G24.A.W.305111
G24.A.W.305111
    TAOGLASLIMITED
    G24.A.W.305111
G24.A.W.305111 数据手册
Part No: Description: G24.A.W.305111 G24 Ultima Series – Super Low Profile Penta Band Cellular Antenna 800~960/1710~2170MHz Permanent mount Datasheet GSM/GPRS/CDMA/HSPA SPE-13-8-044.D Features: Height 19.6mm(0.77”) and diameter 55mm(2.16”) Heavy duty screw mount UV and vandal resistant PC housing and thread IP67 compliant Standard is 3 meter low loss cable TGC-200 SMA(M) Cables and Connectors Customizable 1 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Antenna Radiation Patterns 8 5. Installation 16 6. Mechanical Drawing 17 7. Packaging 18 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-13-8-044.D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. G24.W Ultima Series Cellular Antenna is an extremely low profile 2G/3G 800MHz to 2200MHz cellular antenna solution for professional telematics applications. Suitable for GSM/GPRS/CDMA applications worldwide, at only 19.6mm (0.77”) in height it is the lowest profile antenna in the market, with a diameter of only 55 mm (2.16”). It works well when mounted on both metal and non-metal. In other words it does not need a metal ground-plane to attach to, to radiate, something that competitor antennas all need. Taoglas recommend a minimum cable length of 70mm when used on a ground plane to achieve an efficiency of greater than 20%. Introduction Introduction Durable UV PC housing, thread and nut is resistant to vandalism and direct attack. 1. The IP67 waterproof robust plastic body makes it extremely light, economical for shipping and minimum weight impact on vehicles. This also makes it ideal for use in humid environments such as water pits or marine applications as there are no metal parts to corrode. The closed cell foam with double-sided adhesive provides a permanent waterproof seal and can adjust to different curvatures, stopping water from leaking under the antenna into the mounting hole. Lowest loss PTFE cable is used for maximum gain and reduced noise entry through the cable. Introduction Also available in white. SPE-13-8-044.D www.taoglas.com 3 2. Specifications Cellular 3. 824~896 880~960 Specifications 1710~1880 Antenna Characteristics2. Frequency (MHz) 1850~1990 1920~2170 Peak Gain (dBi) Free space 3. 4. 2.0 10*10cm ground plane -0.6 Antenna Characteristics 1.8 3.9 3.9 3.9 0.7 -0.2 1.7 1.7 3.1 3.1 3.1 1.7 1.7 2.0 -2.7 -2.8 -2.7 -4.9 -4.0 -4.0 -4.2 -4.0 -4.0 -4.4 -4.4 -4.4 39.3 53.4 52.5 53.4 32.1 40.0 40.0 37.8 39.3 39.3 36.0 36.0 36.0 20*20cm ground plane 1.8 1.8 30*30cm ground plane 0.0 0.0 Antenna Radiation Patterns3. Antenna Average Gain (dBi) Free space Characteristics2. -4.1 10*10cm ground plane -4.8 -3.3 20*20cm ground plane -4.3 -4.3 30*30cm ground plane -6.3 -6.6 3. -4.0 Specifications Antenna Characteristics2. Specifications Efficiency (%) 3. 