DELTA7A/X/SMAM/RP/S/11
    SIRETTA
    Delta 7A 是一款双频段WiFi天线,支持2.4GHz和5.8GHz频段,具有5dBi峰值增益。
DELTA7A/X/SMAM/RP/S/11 数据手册
Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Key Features • Supports 5G NR / 4G LTE • Supports Dual-Band WiFi full 2.4 GHz & 5 GHz spectrum • Supports Bluetooth and BLE, Zigbee, ISM 2.4 GHz, ISM 5.8 GHz & IEEE 802.15.4 bands • Hinged Mount • Omni-Directional General Description Additional Considerations The Delta 7A is primarily designed as a dual band WiFi antenna, tuned to the 2.4 GHz and 5 GHz bands. It also supports some of the 5G NR and 4G LTE Cellular bands. The hinged joint provides a flexible means of setting the antenna into the optimum position for WiFi transmission. • Adjustable mounting allows positioning for signal optimization • Dual band flexibility – choose least congested network • Meets all EU compliance criteria for electronic goods The Delta 7A supports WiFi, Bluetooth, Zigbee and ISM based applications and can be used with most modern-day WiFi modems that operate on the traditional 2.4 GHz and extended 5 GHz bands. The table for 4G and 5G bands lists the supported frequency bands for LTE. The Delta 7A is supplied, as standard, with either an SMA male or a reverse polarity SMA male connector. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 976 9000 sales@siretta.com www.siretta.com Rev 2.4 1 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Electrical Specifications Impedance: 50 Ohms Polarization: Vertical Max Input Power: 5W Ground plane independent Yes Environmental Specifications Operating Temperature range: -20 to +65 °C Storage Temperature range: -30 to +75 °C Mechanical Specifications Dimensions: Weight: Connector: L108 x 10 mm Ø 8.8 g SMA male / reverse polarity SMA male Mounting method: Direct connect Housing materials: TPEE Z Y X orientation Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 2 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Spectrum Coverage Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 3 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Usable Cellular Frequency Support (410 MHz – 1900 MHz) 410 450 600 700 800 850 900 1500 1600 1700 1800 1900 GSM Bands: UMTS Bands: LTE Bands: LTE Cat M Bands: LTE Cat NB Bands: 5G NR Bands: NR Cat NB Bands: Usable Cellular Frequency Support (2000 MHz – 5900 MHz) 2000 2100 2300 2400 2500 2600 3300 3500 3700 4700 5200 5900 GSM Bands: UMTS Bands: LTE Bands: LTE Cat M Bands: LTE Cat NB Bands: 5G NR Bands: NR Cat NB Bands: Usable ISM Frequency Support (433 MHz - 5800 MHz) 433 868 915 2450 5800 Bluetooth IEEE 802.15.4 LoRa Sigfox WiFi 2.4G WiFi 5G Zigbee Z-Wave Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 4 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Peak Gain vs. Frequency Peak Gain From Highest Direction (dBi) 10.00 5.00 0.00 dBi -5.00 -10.00 -15.00 -20.00 0 1000 2000 3000 4000 5000 6000 MHz Return Loss Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 4000 5000 6000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 5 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA VSWR VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 6 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Cat