SPECIFICATION
Part No.
GW.26.0111.HT
Product Name
2.4GHz Miniature Screw Mount Monopole Antenna
HIGH TEMPERATURE
Feature
SMA(M) Straight Connector, 50 Ohm
Dupont® Hytrel® High Temperature Resistant
TPEE Housing (up to 150°C)
ROHS Compliant
SPE-14-8-021/F/PK
Page 1 of 13
1 Introduction
The GW.26 HT series 2.4 GHz Monopole SMA (M) mount antenna is ideal for 2.4 GHz wireless
applications such as Wifi, Zigbee and Bluetooth.
Antenna housing is made of highly resistant Dupont® Hytrel® TPEE material which is durable
in high temperature application environments up to 150°C. This material is often applied in
automotive or industrial applications, where the antenna is placed near the engine or heat
generating components.
Many module manufacturers specify peak gain limits for any antennas that are to be
connected to that module. Those peak gain limits are based on free-space conditions. In
practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2dBi
when put inside a device. So ideally you should go for a slightly higher peak gain antenna
than mentioned on the module specification to compensate for this effect, giving you better
performance.
Upon testing of any of our antennas with your device and a selection of appropriate layout,
integration technique, or cable, Taoglas can make sure any of our antennas’ peak gain will be
below the peak gain limits. Taoglas can then issue a specification and/or report for the
selected antenna in your device that will clearly show it complying with the peak gain limits,
so you can be assured you are meeting regulatory requirements for that module.
For example, a module manufacturer may state that the antenna must have less than 2dBi
peak gain, but you don’t need to select an embedded antenna that has a peak gain of less
than 2dBi in free-space. This will give you a less optimized solution. It is better to go for a
slightly higher free-space peak gain of 3dBi or more if available. Once that antenna gets
integrated into your device, performance will degrade below this 2dBi peak gain due to the
effects of GND plane, surrounding components, and device housing. If you want to be
absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher
peak gain than what is specified by the module manufacturer and enlisting our help will
ensure you are getting the best performance possible without exceeding the peak gain limits.
Connection is made via a fixed SMA(M) connector with a hardened TPEE casing, this antenna
is the ideal Wi-Fi-Bluetooth-ZigBee antenna for M2M devices where the antenna must be
placed in harsh high temperature environments.
SPE-14-8-021/F/PK
Page 2 of 13
2 Specification
Wi-Fi 2.4GHz
Frequency
2400~2500MHz
Bandwidth
100MHz
Peak Gain
1.2dBi
Radiation Efficiency
> 40%
Radiation
Omni-directional
Polarization
Vertical
Power Handling 1W Max
Electrical Wave
Monopole
Impedance
50Ω
Operating Temperature
-40°C ~ +150°C
Storage Temperature
-40°C ~ +85°C
SPE-14-8-021/F/PK
Page 3 of 13
3 Mechanical Properties
No
Parameter
Specification
1
Temperature
-40°c to +150°c
2
Radome Colour
Black
3
Radome Material
4 Antenna Characteristics
4.1 Antenna S11
SPE-14-8-021/F/PK
Page 4 of 13
4.2
Antenna Peak Gain
3
Peak Gain (dBi)
2
Peak Gain(dBi)
1
-2
-3
-4
2350 2360 2370 2380 2390 2400 2410 2420 2430 2440 2450 2460 2470 2480 2490 2500 2510 2520 2530 2540 2550
Freq(MHz)
SPE-14-8-021/F/PK
Page 5 of 13
4.3
Antenna Efficiency
60
Efficiency (%)
50
Efficiency(%)
40
30
Freq(MHz)
SPE-14-8-021/F/PK
Page 6 of 13
4.4
Antenna pattern (XY plane)
SPE-14-8-021/F/PK
Page 7 of 13
4.5
330
30
-10
-15
300
60
-20
-25
-30
-35
270
-40
90
2400MHz
2420MHz
2440MHz
240
120
2460MHz
2480MHz
2500MHz
210
150
180
SPE-14-8-021/F/PK
Page 8 of 13
4.6
Antenna pattern (XZ plane)
30
-5
-10
-15
300
60
-20
-25
-30
-35
270
-40
90
2400MHz
2420MHz
2440MHz
240
120
2460MHz
2480MHz
2500MHz
210
150
180
SPE-14-8-021/F/PK
Page 9 of 13
4.7
Antenna pattern (YZ plane)
30
-5
-10
-15
300
60
-20
-25
-30
-35
270
-40
90
2400MHz
2420MHz
2440MHz
240
120
2460MHz
2480MHz
2500MHz
210
150
180
SPE-14-8-021/F/PK
Page 10 of 13
5. Outline Drawings and Structure
SPE-14-8-021/F/PK
Page 11 of 13
6. Packaging
SPE-14-8-021/F/PK
Page 12 of 13
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and
reserves the right to make changes to specifications and product descriptions at any time without notice.
Taoglas reserves the rights to this document and the information contained herein. Reproduction, use or disclosure
to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-021/F/PK
Page 13 of 13
很抱歉,暂时无法提供与“GW.26.0111.HT”相匹配的价格&库存,您可以联系我们找货
