OMB.445.05F21
OMB.445.05F21
    TAOGLASLIMITED
    OMB.445.05F21
OMB.445.05F21 数据手册
Barracuda – 5.5dBi Omnidirectional Antenna Covering 2.4-6GHz 5G/4G and Public Safety Bands Part No: OMB.445.05F21 Features: Omnidirectional Radiation Pattern Robust Design for all Demanding Application IP65 Waterproof Length: 270mm Weight: 250g Connector: N-type Female Wall/Pole Mount Bracket Included RoHS & Reach Compliant SPE-13-8-042-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 14 6. Packaging 15 7. Installation 16 Changelog 17 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-13-8-042-E www.taoglas.com 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. Introduction The Taoglas Barracuda OMB.445 is a robust, cost-effective outdoor antenna designed to provide longdistance coverage for 4G and sub 6GHz 5G bands, spanning 2 – 6GHz. With incredible efficiency of up to 88%, the high omnidirectional gain ensures consistent and reliable reception and transmission making the OMB.455 perfect for private LTE or CBRS networks or Public Safety applications. Introduction The UV-resistant fiberglass radome ensures that the antenna can be used for many years of outdoor use without any degradation of appearance or mechanical specifications. The radome sits in a rugged bracket that makes this antenna suitable to be mounted by either pole-mount or and wall-mounting options. Introduction The OMB.455 ships with an industry-standard N-Type connector but other connectors are available subject to MOQ and NRE. Taoglas can also offer a customized cable assembly to help with your installation. Check out our Cable Builder here. For more information on the OMB.455 or any of Taoglas Barracuda series of omnidirectional antennas, contact your regional Taoglas customer support team. SPE-13-8-042-E www.taoglas.com 2. Specifications Electric Efficiency Average Gain 3. BandAntenna Frequency Characteristics2. Specifications Max Input Impedance (MHz) (%) (dB) Peak Gain (dBi) 2300~2690 59 -2.3 4.1 5G/4G 3. Antenna Characteristics 3300~3800 86 -0.6 Band 22,42,78 6.1 4G/3G Band 7,30,38,40,41 5G/4G Band 22,42,43,48,77,78,79 4. Power 50 Ω 3200~5000 88 -0.5 100W Polarization Radiation Pattern Vertical Omni-directional 7.2 -0.6 Antenna Radiation Patterns3. Antenna 5150~5925 86 6.8 Greater than 5GHz Antenna Type Characteristics2. Specifications Collinear Vertical Beam-width 25 Deg Horizontal Beam-width 360 Deg Antenna Design Dipole Array 3. Antenna Characteristics2. Specifications 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-13-8-042-E Specifications www.taoglas.com Mechanical Length 270mm Bracket Dimension 70*35mm Radome Diameter 24mm Antenna Weight (G.W) 250g Mounting Accessories (G.W) 50g Application Indoor/Outdoor Radome Material White Fiberglass Internal Material Copper Connector N Type Female Base Material Aluminum Mount Style Pole Mount(32mm~48mm)/Wall Mount Mounting Stainless Steel Wind Resistance >150mph(>241km/h) Waterproof IP65 Environmental Storage Temperature -20°C to +80°C Operating Temperature -20°C to +60°C Operating Humidity 10%~80% non-condensing Storage Humidity 5%~80% non-condensing 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 4 UL: 1710 to 1755 DL: 2110 to 2155 7 UL: 2500 to 2570 DL:2620 to 2690 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 30 UL: 2305 to 2315 DL: 2350 to 2360 38 2570 to 2620 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 77 3300 to 4200 78 3300 to 3800 79 4400 to 5000 SPE-13-8-042-E Covered  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ www.taoglas.com 3. 