4. Free space 39.1 Antenna Characteristics 10*10cm ground plane 33.8 46.2 20*20cm ground plane 36.9 36.9 30*30cm ground plane 23.4 23.4 Antenna Radiation Patterns3. Characteristics 4. Antenna Impedance 50Ω Polarization Linear Antenna Radiation Patterns Radiation Pattern Omni Input Power 10 W Mechanical 4. Dimensions Ø55±2mm , Height 30±2 mm, Profile 19.6mm Antenna Radiation Patterns3. Antenna Cable type TGC-200 Characteristics Connector 4. SMA Male Straight Cable length 3000mm Casing PC Antenna Radiation Patterns3. SPE-13-8-044.D Characteristics2. Specifications Antenna www.taoglas.com 4 Environmental Temperature Range -40°C to 85°C Waterproof IP-67 Thermal Shock 100 cycles -40°C to +80°C Shock (drop test) 1m drop on concrete 6 axes Humidity Non-condensing 65°C 95% RH Weight 180g Recommended Torque for Mounting Max Torque for Mounting 3.92N∙m SPE-13-8-044.D 4.9N∙m www.taoglas.com 5 3. 4. Antenna Characteristics 3.1 Antenna Radiation Patterns3. 3.1 Cellular antenna SWR Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3. Antenna Characteristics 4. Antenna Radiation Patterns3. Antenna Characteristics 3.2 4. Efficiency Antenna Radiation Patterns 60 G24_Free Space 50 4. (%) 4. Antenna Radiation Patterns G24_On 10X10 cm Ground 40 30 G24_On 20X20 cm Ground Antenna Radiation Patterns 20 4. 10 Antenna Radiation Patterns3. Antenna G24_On 30X30 cm Ground 0 Characteristics 800 1000 1200 1400 1600 4. SPE-13-8-044.D Antenna Radiation Patterns3. 1800 2000 Antenna 2200 (MHz) www.taoglas.com 6 3.3 Average Gain 0 -2 G24_Free Space -4 -6 G24_On 10X10 cm Ground (dBi) -8 -10 G24_On 20X20 cm Ground -12 -14 G24_On 30X30 cm Ground -16 -18 -20 800 3.4 1000 1200 1400 1600 1800 2000 2200 (MHz) Peak Gain 10 G24_Free Space (dBi) 5 G24_On 10X10 cm Ground 0 G24_On 20X20 cm Ground -5 G24_On 30X30 cm Ground -10 800 SPE-13-8-044.D 1000 1200 1400 1600 1800 2000 2200 (MHz) www.taoglas.com 7 4. Antenna Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup – Free Space 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Free space 4. Antenna Radiation Patterns SPE-13-8-044.D www.taoglas.com 8 XY Plane X X Y Y XZ Plane Z Z X SPE-13-8-044.D X www.taoglas.com 9 4. 4.2 Test Setup – 10*10m Ground Plane 10x10m Ground Plane SPE-13-8-044.D www.taoglas.com 10 XY Plane X X Y Y XZ Plane Z Z X SPE-13-8-044.D X www.taoglas.com 11 4.3 Test Setup - (20*20mm Ground Plane) 20x20cm Ground Plane SPE-13-8-044.D www.taoglas.com 12 XY Plane X X Y Y XZ Plane Z Z X SPE-13-8-044.D X www.taoglas.com 13 4.4 Test Setup - (30*30mm Ground Plane) 30x30cm Ground Plane SPE-13-8-044.D www.taoglas.com 14 XY Plane X X Y Y XZ Plane Z Z X SPE-13-8-044.D X www.taoglas.com 15 5. Installation 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-13-8-044.D www.taoglas.com 16 6. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. SPE-13-8-044.D Packaging5. Mechanical Drawing www.taoglas.com 17 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. SPE-13-8-044.D Packaging5. Mechanical Drawing www.taoglas.com 18 www.taoglas.com SPE-13-8-044.D www.taoglas.com 19
G24.A.W.305111 价格&库存
很抱歉,暂时无法提供与“G24.A.W.305111”相匹配的价格&库存,您可以联系我们找货
G24.A.W.305111
  • 3+313.89451
  • 8+308.03038
  • 15+302.26297
  • 29+296.39883
  • 50+290.63143
库存:95
G24.A.W.305111
    • 2+499.595402+64.63600
    • 8+441.251048+57.08760
    • 15+432.9535715+56.01410
    • 29+424.5687529+54.92930
    • 50+416.3586150+53.86710
    库存:95
    G24.A.W.305111
    • 1+475.745471+61.55038
    • 8+351.902658+45.52800
    • 15+345.3288215+44.67750
    • 29+338.6738329+43.81650
    • 50+332.0188550+42.95550
    库存:95
    G24.A.W.305111
    • 2+463.90794
    • 8+409.73145
    • 15+402.07750
    • 29+394.30378
    • 50+386.64984
    库存:95
