RM1xx
Dipole Antenna
A
863-928 MHz, Coaxial Cable to u.FL Connector
ORDERING INFORMATION
Laird Part #
Description
0600-00060
Dipole Antenna, 863 – 928MHz, coaxial cable to u.FL connector
SPECIFICATIONS
Specification
Value
Working Frequency Range
863 ~ 928 MHz (Note-1)
Gain
0.90 dBi
Return Loss
-10 dB (Max)
VSWR
2 max.
Polarization
Linear
Radiation Pattern
Omni-directional
Impedance
50
Antenna Cover
ABS, Black
Embedded Wireless Solutions Support
Center: http://ews-support.lairdtech.com
www.lairdtech.com/wireless
1
© Copyright 2016 Laird. All Rights
Reserved
Americas: +1-800-492-2320
Europe: +44-1628-858-940
Hong Kong: +852 2923 0610
RM1xx Dipole Antenna
Data Sheet
Specification
Value
Antenna Base
PC+PBT, Black
Cable
Coaxial Cableψ1.13,Black
PCB
FR4
Connector
IPEX Compatible
Note:
Central Frequency should be defined after customers’ application approval.
PHYSICAL DIMENSIONS
2
© Copyright 2016 Laird. All Rights Reserved
Data Sheet
TEST REPORT
Experimental Setup
RM1xx Antenna
Figure 1: Antenna test setup
Electrical Characteristics – Return Loss
Figure shows a ten dB return loss.
Figure 2: Ten dB Return Loss
3
Data Sheet
Antenna and Peak Gain
Figure 3: Maximum efficiency at 890 MHz: 57.30%
Figure 4: Maximum peak gain at 910 MHz: 0.90 dBi
4
Data Sheet
Radiation Pattern
ZY Plane
ZX Plane
Phi = 90.00 degrees (Gain in dB)
Phi = 0.00 degrees (Gain in dB)
XY Plane
Theta = 90.00 degrees (Gain in dB)
Freq.
(MHz)
860
890
930
Note:
ZX Plane
Max
Ave
(dB)
(dB)
0.36
-2.77
0.12
-2.72
-0.09
-2.80
ZY Plane
Max
Ave
(dB)
(dB)
0.07
-2.15
-0.11
-1.80
0.21
-1.95
XY Plane
Max
Ave
(dB)
(dB)
-0.73
-2.36
-0.21
-2.08
-0.47
-2.22
This antenna is not manufactured by Laird. It is manufactured by Walsin, one of our
suppliers. All test data and specifications are provided by Walsin.
5
Data Sheet
REVISION HISTORY
Version
1.0
Date
TBD
Notes
Initial Release
Approver
Jonathan Kaye
© Copyright 2016 Laird. All Rights Reserved. Patent pending. Any information furnished by Laird and its agents is believed to be accurate and reliable. All
specifications are subject to change without notice. Responsibility for the use and application of Laird materials or products rests with the end user since
Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to non-infringement nor as to the fitness, merchantability, or
sustainability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc., or any of its affiliates or agents shall not be
liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of Sale in effect from
time to time, a copy of which will be furnished upon request. When used as a tradename herein, Laird means Laird PLC or one or more subsidiaries of Laird
PLC. Laird™, Laird Technologies™, corresponding logos, and other marks are trademarks or registered trademarks of Laird. Other marks may be the
property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property right.
6
很抱歉,暂时无法提供与“0600-00060”相匹配的价格&库存,您可以联系我们找货