4. Antenna Characteristics 3.1 Return Loss Antenna Radiation Patterns3.Antenna Characteristics 0 -5 4. -10 Antenna Radiation Patterns Return Loss [dB] 4. -15 -20 -25 Antenna Radiation Patterns3.Antenna -30 Characteristics -35 -40 2000 2250 2500 2750 3000 3250 3500 3750 4000 4250 4500 4750 5000 5250 5500 5750 6000 4. Frequency [MHz] Antenna Radiation Patterns3. Antenna Characteristics 3.2 VSWR 10.0 4. Antenna Radiation Patterns 9.0 8.0 7.0 6.0 Antenna Radiation Patterns VSWR 4. 5.0 4.0 4. 3.0 Antenna Radiation Patterns 2.0 1.0 4. 0.0 2000 2250 2500 2750 3000 3250 3500 3750 4000 4250 4500 4750 5000 5250 5500 5750 6000 Antenna Radiation Patterns3. Antenna Frequency [MHz] Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-042-E www.taoglas.com 3.3 Efficiency 100 90 80 Efficiency [%] 70 60 50 40 30 20 10 0 2000 2250 2500 2750 3000 3250 3500 3750 4000 4250 4500 4750 5000 5250 5500 5750 6000 Frequency [MHz] 3.4 Peak Gain 8 7 Gain [dBi] 6 5 4 3 2 1 0 2000 2250 2500 2750 3000 3250 3500 3750 4000 4250 4500 4750 5000 5250 5500 5750 6000 Frequency [MHz] SPE-13-8-042-E www.taoglas.com 3.5 Average Gain Aver Gain [dB] 0 -1 -2 -3 2000 2250 2500 2750 3000 3250 3500 3750 4000 4250 4500 4750 5000 5250 5500 5750 6000 Frequency [MHz] SPE-13-8-042-E www.taoglas.com 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-13-8-042-E www.taoglas.com 4.2 2400MHz 3D and 2D Radiation Patterns XY Plane SPE-13-8-042-E XZ Plane YZ Plane www.taoglas.com 3500MHz XY Plane SPE-13-8-042-E XZ Plane YZ Plane www.taoglas.com 4400MHz XY Plane SPE-13-8-042-E XZ Plane YZ Plane www.taoglas.com 5500MHz XY Plane SPE-13-8-042-E XZ Plane YZ Plane www.taoglas.com 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-13-8-042-E Mechanical Drawing www.taoglas.com 6. Packaging 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-13-8-042-E www.taoglas.com 7. Installation 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics Mounting Recommendations: For optimum cellulat performance when mounting the OMB.455 onto a metal pole, please ensure that the base of the antenna / top of the bracket is mounted above the top of the pole as per the red line above. Failure to do so may impede performance of the antenna. 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. SPE-13-8-042-E Antenna Radiation Patterns3.Antenna www.taoglas.com Changelog for the datasheet SPE-13-8-042 - OMB.445.05F21 Revision: E (Current Version) Date: Changes: Changes Made by: 2021-07-23 Full datasheet update and rebranded to cover 5GHz band Gary West Previous Revisions Revision: D Date: Changes: Changes Made by: 2018-03-27 Amended Installation Jack Conroy Revision: C Date: Changes: Changes Made by: 2018-03-16 Added Installation Guide Jack Conroy Revision: B Date: Changes: Changes Made by: 2015-08-21 added note on gain Aine Doyle Revision: A (Original First Release) Date: Notes: Author: SPE-13-8-042-E 2021-05-17 SS www.taoglas.com SPE-13-8-042-E © Taoglas www.taoglas.com
OMB.445.05F21 价格&库存
很抱歉,暂时无法提供与“OMB.445.05F21”相匹配的价格&库存,您可以联系我们找货
OMB.445.05F21
    • 1+2129.233061+275.44880
    • 2+1880.898242+243.32290
    • 4+1845.434314+238.73510
    库存:6
    OMB.445.05F21
    • 1+1137.11040
    • 2+1116.04788
    • 4+1094.98535
    库存:6
    OMB.445.05F21
    • 1+1977.13659
    • 2+1746.50020
    • 4+1713.58466
    库存:6
