DELTA2C/X/SMAM/S/RA/23
    SIRETTA
DELTA2C/X/SMAM/S/RA/23 数据手册
Delta 2C 2G/GPRS Right Angle Stubby Antenna Key Features • Right angle mount • Groundplane independent • Compact size General Description Additional Considerations The Delta 2C antenna is an omni directional dipole antenna which is over moulded in black high grade rubber giving a rugged, stylish finish. • Fits to many popular 2G / GPRS terminal equipment • Does not rely on mounting on metallic surface • Meets all EU compliance criteria for electronic goods Terminated with an SMA male, it is ideally suited to applications requiring a simple, cable free set up such as Point of Sale, metering or alarm panels. Peak gain performance of 2dBi is excellent given the size of the antenna. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Delta 2C 2G/GPRS Right Angle Stubby Antenna Electrical Specifications Mechanical Specifications Operating temperature: -45 - +75°C Storage temperature: -45 - +75°C Impedance: 50 Ohm Gain: 2.15 dBi Max Power: Operating frequences: Polarization: Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Dimensions: L45 x W8mm Ø Connector: SMA Male Mounting method: Direct connect 50W 890-960MHz @
DELTA2C/X/SMAM/S/RA/23 价格&库存
很抱歉,暂时无法提供与“DELTA2C/X/SMAM/S/RA/23”相匹配的价格&库存,您可以联系我们找货
  • 1+75.51074
  • 10+71.15775
  • 50+64.04510
库存:103
