SPECIFICATION
Part No.
G20.B.305111.wmc
Product Name
Hercules Covert Wall and Cabinet Mounted Cellular
Antenna
Features
GSM / CDMA /DCS /PCS / WCDMA / UMTS /
HSDPA
850/900/1700/1800/1900/2100 MHz
High Efficiency - Omni-directional Pattern
Covert and Vandal Resistant
IP67 and IP69K Waterproof
Standard is 3M Cable NFC200
SMA(M)-Customizable
ROHS Compliant
Photo:
SPE-14-8-091/C/WY
Page 1 of 15
1. Introduction
The Wall Mount G20 Hercules Gen II is a high performance covert wall mounted
cellular antenna for 2G and 3G applications. This antenna can easily fix to a wall
or metal surface. The Wall Mount G20 antenna has omnidirectional radiation
patterns across all bands ensuring constant reception and transmission.
Applications
- Smart City Outdoors Utility and Traffic Management
On Building Wall
On Street Metal Cabinet
PC housing is resistant to vandalism and direct attack. The Hercules and the
connection internally to the bracket is completely IP67 waterproof. The bracket
allows complete concealment of the cable for a more secure integration and
cleaner installation. The cable can also be routed out of the back wall of the
bracket into the interior of the mounting wall for added security against
vandalism. The standard version comes with 3 meters extremely low loss
NFC200 (0.3dB against 0.7dB per meter for RG58) to allow for flexibility of
placement. The cable and connector can be completely customized.
SPE-14-8-091/C/WY
Page 2 of 15
2. Specification
ELECTRICAL
Standard
GSM
GSM
DCS
PCS
UMTS/ HSPA
Band (MHz)
850
900
1800
1900
2100
Frequency (MHz)
824~894
880~960
1710~1880
1850~1990
1920~2170
75.09
68.48
61.56
54.40
63.10
57.80
51.51
45.24
54.48
50.15
44.54
38.97
Efficiency (%)
30 cm cable length
1 meter cable length
2 meters cable length
3 meters cable length
45.64
43.59
40.32
37.33
70.44
67.27
61.35
56.84
5 meters cable length
50.65
40.64
33.64
30 cm cable length
32.05
53.61
Average Gain(dBi)
-3.68
-1.53
-3.88
-1.73
-4.21
-2.13
-1.27
-1.67
-2.14
-2.04
-2.41
-2.91
-2.76
-3.12
-3.64
-4.54
-2.47
-2.67
-3.48
-4.22
-5.28
-3.23
-3.75
-4.60
-5.33
Peak Gain(dBi)
30 cm cable length
Impedance
Polarization
Radiation Pattern
Input Power
Antenna Dimensions
Bracket Dimensions
Antenna Cable Length
Connector
Antenna Casing
Bracket Casing
Base and Thread
Thread Diameter
Weather proof gasket
Sealant
Weight
Protection
Corrosion
Temperature Range
Thermal Shock
Humidity
Shock (Drop Test)
2.07
3.21
4.21
3.48
2.81
1.87
1.54
1.21
0.47
3.01
2.61
2.28
1.51
3.81
3.34
2.81
1.73
3.10
2.60
2.04
0.92
2.45
1.93
1.35
0.24
50Ω
Linear
Omni
5W
MECHANICAL
Height = 29 mm and Diameter = 49 mm
Height = 92.4 mm and Length = 128.7 mm
3M NFC200 – Fully Customizable
SMA-Male – Fully Customizable
PC
Plastic: PC+ABS, Metal: Aluminum
Nickel plated steel
18 mm
CR4305 foam with 3M9448B double-sided adhesive
Rubber Stopper
340g
ENVIRONMENTAL
IP67 and IP69K
5% NaCl for 48hrs - Nickel plated steel base and thread