M E-UTRA Band Cat NB E-UTRA Band NR (5G) Band Cat NB NR (5G) Band Uplink Downlink Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 1 1 1 n1 n1 1920 - 1980 MHz 2110 - 2170 MHz 42.24 66.37 5.10 4.13 PCS-1900 2 2 2 2 n2 n2 1850 - 1910 MHz 1930 - 1990 MHz 40.90 42.92 3.90 5.50 DCS-1800 3 3 3 3 n3 n3 1710 - 1785 MHz 1805 - 1880 MHz 23.76 37.94 4.53 4.36 4 4 4 4 1710 - 1755 MHz 2110 - 2155 MHz 22.11 66.13 4.53 4.13 5 5 5 5 824 - 849 MHz 869 - 894 MHz 23.51 19.10 8.11 6.23 830 - 840 MHz 875 - 885 MHz 23.78 19.00 8.11 5.73 GSM-850 n5 n5 6 E-GSM-900 7 7 7 7 n7 n7 2500 - 2570 MHz 2620 - 2690 MHz 66.59 71.02 1.36 1.53 8 8 8 8 n8 n8 880 - 915 MHz 925 - 960 MHz 19.40 22.26 5.65 7.28 9 9 1749.9 - 1784.9 MHz 1844.9 - 1879.9 MHz 25.91 39.66 4.27 3.97 10 10 1710 - 1770 MHz 2110 - 2170 MHz 22.81 66.37 4.53 4.13 11 11 11 11 1427.9 - 1447.9 MHz 1475.9 - 1495.9 MHz 8.28 10.82 12.24 9.75 12 12 12 12 n12 n12 699 - 716 MHz 729 - 746 MHz 22.50 21.28 4.36 7.01 13 13 13 13 n13 n13 777 - 787 MHz 746 - 756 MHz 23.62 21.25 5.99 6.99 14 14 14 14 n14 788 - 798 MHz 758 - 768 MHz 24.61 21.71 6.50 6.60 704 - 716 MHz 734 - 746 MHz 22.42 21.18 4.36 7.01 815 - 830 MHz 860 - 875 MHz 24.83 19.48 8.02 7.03 830 - 845 MHz 875 - 890 MHz 23.48 19.02 8.11 5.73 832 - 862 MHz 791 - 821 MHz 22.02 25.07 8.11 7.76 1447.9 - 1462.9 MHz 1495.9 - 1510.9 MHz 8.69 12.44 11.46 8.20 3410 - 3490 MHz 3510 - 3590 MHz 50.41 48.89 4.01 4.00 1626.5 - 1660.5 MHz 1525 - 1559 MHz 19.68 16.29 7.70 7.92 1850 - 1915 MHz 1930 - 1995 MHz 40.94 43.14 3.90 5.67 814 - 849 MHz 859 - 894 MHz 23.95 19.26 8.11 7.08 807 - 824 MHz 852 - 869 MHz 25.10 20.04 7.83 7.41 703 - 748 MHz 758 - 803 MHz 21.80 23.41 7.01 6.80 17 17 18 18 18 19 19 19 19 20 20 20 20 21 21 21 21 22 22 n18 n20 24 24 24 n24 25 25 25 25 n25 26 26 26 26 n26 27 27 28 28 28 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition n28 n18 n20 n25 n28 Adequate band in good signal conditions Use Indicator E-UTRA (4G) Band 1 GSM (2G) Band UMTS (3G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 7 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 758 - 788 MHz 22.10 22.71 5.92 6.60 n29 N/A 717 - 728 MHz N/A 21.95 N/A 5.43 30 n30 2305 - 2315 MHz 2350 - 2360 MHz 62.52 62.57 1.22 1.12 452.5 - 457.5 MHz 462.5 - 467.5 MHz 5.81 6.36 26.77 23.02 32 N/A 1452 - 1496 MHz N/A 9.92 N/A 11.23 33 1900 - 1920 MHz 1900 - 1920 MHz 41.50 41.50 3.16 3.16 2010 - 2025 MHz 2010 - 2025 MHz 49.61 49.61 6.34 6.34 35 1850 - 1910 MHz 1850 - 1910 MHz 40.90 40.90 3.90 3.90 36 1930 - 1990 MHz 1930 - 1990 MHz 42.92 42.92 5.50 5.50 37 1910 - 1930 MHz 1910 - 1930 MHz 41.14 41.14 3.36 3.36 n38 2570 - 2620 MHz 2570 - 2620 MHz 69.04 69.04 1.49 1.49 n39 1880 - 1920 MHz 1880 - 1920 MHz 41.81 41.81 3.37 3.37 2300 - 2400 MHz 2300 - 2400 MHz 63.81 63.81 1.25 1.25 2496 - 2690 MHz 2496 - 2690 MHz 68.70 68.70 1.53 1.53 31 31 34 n34 38 39 39 40 40 41 41 41 42 42 42 3400 - 3600 MHz 3400 - 3600 MHz 49.69 49.69 4.02 4.02 43 43 43 3600 - 3800 MHz 3600 - 3800 MHz 53.49 53.49 3.78 3.78 44 703 - 803 MHz 703 - 803 MHz 22.47 22.47 7.01 7.01 45 1447 - 1467 MHz 1447 - 1467 MHz 8.78 8.78 11.51 11.51 n40 n41 n41 46 n46 5150 - 5925 MHz 5150 - 5925 MHz 63.86 63.86 