DELTA40/X/SMAM/S/S/32
    SIRETTA
DELTA40/X/SMAM/S/S/32 数据手册
Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Key Features • • • • 2G/3G/4G Some 5G band coverage WiFi, Bluetooth and Zigbee Flat Panel Swivel Knuckle Design General Description Additional Considerations The Delta 40 direct connect antenna is tuned for wide band reception/ transmission. • Swivel knuckle allows positioning for best signal reception. • Meets EU compliance criteria for electronic goods Suitable for a host of applications from cellular 2G/3G/4G/(5G) or the 2.4MHz band for WiFi/ISM/Zigbee or Bluetooth. Now with the addition of some 5G bands. The swivel knuckle design is ideal for mounting on IoT modems/routers where the antenna can be positioned for best reception. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Electrical Specifications Impedance: Mechanical Specifications 50 Ohm Radiation: Weight: Omni Polarization: Connector: Vertical Ground Plane Independent: Yes Max Input Power: 5W 29g SMA Male Body Material: PU/PC Dimensions: 161 mm x 21.3 mm Environmental Specification Operating Temperature: -20 - +65 °C Z X Y orientation Return Loss Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 4000 5000 6000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA VSWR VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA LTE/5G Band Coverage M/5G Bands NB-IoT Band 1/n1 B1 2/n2 3/n3 LTE, CAT- Avg Efficieny % over band Max VSWR over Band Uplink Downlink Europe / Asia 1920-1980 MHz 2110-2170 MHz 88.79 / 82.16 1.62 / 1.88 B2 North America/Latin America/Caribbean 1850-1910 MHz 1930-1990 MHz 72.57 / 91.24 1.93 / 1.59 B3 Europe/Africa/Asia/Oceania 1710-1785 MHz 1805-1880 MHz 69.85 / 65.66 2.19 / 2.08 4 B4 North America/Latin America/Caribbean 1710-1755 MHz 2110-2155 MHz 72.73 / 82.61 2.19 / 1.79 5/n5 B5 Country Specific 824-849 MHz 869-894 MHz 64.03 / 57.40 1.42 / 1.39 7/n7 Regional Coverage 2500-2570 MHz 2620-2690 MHz 47.98 / 59.82 8/n8 B8 Latin America/Europe/Asia + Europe / Asia + 880-915 MHz 925-960 MHz 53.43 / 39.60 2.56 / 1.92 x 1.91 / 2.34 x 11.83 / 6.54 11 B11 Country Specific 1427.9-1447.9 MHz 1475.9-1495.9 MHz 21.01 / 32.57 12/n12 B12 North America/Caribbean + 699-716 MHz 729-746 MHz 20.85 / 38.39 5.87 / 4.53 13/n13 B13 North America/Caribbean + 777-787 MHz 746-756 MHz 48.65 / 43.45 1.64 / 4.04 14/n14 B14 Country Specific 788-798 MHz 758-768 MHz 47.80 / 49.38 2.11 / 3.06 x 17 B17 North America/Caribbean + 704-716 MHz 734.746 MHz 24.24 / 38.39 18/n18 B18 Country Specific 815-830 MHz 860-875 MHz 54.49 / 59.92 1.43 / 1.45 19 B19 Country Specific 830-845 MHz 875-890 MHz 64.03 / 57.40 1.35 / 1.27 20/n20 B20 Europe/Africa + 832-862 MHz 791-821 MHz 62.24 / 56.18 1.47 / 2.11 Country Specific 1447.9-1462.9 MHz 1495.9-1510.9 MHz 22.94 / 44.58 25/n25 21 B25 Country Specific 1850-1915 MHz 1525-1559 MHz 72.57 / 63.81 26/n26 B26 Country Specific 814-849 MHz 859-894 MHz 56.61 / 59.95 28/n28 B28 29/n29 B31 32 6.01 / 3.03 1.93 / 2.07 1.69 / 1.47 703-748 MHz 758-803 MHz 38.39 / 48.80 x - 717-728 MHz 28.35 x Country Specific 30/n30 31 Latin America/Europe/Asia + x 10.91 / 5.89 10.91 / 3.06 8.16 Country Specific 2305-2315 MHz 2350-2360 MHz 41.17 / 36.72 Country Specific 452.5-457.5 MHz 462.5-467.5 MHz 6.14 / 3.90 x 35.0 / 34.9 28.87 x 6.01 Country Specific - 1452-1496 MHz 3.62 / 4.38 38/n38 Europe + 2570-2620 MHz 40.58 2.57 39/n39 Country Specific 1880-1920 MHz 77.66 1.76 40/n40 Asia + 2300-2400 MHz 38.86 4.38 41/n41 Country Specific 2496-2690 MHz 52.79 42 Country Specific 3400-3600 MHz 30.59 43 Country Specific 3600-3800 MHz 60.51 46/n46 Country Specific 5150-5925 MHz 25.89 48/n48 Country Specific 3550-3700 MHz 48.00 65/n65 66/n66 71/n71 B66 