-40°C to +85°C
100 cycles -40°C to +85°C
Non-condensing 65°C 95% RH
1m drop on concrete 6 axes
SPE-14-8-091/C/WY
Page 3 of 15
3. Antenna Characteristics
3.1 Testing setup
Figure.1 Test setup with bracket
SPE-14-8-091/C/WY
Page 4 of 15
3.2 Return loss
Figure2. Return loss of G20.B.305111.wmc with 3 meters cable length
3.3 Efficiency
Figure3. Efficiency of G20.B.305111.wmc with 3 meters cable length
SPE-14-8-091/C/WY
Page 5 of 15
3.4 Peak gain
Figure4. Peak gain of G20.B.305111.wmc with 3 meters cable length
3.5 Average gain
Figure5. Average gain of G20.B.305111.wmc with 3 meters cable length
SPE-14-8-091/C/WY
Page 6 of 15
4. Antenna Radiation Patterns
4.1 Testing setup
The antenna radiation patterns were measured in ETS Anechoic Chamber. The
measurement setup as below,
Y
X
Z
Figure.6
Testing Setup in ETS Anechoic Chamber
SPE-14-8-091/C/WY
Page 7 of 15
4.2 Antenna radiation patterns (Antenna with L-bracket
and 3 meters cable length)
X-Y plane (824MHz~960MHz)
X
Y
X-Y plane (1710MHz~2170MHz)
X
Y
SPE-14-8-091/C/WY
Page 8 of 15
X-Z plane (824MHz~960MHz)
X
Z
X-Z plane (1710MHz~2170MHz)
X
Z
SPE-14-8-091/C/WY
Page 9 of 15
Y-Z plane (824MHz~960MHz)
Z
Y
Y-Z plane (1710MHz~2170MHz)
Z
Y
SPE-14-8-091/C/WY
Page 10 of 15
5. DRAWING
Cellular
YY
ZZ
SMA (M) ST
Name
Material
P/N
Finish
QTY
1
Housing
000113F000010A PC
Black
1
2
Closed Cell Foam
001011F040001A
CR 4305
Black
1
3
3M Double Adhesive
001011F040001A
3M 9448 WC
White Liner
1
4
Bracket Housing
000111I020020A
PC+ABS
Black
1
5
Bracket
000511J040020A
AL
Black
1
6
Cellular Label
001011F020017A
Coated Paper
Blue
1
7
Φ 4*25L Screw
000411A040054A
Stainless Steel N/A
8
Φ 6*24L Wall Mount Stud 000411A050054A
Nylon
White
4
9
Heat Shrink Tube
001311F010013A
PE
Black
1
000411C020054A
Steel
Black
6
10 Φ 3*8 SCREW
Name
Spec
P/N
Finish
4
QTY
YY
Cable Type
301412K000013A
NFC200
Black
1
ZZ
Connector Type
200211G010013A
SMA(M)
Gold
1
SPE-14-8-091/C/WY
Page 11 of 15
6. Packaging
SPE-14-8-091/C/WY
Page 12 of 15
7. Application Note
The G20.B.305111.wmc antenna measurement with different cable length, the
performance is shown as below:
7.1 Return loss
Figure 7. Measured the return loss of G20.B.305111.wmc Antenna with different cable length
7.2 Efficiency
Figure 8. Measured the efficiency of G20.B.305111.wmc Antenna with different cable length
SPE-14-8-091/C/WY
Page 13 of 15
7.3 Average Gain
Figure 9. Measured the Average Gain of G20.B.305111.wmc Antenna with different cable
length
7.4 Peak Gain
Figure 10. Measured the Peak Gain of G20.B.305111.wmc Antenna with different cable length
SPE-14-8-091/C/WY
Page 14 of 15
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves
the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all
rights to this document and the information contained herein.
Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
Copyright © Taoglas Ltd.
SPE-14-8-091/C/WY
Page 15 of 15
很抱歉,暂时无法提供与“G20.B.305111.WMC”相匹配的价格&库存,您可以联系我们找货
