Meteor
Part No:
FW.95.B.SMA.M
Description:
ISM Band 915Mhz Flexible Whip Monopole Antenna SMA(M) Straight
Features:
External 915MHz Monopole Antenna
Designed for Outdoor Use
Over 60% high efficiency*
2.71dBi high peak gain*
Robust Inner Steel Core
Antenna Length: 226mm
SMA Type(M) Straight Connector
IP65 dust and water-resistant
*Tested on 30cm*30cm Ground Plane
RoHS Compliant
SPE-16-8-007/B/WY
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Patterns
7
5.
Mechanical Drawing
9
6.
Packaging
10
Changelog
11
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-16-8-007/B/WY
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The FW.95 is a flexible 915MHz whip antenna with a SMA type (M) connector for outdoor use. It features
excellent efficiency (>60%) and high peak gain (>2.71 dBi) at 915MHz on a 30x30 cm ground plane.
The antenna was developed for monitoring systems, such as weather monitoring, motion / vibration sensors,
and pollutants monitoring.
Introduction
The FW.95 has an excellent omni-directional radiation pattern, ensuring wide coverage. The antennas high
efficiency means that it allows your radio to consume less power than with a lower efficiency antenna when
transferring data. It also means a better signal strength and better sensitivity in areas of low signal levels. The
antenna performs at its best while attached to a ground plane with dimensions of at least 30x30 cm. For an
environment where there is no ground-plane available we recommend to use the terminal mount antenna
the TI.19 or the outdoor fiberglass omni antenna the OMB.915.
Introduction
Introduction
The FW.95 whip is made of a flexible inner steel core covered by PE so it is extremely resistant to abrasion
and maintains its original shape and RF performance even after shock. This rugged design and IP65 rating on
the housing ensure high reliability.
This antenna comes with SMA(M) connector as standard. Other custom variants can be provided subject to
NRE and MOQ. Contact your regional Taoglas office for details..
SPE-16-8-007/B/WY
www.taoglas.com
3
2.
Specifications
3.
915MHz
Antenna Characteristics2.ISM Band
Specifications
Center Frequency
902MHz
915MHz
Design Environment
3.
4.
Efficiency
3.
4.
62.07 %
60.60 %
64.46 %
2.71 dBi
3.75 dBi
Return loss
< -10 dB
VSWR
≤ 2:1
Antenna
Radiation Patterns3.Antenna
Impedance
Polarization
3.
On 30x30cm ground
Antenna
Characteristics2.30 dBi
Peak Gain
Characteristics2.
Radiation Pattern
50 Ω
Linear
Specifications
Omni-Directional
Input Power
2W
Tested Power
10 W
Specifications
Mechanical
Dimensions
Length 226 ± 6 mm
Base Diameter
16 ± 0.6 mm
Whip Diameter
Antenna
Characteristics
6.2 ± 0.6 mm
Casing
ABS
Connector
Weight
38 g
Antenna
Dust and Water Resistance
Characteristics
928MHz
IP65
Environmental
Temperature Range
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
4.
Antenna Radiation Patterns
4.
Antenna Radiation Patterns3.Antenna
Characteristics
4.
Characteristics2.
SPE-16-8-007/B/WY
Specifications
www.taoglas.com
4
3.
4.
3.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-16-8-007/B/WY
www.taoglas.com
5
3.3
Peak Gain
3.4
Average Gain
SPE-16-8-007/B/WY
www.taoglas.com
6
4.
4.
Radiation Patterns
4.1
4.
Test Setup
4.
4.
Y
X
Z
4.
4.
On 30x30 cm ground plane
4.
4.
SPE-16-8-007/B/WY
www.taoglas.com
7
4.2
3D and 2D Radiation Patterns (0n 30cm*30cm Ground Plane)
XZ Plane
X
Y
902MHz
XZ Plane
Z
X
915MHz
YZ Plane
Z
Y
928MHz
SPE-16-8-007/B/WY
www.taoglas.com
8
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
8.
6.
Packaging
Packaging5.
SPE-16-8-007/B/WY
Mechanical Drawing
www.taoglas.com
9
6.
Packaging
6.
Packaging5.
6.
7.
Mechanical Drawing
1 pcs FW.95.B.SMA.M per PE Bag
Bag Dimensions - 380*50mm
Weight - 38g
Packaging
Mechanical
Drawing
6.
6.
7.
7.
7.
7.
50 PE Bags per Large PE Bag
50 pcs FW.95.B.SMA.M per Large PE Bag
Large PE Bag Dimensions - 470*340mm
Weight – 2Kg
Packaging5.
Mechanical Drawing
Packaging
5 Large PE Bags per Carton
50 pcs FW.95.B.SMA.M per Carton
Carton Dimensions - 360*310*180mm
Weight - 10.5Kg
Application Note
Pallet Dimensions:
1200*1000*1350mm
63 Cartons Per Pallet
9 Cartons Per Layer
7 Layers
Mechanical
Drawing
6.
Packaging5.
SPE-16-8-007/B/WY
Mechanical Drawing
www.taoglas.com
10
Changelog for the datasheet
SPE-16-8-007 - FW.95.B.SMA.M
Revision: B
Date:
Changes:
Changes Made by:
2019-08-16
Updated to new format
Dan Cantwell
Previous Revisions
Revision: A (Original First Release)
Date:
Notes:
2015-12-01
Author:
Wayne Yang
SPE-16-8-007/B/WY
www.taoglas.com
11
www.taoglas.com
SPE-16-8-007/B/WY
© Taoglas
www.taoglas.com
12
很抱歉,暂时无法提供与“FW.95.B.SMA.M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+152.162041+19.77736
- 10+120.7070710+15.68898
- 25+112.8522625+14.66804
- 100+104.22021100+13.54609
- 300+99.40523300+12.92026
- 500+97.62457500+12.68882