1.83 1.83 47 n47 5855 - 5925 MHz 5855 - 5925 MHz 61.89 61.89 1.24 1.24 48 n48 3550 - 3700 MHz 3550 - 3700 MHz 53.75 53.75 3.87 3.87 3550 - 3700 MHz 3550 - 3700 MHz 53.75 53.75 3.87 3.87 49 50 n50 1432 - 1517 MHz 1432 - 1517 MHz 10.27 10.27 12.08 12.08 51 n51 1427 - 1432 MHz 1427 - 1432 MHz 8.04 8.04 12.29 12.29 3300 - 3400 MHz 3300 - 3400 MHz 47.57 47.57 3.92 3.92 52 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Use Indicator Average Upload Efficiency (%) 703 - 733 MHz 29 31 32 Downlink 28A Uplink Cat NB NR (5G) Band NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 8 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 65 Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 2483.5 - 2495 MHz 2483.5 - 2495 MHz 60.90 60.90 1.39 1.39 65 n65 n65 1920 - 2010 MHz 2110 - 2200 MHz 43.52 66.43 6.07 4.13 66 n66 n66 1710 - 1780 MHz 2110 - 2200 MHz 23.41 66.43 4.53 4.13 N/A 738 - 758 MHz N/A 21.21 N/A 7.01 68 698 - 728 MHz 753 - 783 MHz 22.30 22.28 5.43 6.79 69 N/A 2570 - 2620 MHz N/A 69.04 N/A 1.49 1695 - 1710 MHz 1995 - 2020 MHz 19.60 47.71 4.95 6.28 663 - 698 MHz 617 - 652 MHz 24.73 24.17 7.90 15.63 66 66 67 n67 70 70 n70 n71 n70 71 71 71 72 72 72 451 - 456 MHz 461 - 466 MHz 5.73 6.28 27.11 23.83 73 73 73 450 - 455 MHz 460 - 465 MHz 5.67 6.22 27.34 24.36 74 74 74 n74 1427 - 1470 MHz 1475 - 1518 MHz 8.58 11.86 12.29 9.82 75 n75 N/A 1432 - 1517 MHz N/A 10.27 N/A 12.08 76 n76 N/A 1427 - 1432 MHz N/A 8.04 N/A 12.29 n77 3300 - 4200 MHz 3300 - 4200 MHz 54.22 54.22 4.02 4.02 n78 3300 - 3800 MHz 3300 - 3800 MHz 50.78 50.78 4.02 4.02 n79 4400 - 5000 MHz 4400 - 5000 MHz 52.42 52.42 2.63 2.63 n80 1710 - 1785 MHz N/A 23.76 N/A 4.53 N/A n81 880 - 915 MHz N/A 19.40 N/A 5.65 N/A n82 832 - 862 MHz N/A 22.02 N/A 8.11 N/A n83 703 - 748 MHz N/A 21.80 N/A 7.01 N/A n84 1920 - 1980 MHz N/A 42.24 N/A 5.10 N/A n85 698 - 716 MHz 728 - 746 MHz 22.52 21.30 4.36 7.01 n86 1710 - 1780 MHz N/A 23.41 N/A 4.53 N/A 85 85 85 87 87 87 410 - 415 MHz 420 - 425 MHz 5.55 5.10 40.52 36.76 88 88 88 412 - 417 MHz 422 - 427 MHz 5.44 5.09 39.18 36.76 Suitable band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Adequate band in good signal conditions Use Indicator Downlink Cat NB NR (5G) Band n53 Uplink 53 NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 9 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA Downlink Average Upload Efficiency (%) Average Download Efficiency (%) Maximum Upload VSWR Maximum Download VSWR 23.51 N/A 8.11 N/A 2496 - 2690 MHz 2496 - 2690 MHz 68.70 68.70 1.53 1.53 n91 832 - 862 MHz 1427 - 1432 MHz 22.02 8.04 8.11 12.29 n92 832 - 862 MHz 1432 - 1517 MHz 22.02 10.27 8.11 12.08 n93 880 - 915 MHz 1427 - 1432 MHz 19.40 8.04 5.65 12.29 n94 880 - 915 MHz 1432 - 1517 MHz 19.40 10.27 5.65 12.08 n95 2010 - 2025 MHz N/A 49.61 N/A 6.34 N/A n97 2300 - 2400 MHz N/A 63.81 N/A 1.25 N/A n98 1880 - 1920 MHz N/A 41.81 N/A 3.37 N/A n99 1626.5 - 1660.5 MHz N/A 19.68 N/A 7.70 N/A n101 1900 - 1910 MHz 1900 - 1910 MHz 41.84 41.84 3.10 3.10 787 - 788 MHz 757 - 758 MHz 24.11 21.34 6.01 6.64 n89 n90 103 Suitable band n90 Adequate band in good signal conditions Use Indicator Uplink N/A Cat NB NR (5G) Band 824 - 849 MHz NR (5G) Band Cat NB E-UTRA Band Cat M E-UTRA Band E-UTRA (4G) Band UMTS (3G) Band GSM (2G) Band Cellular Standards Band Support Likely to be unsuitable NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective. The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end user is advised to use their own criteria and/or testing to confirm suitability. