PC104R.A.07.0165C
PC104R.A.07.0165C
    TAOGLASLIMITED
    PC104R.A.07.0165C
PC104R.A.07.0165C 数据手册
SPECIFICATION Penta-band Cabled Embedded PCB Antenna Adhesive Mount with Diagnostic Resistor Part No. : Product Name : Penta-Band PCB Antenna with Diagnostic Resistor Feature : GSM/CDMA/DCS/PCS/WCDMA/UMTS/ PC104R.A.07.0165C HSDPA/GPRS/EDGE 850/900/1800/1900/2100 MHz bands High Efficiency - even at long cable lengths 164.9mm Φ1.37 coaxial cable with IPEX connector 80mm*20.8mm*1mm Low profile AntD© Shunt 10k Ohm Chip Resistor Inside With 3M adhesive RoHS compliant AntD© Resistor SPE-13-8-075/A/AS Page 1 of 11 1. Introduction The high efficiency embedded PC104R Penta-band PCB Antenna with AntD© Resistor slim-line design allows for convenient installation inside the customer device. Omni-directional gain across all bands ensures constant reception and transmission. With its unique dipole design, the PC104R has exceptional industry performance characteristics considering its very low profile at 2.4mm and has a compact size 80mm*20mm. It is suitable for clients that appreciate highest performance with lower price. This antenna has 3M adhesive on the back, and is tuned and designed to be mounted on 2mm thickness plastic (not on metal). Cable lengths and connectors are fully customizable and the antenna is suitable for long cable lengths out to 2 metres. For good efficiency performance the shortest cable length should however not be less than 100mm, for requirements with shorter cable lengths the alternative product the FXP.14 can be used. AntD© allows connected radio products designed using the latest cellular modules from companies such as Telit and uBlox to perform diagnostics on the antenna. This includes detection that the proper antenna is connected and that the connection isn’t shorted or broken. Contact Taoglas engineering for examples on how to implement AntD© antenna diagnostics in your product. SPE-13-8-075/A/AS Page 2 of 11 2. Specification ELECTRICAL GSM850 GSM900 DCS PCS 2100 Frequency (MHz) 824~896 880~960 1710~1880 1850~1990 1920~2170
PC104R.A.07.0165C
物料型号是TI的LM358N,它是一款双运算放大器。
器件简介为LM358N是一款低功耗、高增益放大器,广泛应用于各种线性应用。
引脚分配为8引脚双列直插式封装,1脚为正输入,2脚为负输入,3脚为输出,4脚为负电源,5脚为正电源,6脚为禁用,7脚为正输入,8脚为负输入。
参数特性包括供电电压范围为±3V至±32V,单位增益带宽为1MHz,压摆率为0.3V/μs,增益带宽积为1MHz。
功能详解为LM358N具有高输入阻抗、低输出阻抗、低失调电压和低噪声等特性,适用于音频放大、信号调节、传感器信号调理等应用。
应用信息包括音频放大器、传感器信号调理、仪表放大器、滤波器设计等。
封装信息为8引脚双列直插式封装(DIP-8)。
PC104R.A.07.0165C 价格&库存
很抱歉,暂时无法提供与“PC104R.A.07.0165C”相匹配的价格&库存,您可以联系我们找货
PC104R.A.07.0165C
    • 100+60.58802
    库存:105
    PC104R.A.07.0165C
      • 8+97.482128+12.61080
      • 40+87.7863240+11.35650
      库存:105
      PC104R.A.07.0165C
      • 8+90.52972
      • 40+81.47436
      库存:105
