MA203.A.AB.045
MA203.A.AB.045
    TAOGLASLIMITED
    MA203.A.AB.045
MA203.A.AB.045 数据手册
SPECIFICATION Part No. : MA.203.A.AB.045 Product Name : GPS/GALILEO/Penta-band/ Cellular Adhesive Antenna Feature : High gain LNA up to 32dB (GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/ HSPA) Height 10.8mm Diameter 55.1mm IP65 Waterproof Fakra Connector ROHS Compliant SPE-11-8-010/D Page 1 of 13 MA.203.A.A301621.B301721 1. Introduction This is a combination high performance GPS/GALILEO and Penta-band Cellular (GSM/CDMA/PCS/DCS/ / UMTS / GPRS / EDGE/ HSPA) antenna to simplify AVL or Fleet management antenna systems worldwide. Its high quality low profile covert housing can be attached onto the glass or even out of sight under the dashboard. This combination of a high gain GPS/GALILEO antenna and a leading edge Penta band cellular antenna is ideal for those applications that require durability, small size and covert installation, and reliable reception and transmission crossing through different mobile networks. 1.1. Features GPS/GALILEO • High LNA Gain up to 32 dB • Antenna Gain 30 ± 2 dB • Miniaturized to 55.15x12mm • Low Noise 1.5 dB max Cellular Advanced Penta-band cellular antenna (GSM/CDMA/PCS/DCS/UMTS/GPRS/EDGE/ HSPA) Other • Water Resistant IP 65(IP 67 MA.203 version also available) • Quality textured covert design. Low profile • UV resistant ABS housing • Comes with high grade 3M double sided tape for quick and easy mounting • Fakra code C (blue) on GPS/GALILEO and code D( violet) on GSM . Optional cables and connectors SPE-11-8-010/D Page 2 of 13 MA.203.A.A301621.B301721 2. Specification 2.1. GPS/GALILEO Antenna GPS/GALILEO Centre Frequency 1575.42MHz Bandwidth 10MHz Average Gain 28dBic typ. (@DC 3V) Radiation Efficiency 50% Gain @ Zenith 4.0dBic typ. Axial Ratio 3.0dB max. Polarization Right Hand Circular VSWR ≦2.0 Impedance 50Ω DC Power Input Range 3~5V DC input 3V LNA Gain(Typ.) 28dB Noise Figure(Typ.) 1.5dB Power Consumption 7~9mA ±50MHz Band Attenuation 40dB Cable 1M RG174 standard, fully customizable Connector SMA(M) standard, standard, fully customizable 2.2. Cellular Antenna CELLULAR Frequency (MHz) Peak gain (dBi) Efficiency 824~894 880~960 1710~1880 1850~1990 2110~2170 >2.5 >0.0 >1.5 >2.5 >0.5 >60% >45% >40% >45% >50% Impedance 50Ω Polarization Linear VSWR 3 max. Cable 1M RG-174 standard, fully customizable Connector SMA(M) standard, fully customizable SPE-11-8-010/D Page 3 of 13 MA.203.A.A301621.B301721 3. Test Setup 3.1. Configuration of SATIMO Cable attenuation(dB/100mm) GHz 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 6 RG-174 67 100 127 153 138 183 207 229 252 272 291 311 CFD-200 26 39 49 58 66 73 86 98 109 SPE-11-8-010/D Page 4 of 13 MA.203.A.A301621.B301721 4. GPS/GALILEO Antenna Characteristics 4.1. Patch antenna S11 4.2. GPS/GALILEO Antenna Pattern( XZ Plane) Far-field amplitude of GPS_1_070108.nsi 345 0 15 330 30 315 45 300 60 285 75 270 -20 -10 0 90 dB 255 105 240 120 225 135 210 150 195 180 165 SPE-11-8-010/D Page 5 of 13 MA.203.A.A301621.B301721 4.3. GPS/GALILEO Antenna Pattern (YZ Plane) Far-field amplitude of GPS_1_070108.nsi 345 0 15 330 30 315 45 300 60 285 75 270 -20 -10 0 90 dB 255 105 240 120 225 135 210 150 195 180 165 4.4. GPS/GALILEO Antenna Gain (with LNA) SPE-11-8-010/D Page 6 of 13 MA.203.A.A301621.B301721 4.5. GPS/GALILEO antenna return loss (With LNA) 5. Cellular antenna 5.1. Return loss (with 1M RG-174 cable) SPE-11-8-010/D Page 7 of 13 MA.203.A.A301621.B301721 6. Radiation Pattern 6.1.1. XZ Plane 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 -35 90 240 120 824M H z 960M H z 960M H z 210 150 180 0 0 330 30 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 1710M 1880M 1990M 2170M Hz Hz Hz Hz 180 SPE-11-8-010/D Page 8 of 13 MA.203.A.A301621.B301721 6.1.2. YZ Plane 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 -35 90 240 120 824M H z 960M H z 960M H z 210 150 180 0 5 330 30 0 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 1710M 1880M 1990M 2170M Hz Hz Hz Hz 180 SPE-11-8-010/D Page 9 of 13 MA.203.A.A301621.B301721 6.1.3. XY Plane 0 5 330 30 0 -5 -10 300 60 -15 -20 -25 -30 270 -35 90 240 120 824M H z 960M H z 960M H z 210 150 180 0 5 330 30 0 -5 -10 -15 300 60 -20 -25 -30 -35 270 -40 90 240 120 210 150 1710M 1880M 1990M 2170M Hz Hz Hz Hz 180 SPE-11-8-010/D Page 10 of 13 MA.203.A.A301621.B301721 7. Mechanical Drawings 7.1. Unit SPE-11-8-010/D Page 11 of 13 MA.203.A.A301621.B301721 SPE-11-8-010/D Page 12 of 13 MA.203.A.A301621.B301721 7.2. Carton Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-11-8-010/D Page 13 of 13 MA.203.A.A301621.B301721
MA203.A.AB.045 价格&库存
很抱歉,暂时无法提供与“MA203.A.AB.045”相匹配的价格&库存,您可以联系我们找货