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 10 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA ISM Standards Frequency Support Application Frequency Range Efficiency (%) Maximum VSWR Peak Gain from highest direction (dBi) ISM 433 MHz 433.05 - 434.79 MHz 5.03 34.72 -7.953 IMT 868 MHz 863 - 870 MHz 19.53 6.80 -0.1595 ISM 915 MHz 902 - 928 MHz 20.32 5.82 1.656 ISM 2.4 GHz 2400 - 2500 MHz 65.05 1.41 7.95 WiFi 2.4G 2401 - 2483 MHz 65.92 1.41 7.928 WiFi 2.4G (USA) 2401 - 2473 MHz 66.55 1.41 7.928 WiFi 2.4G (Japan) 2401 - 2495 MHz 65.28 1.41 7.928 WiFi 5G (all channels) 5150 - 5990 MHz 63.20 1.83 3.37 WiFi 5G (Ch 32-48) 5150 - 5250 MHz 68.02 1.54 2.75 WiFi 5G (Ch 32-64) 5150 - 5330 MHz 65.40 1.54 2.81 WiFi 5G (Ch 32-161) 5150 - 5815 MHz 63.76 1.83 3.37 WiFi 5G (Ch 32-173) 5150 - 5875 MHz 64.14 1.83 3.37 ISM 5.8 GHz 5725 - 5875 MHz 69.39 1.54 3.12 Suitable band Adequate band in good signal conditions Use Indicator Likley to be unsuitable NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective. The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end user is advised to use their own criteria and/or testing to confirm suitability. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 11 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 2D Radiation Plots 1900 MHz XY XZ YZ 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 12 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 2D Radiation Plots 2500 MHz XY XZ YZ 2600 MHz XY XZ YZ 3500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 13 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 2D Radiation Plots 3700 MHz XY XZ YZ 4700 MHz XY XZ YZ 5200 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 14 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 2D Radiation Plots 5500 MHz XY XZ YZ 5800 MHz XY XZ YZ 5900 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 15 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 3D Radiation Plots 1900 MHz 2300 MHz 2400 MHz 2500 MHz 2600 MHz 3500 MHz 3700 MHz 4700 MHz 5200 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 16 Delta 7A DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA 3D Radiation Plots 5500 MHz 5800 MHz 5900 MHz NOTE: All 3D radiation plots are shown with Theta = 45 and Phi = 45. Ordering Details: Part Number Description DELTA7A/x/SMAM/S/S/11 DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA SMA MALE DELTA7A/x/SMAM/RP/S/11 DUAL BAND WIFI / 5G / 4G / Bluetooth / Zigbee / ISM 2.4G & 5.8G HINGED ANTENNA REVERSE POLARITY SMA MALE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Download Latest Edition Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44 118 796 9000 sales@siretta.com www.siretta.com Rev 2.4 17
DELTA7A/X/SMAM/RP/S/11 价格&库存
很抱歉,暂时无法提供与“DELTA7A/X/SMAM/RP/S/11”相匹配的价格&库存,您可以联系我们找货
  • 1+61.91027
  • 10+57.61976
  • 50+51.84008
库存:321