B71 2.57 x 3.70 x 1920-2010 MHz 2110-2200 MHz 92.58 / 79.97 Country Specific 1710-1780 MHz 2110-2200 MHz 71.46 / 79.97 663-698 MHz 617-652 MHz 8.95 4.72 Country Specific Country Specific 8.59 14.60 / 5.91 1.62 / 2.15 2.19 / 2.15 x 17.89 / 22.7 Table data for bands as detailed in 3GPP TS 36.101 & 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA 5G Extended Table for Band Coverage LTE/5G Band NB-IoT Band n24 Uplink Downlink 1626.5 – 1660.5 MHz 1525 – 1559 MHz Max VSWR over Band Avg Efficieny % over band 75.99 / 63.81 1.52 / 2.07 n34 2010 – 2025 MHz 98.10 n47 5855 – 5925 MHz 15.62 x 8.04 n50 1432 – 1517 MHz 32.79 x 6.01 n51 1427 – 1432 MHz 21.98 4.49 n53 2483.5 – 2495 MHz 56.84 1.88 n67 738 – 758 MHz 38.39 5.33 n70 B70 n74 1.15 1695 – 1710 MHz 1995 – 2020 MHz 75.06 / 95.16 1427 – 1470 MHz 1475 – 1518 MHz 23.75 / 38.20 x 6.01 / 4.53 x 6.01 1.98 / 1.24 n75 1432 – 1517 MHz 32.79 n76 1427 – 1432 MHz 21.98 n77 3300 – 4200 MHz 46.06 x 11.29 n78 3300 – 3800 MHz 40.31 x 11.29 n79 4400 – 5000 MHz 27.00 x 11.49 n80 1710 – 1785 MHz 69.85 2.19 n81 880 – 915 MHz 53.43 1.91 n82 832 – 862 MHz 62.24 n83 703 – 748 MHz 33.85 1920 – 1980 MHz 89.79 n84 n85 B85 n86 698 – 716 MHz 728 – 746 MHz 4.49 1.47 x 10.91 1.62 x 20.85 / 38.39 11.83 / 6.54 1710 – 1780 MHz 71.46 2.19 n89 824 – 849 MHz 64.03 1.42 n90 2496 – 2690 MHz 52.79 2.57 n91 832 – 862 MHz 1427 – 1432 MHz 62.24 / 21.98 1.47 / 4.49 n92 832 – 862 MHz 1432 – 1517 MHz 62.24 / 32.79 1.47 / 6.01 n93 880 – 915 MHz 1427 – 1432 MHz 53.43 / 21.98 1.91 / 4.49 n94 880 – 915 MHz 1432 – 1517 MHz 53.43 / 32.79 1.91 / 6.01 n95 2010 – 2025 MHz n96 5925 – 7125 MHz 98.10 n97 2300 – 2400 MHz 38.86 4.38 n98 1880 – 1920 MHz 77.66 1.76 n99 1626.5 – 1660.5 MHz 75.99 1.52 1.15 unmeasured Table data for bands as detailed in 3GPP TS 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 740 MHz XY XZ YZ 800 MHz XY XZ YZ 900 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 1400 MHz XY XZ YZ 1500 MHz XY XZ YZ 1600 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 1700 MHz XY XZ YZ 1800 MHz XY XZ YZ 1900 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 2000 MHz XY XZ YZ 2100 MHz XY XZ YZ 2200 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 38.64 Eff % 38.64 2500 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 58.48 Eff % 58.48 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 2600 MHz XY XZ YZ 2700 MHz XY XZ YZ 3500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA Radiation Plots 3600 MHz XY XZ YZ 3700 MHz XY XZ YZ 3800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 740 MHz 800 MHz 900 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 1400 MHz 1500 MHz 1600 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 1700 MHz 1800 MHz 1900 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 2000 MHz Theta 65 Phi 45 2300 MHz 2100 MHz Theta 65 Phi 45 2400 MHz 2200 MHz Theta 65 Phi 45 2500 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 2600 MHz 2700 MHz 3500 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Delta 40 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA 3D Radiation Plots 3600 MHz Theta 65 Phi 45 3700 MHz Theta 65 Phi 45 3800 MHz Theta 65 Phi 45 Ordering Details Part number Description DELTA40/X/SMAM/S/S/32 2G/3G/4G/(5G) & WIFI 161MM HINGED DIRECT CONNECT ANTENNA SMA MALE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0
DELTA40/X/SMAM/S/S/32 价格&库存
很抱歉,暂时无法提供与“DELTA40/X/SMAM/S/S/32”相匹配的价格&库存,您可以联系我们找货
  • 1+133.59912
  • 5+120.23817
库存:743
    • 1+214.660551+27.77208
    • 10+172.1959310+22.27814
    • 25+161.5815925+20.90490
    • 100+149.91476100+19.39548
    • 250+144.35303250+18.67592
    • 500+141.00161500+18.24233
    库存:33
