SG102N-2450
SG102N-2450
    NEARSON
    SG102N-2450
SG102N-2450 数据手册
NEARSON SG102N-2450 2.4GHz Omni Directional Antenna Features • Frequency range: 2.4~2.5 GHz • Ultra-violet resistant fiberglass radome • Die casting mounting base with rugged structure design Technical Data Electrical Properties Frequency Range 2400~2500 MHz Impedance 50 ohms nominal Gain 6 dBi VSWR ≤ 2.0 Radiation Omni Polarization Vertical Mechanical Properties Antenna Height 16 in.(400 mm) Connector N (Female) Radome UV Resistant Fiberglass Mounting Base Zinc Alloy with Chrome Plated Color White Guided Pipe** Aluminum Alloy Bracket** Alluminum Alloy *Accepted mast diameter 1”~1.9” (25~49mm) **Guided Pipe and Bracket are shown on the drawing. NEARSON INC. 7432 Alban Station Blvd. B226, Springfield, VA 22150 Tel: (703)913-5552 Fax: (703)913-5553 Email: sales@nearson.com web: http://www.nearson.com All rights reserved. NEARSON INC. Specification is subject to change without notice. NEARSON SG102N-2450 2.4GHz Omni Directional Antenna Radiation Pattern NEARSON INC. 7432 Alban Station Blvd. B226, Springfield, VA 22150 Tel: (703)913-5552 Fax: (703)913-5553 Email: sales@nearson.com web: http://www.nearson.com All rights reserved. NEARSON INC. Specification is subject to change without notice.
SG102N-2450
PDF文档中包含了以下信息:
物料型号:STC8H2K60U 器件简介:该器件是一款高性能的8051单片机,适用于需要大容量程序存储和数据存储的应用。
引脚分配:该单片机具有40个引脚,包括电源引脚、地引脚、I/O引脚、定时器引脚等。
参数特性:工作电压范围为2.3V至5.5V,最大工作频率为35MHz,内置64K字节的Flash存储器和4K字节的RAM。
功能详解:该单片机支持ISP编程,具有看门狗定时器、外部中断、定时器等多种功能。
应用信息:适用于工业控制、智能家居、消费电子等领域。
封装信息:提供了LQFP44和TSSOP20两种封装方式。
SG102N-2450 价格&库存
很抱歉,暂时无法提供与“SG102N-2450”相匹配的价格&库存,您可以联系我们找货
