ALPHA10/2.5M/SMAM/S/S/20
    SIRETTA
ALPHA10/2.5M/SMAM/S/S/20 数据手册
Alpha 10 2.4GHz WiFi / Bluetooth Blade Antenna Key Features • Gain 2.6 to 3dBi • WiFi: 2400 - 2500MHz • Mounts on any non metallic surface General Description Additional Considerations The Alpha 10 is a slim, adhesive base WiFi 2.4GHz blade antenna. • Mounts discretely, good for covert use The Alpha 10 is tuned to operate within the 2.4GHz to 2.5GHz band, making this antenna perfect for WiFi, Bluetooth and Zigbee applications. • Meets all EU compliance criteria for electronic goods • Intended for internal to equipment use The Alpha 10 achieves a reputable peak gain of 3.03dBi, helping to improve the short range signal transmission/reception of WiFi modems, Bluetooth gadgets or low power ZigBee sensors. Custom cable lengths and alternative connector types can be supplied for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.8 Alpha 10 2.4GHz WiFi / Bluetooth Blade Antenna Electrical Specifications Operating Temp Range: Mechanical Specifications -40 - 85°C Impedance: 50 Ohm Peak Gain: 3.03dBi VSWR: Max Input Power: Frequency: Polarization: Dimensions: L115 x W22 x 4mm Cable: RG174 Mounting Method: Adhesive ≤1.5.1 50W 2400 - 2500MHz Vertical 116mm 21.5mm RG174 4mm Return Loss Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.8 Alpha 10 2.4GHz WiFi / Bluetooth Blade Antenna VSWR Ordering Details Part Number Description ALPHA10/2.5M/SMAM/S/S/20 2.4GHz WiFi / Bluetooth Blade Antenna 2.5M SMA Male Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.8
ALPHA10/2.5M/SMAM/S/S/20 价格&库存
很抱歉,暂时无法提供与“ALPHA10/2.5M/SMAM/S/S/20”相匹配的价格&库存,您可以联系我们找货
  • 1+130.460081+16.91011
  • 10+102.9409210+13.34311
  • 25+96.0737825+12.45299
  • 100+88.52734100+11.47483
  • 250+84.93000250+11.00855
  • 500+82.76154500+10.72747
  • 1000+80.977061000+10.49617
库存:11
  • 1+89.92349
  • 5+83.63353
库存:254
