Meteor
Part No:
FW.92.RNT.M
Description:
Penta-band cellular 2G/3G GSM/CDMA/UMTS
Flexible Whip Monopole Antenna
850/900/1800/1900/2100MHz
Features:
Robust Inner Steel Core
RP-N-type Male Connector
IP65
RoHS Compliant
SPE-12-8-090/B/WY
1.
Introduction
3
2
Specifications
4
2.
Antenna Characteristics
5
3.
Radiation Patterns
7
4.
Mechanical Drawing
9
5.
Packaging
10
Changelog
11
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-12-8-090/B/WY
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
The FW.92 is a flexible cellular whip antenna with IP65 housing and an RP-N-type male connector. It has a
wide response and high peak gain. It is ideal for outdoor environments which require high gain on both lower
and upper bands. It's unique characteristic is it has stable above 3dBi peak gain on all five common 2G/3G
1.
1.
GSM/CDMA cellular bands used worldwide (when attached to a 30cm*30cm metal plate). The antenna
Introduction
radiates best attached to a metal plate but it can still perform without as evidenced by the table below.
This antenna delivers wider coverage areas and more reliable connections for professional customers in the
Introduction
automotive and industrial sectors. The whip is made up of a flexible inner steel core covered by TPU so
extremely resistant to collisions and maintaining its original shape and RF performance.
1.
Introduction
Customized frequency and gain versions can be supplied.
SPE-12-8-090/B/WY
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
Frequency (MHz)
CELLULAR
Specifications
824~896
880~960
1710~1880
1850~1990
1710~2170
-0.1
3.0
3.3
3.3
3.4
3.9
4.0
4.0
-3.4
-2.3
-1.9
-1.9
-2.0
-1.5
-1.4
46%
59%
65%
65%
61%
63%
71%
72%
Peak Gain (dBi)
3.
Free Space
-0.2
Antenna
Characteristics
With Ground plane(30x30cm)
3.3
Average Gain (dBi)
Free Space
4.
-3.8
Antenna
Radiation Patterns3.Antenna
-1.2
-2.1
Characteristics2.
Free Space
Specifications
41%
3.
3.
70%
Impedance
Efficiency
50Ω
Antenna
Characteristics2.
Polarization
Specifications
Linear
Radiation Pattern
Omni
Input Power
50 W
Tested Power
Antenna
Characteristics
10 W
Mechanical
4.
Dimensions
Height 274 ± 5 mm
Base Diameter
20 ± 0.1 mm
Antenna
Radiation Patterns3.Antenna 4 ± 0.2 mm
Whip Diameter
Casing
Characteristics
ABS
Connector
RP-N-type Male
Environmental
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
4.
Antenna Radiation Patterns
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-12-8-090/B/WY
Specifications
www.taoglas.com
4
3.
4.
3.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-12-8-090/B/WY
www.taoglas.com
5
3.3
Peak Gain
3.4
Average Gain
SPE-12-8-090/B/WY
www.taoglas.com
6
4.
Radiation Patterns
4.
4.
4.
4.
Antenna Radiation Patterns X
4.
4.
Antenna Radiation
Patterns
XY Plane
4.1
Antenna Free Space
Y
Z
X
4.
XZ Plane
X
Z
Y
4.
X
X
Y
SPE-12-8-090/B/WY
Z
www.taoglas.com
7
4.2
Antenna on Ground plane (30X30cm)
Y
Z
X
XY Plane
XZ Plane
X
X
Z
Y
SPE-12-8-090/B/WY
www.taoglas.com
8
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-12-8-090/B/WY
Mechanical Drawing
www.taoglas.com
9
6.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-12-8-090/B/WY
Mechanical Drawing
www.taoglas.com
10
Changelog for the datasheet
SPE-12-8-090 - FW.92.RNT.M
Revision: B
Date:
Changes:
Changes Made by:
2019-08-16
Updated to new format
Dan Cantwell
Previous Revisions
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-12-8-090/B/WY
2012-07-17
SS
www.taoglas.com
11
www.taoglas.com
SPE-12-8-090/B/WY
© Taoglas
www.taoglas.com
12
很抱歉,暂时无法提供与“FW.92.RNT.M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+161.05619
- 25+144.94578
- 国内价格 香港价格
- 5+173.476245+22.44180
- 25+156.0936825+20.19310
