ANT-DB1-RMS-xxx
Data Sheet
by
Product Description
10.0 mm
(0.39")
Designed for permanent mounting through a metal
surface such as an automobile roof or trunk, the
compact RMS Series offers excellent performance
in a durable and unobtrusive housing. The antenna
may be operated at either or both of two frequency
bands. It is supplied with 14.1 feet (4.3 m) of
RG-58 cable and can be terminated in a standard
SMA, Part 15 compliant RP-SMA or a TNC
connector.
14.0 mm
(0.55")
42.0 mm
(1.65")
77.8 mm
(3.06")
23.6 mm
(0.93")
29.0 mm
(1.14")
Features
8.0 mm
(0.31")
Dual-band (824–960MHz and 1.71–1.99GHz)
Compact & unobtrusive
Through-hole mount
Low VSWR
Excellent performance
Omni-directional pattern
Fully weatherized
Rugged & damage-resistant
SMA, RP-SMA or TNC connector
Standard
13.34–13.97 mm
(0.525–0.550")
7.0 mm
(0.28")
Suggested Mounting Holes
Anti-Rotation
11.48–11.56 mm
(0.452–0.455")
11.3 mm
(0.44")
13.1 mm
(0.52")
Electrical Specifications
Recom. Freq. Range: Band 1: 824–960MHz
Band 2: 1.71–1.99GHz
Wavelength:
¼-wave
VSWR:
Band 1: ≤ 1.5 typ. at center
Band 2: ≤ 2.0 typ. at center
Peak Gain:
Band 1: –0.6dBi
Band 2: 5.3dBi
Impedance: 50-ohms
Oper. Temp. Range:
–40°C to +80°C
Connector:
SMA, RP-SMA or TNC
Cable:
14.1' (4.3 m) RG-58 coax
Ordering Information
ANT-DB1-RMS-SMA (with SMA connector)
ANT-DB1-RMS-RPS (with RP-SMA connector)
ANT-DB1-RMS-TNC (with TNC connector)
–1–
Revised 12/11/13
VSWR Graph
VSWR
1.221
1.894
Reflected Power
3:1
25%
2:1
11%
1:1
0%
CENTER 868.000MHz
CENTER 1 800.000MHz
SPAN 200.000MHz
What is VSWR?
The Voltage Standing Wave Ratio (VSWR) is a measurement of how well
an antenna is matched to a source impedance, typically 50-ohms. It is
calculated by measuring the voltage wave that is headed toward the load
versus the voltage wave that is reflected back from the load. A perfect
match will have a VSWR of 1:1. The higher the first number, the worse the
match, and the more inefficient the system. Since a perfect match cannot
ever be obtained, some benchmark for performance needs to be set. In
the case of antenna VSWR, this is usually 2:1. At this point, 88.9% of the
energy sent to the antenna by the transmitter is radiated into free space
and 11.1% is either reflected back into the source or lost as heat on
the structure of the antenna. In the other direction, 88.9% of the energy
recovered by the antenna is transferred into the receiver. As a side note,
since the “:1” is always implied, many data sheets will remove it and just
display the first number.
How to Read a VSWR Graph
VSWR is usually displayed graphically versus frequency. The lowest point
on the graph is the antenna’s operational center frequency. In most cases,
this will be different than the designed center frequency due to fabrication
tolerances. The VSWR at that point denotes how close to 50-ohms the
antenna gets. Linx specifies the recommended bandwidth as the range
where the typical antenna VSWR is less than 2:1.
–2–
Data Sheet ANT-DB1-RMS-xxx
by
很抱歉,暂时无法提供与“ANT-DB1-RMS-RPS”相匹配的价格&库存,您可以联系我们找货
