ECHO30/0.1M/IPEX/S/S/26 数据手册
Echo 30
T-Shaped Embedded 2G & 3G PCB Antenna
Key Features
• Dipole design
• Quad band GSM & 3G
• 2dBi Peak Gain
General Description
Additional Considerations
The Echo 30 is a quad band 2G & 3G
tuned dipole PCB antenna that does not
rely upon a ground plane for half of the
waveform. The design is easily integrated
into projects with the small size and
simplicity of placement.
• Small footprint
• Ground plane independent
• Meets all EU compliance criteria for electronic goods
The wide frequency band allows for
worldwide cellular applications over the
quad band 2G/GPRS networks and also
high data transfer rates via 3G/UMTS.
Supplied as standard with a short length
of cable and an IPEX/uFL connector.
Alternative cable lengths and connectors
may be specified for volume orders.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.4
Echo 30
Electrical Specifications
Mechanical Specifications
Impedance:
50 Ohm
Peak Gain:
Frequency Range:
2dBi
824 ~ 960MHz
1920 - 2170MHz
Polarization:
Linear
Dimensions:
L40 x W6.7 x H1.0mm
Cable:
1.13mm Coax
Connector:
IPEX
Mounting Method:
Adhesive
Environmental Specifications
Operating
Temperature:
Relative humidity:
-40 - +85°C
Up to 95%
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.4
Echo 30
VSWR
Radiation Pattern
Horizontal Plane
Vertical Plane
824MHz
880MHz
960MHz
1920MHz
1990MHz
2170MHz
Ordering Details:
Part number
Description
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9014
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.4
ECHO30/0.1M/IPEX/S/S/26 价格&库存
很抱歉,暂时无法提供与“ECHO30/0.1M/IPEX/S/S/26”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.907191+12.33763
- 10+82.3527210+10.70559
- 25+78.0076225+10.14074
- 100+72.04176100+9.36520
- 300+67.78948300+8.81242
- 500+65.94549500+8.57270
- 1000+63.570281000+8.26393
