ECHO18/0.1M/UFL/S/S/15
    SIRETTA
ECHO18/0.1M/UFL/S/S/15 数据手册
Echo 18 WiFi / WLAN PCB Antenna Key Features • Compact size • 2.4 - 2.5GHz operation • WiFi, Bluetooth, Zigbee and ISM Band 2450MHz compatible General Description Additional Considerations The Echo 18 is a WiFi / WLAN dedicated PCB antenna tuned between 2.4 and 2.5GHz. Achieving a peak gain of 0.8dBi. • Small size allow easy integration into devices • Meets all EU compliance criteria for electronic goods It is suitable for applications where internal space for components is extremely limited or when using an external antenna is simply not appropriate. The small design allows this antenna to be simply fixed to the inside of an enclosure. Echo 18 is therefore suitable for a host of wireless IoT applications that require a space conscious embedded antenna solution. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Echo 18 WiFi / WLAN PCB Antenna Electrical Specifications Mechanical Specifications Operating Temperature range: -30 - +30°C Dimensions: L37 x W6 x H0.7mm (without cable) Storage Temperature: -35 - +75°C Cable Dimensions: 100 x 1.13mm Frequency Band: 2.4 GHz Impedance: 50 Ohm VSWR: Connector: UFL 2.0:1 Peak Gain: 0.8 dBi Polarization: Vertical Return Loss Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Echo 18 WiFi / WLAN PCB Antenna VSWR Smith Chart Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Echo 18 WiFi / WLAN PCB Antenna Simulated Radiation Pattern 2.4GHz H Plane E Plane 1 E Plane 2 Simulated Radiation Pattern 2.45GHz H Plane Registered in England No. 08405712 VAT Registration No. GB163 04 0349 E Plane 1 E Plane 2 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Echo 18 WiFi / WLAN PCB Antenna Simulated Radiation Pattern 2.5GHz H Plane E Plane 1 E Plane 2 Ordering Details Part Number Description ECHO18/0.1M/UFL/S/S/15 WiFi / WLAN PCB Antenna 100mm uFL Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5
物料型号:Echo 18
器件简介: - Echo 18是一款专为2.4至2.5GHz频段设计的WiFi / WLAN PCB天线。 - 该天线具有0.8dBi的峰值增益,适合在内部空间非常有限或使用外置天线不适宜的场合。 - 它的小巧设计允许天线简单地固定在外壳内部,适合多种需要空间节省的嵌入式无线IoT应用。
引脚分配:文档中未明确提及引脚分配信息。
参数特性: - 工作温度范围:-30°C至+85°C - 存储温度:-35°C至+75°C - 频率带宽:2.4GHz - 阻抗:50欧姆 - 电压驻波比(VSWR):2.0:1 - 峰值增益:0.8dBi - 极化方式:垂直
功能详解: - Echo 18天线易于集成到设备中,满足所有欧盟电子产品合规标准。
应用信息: - 适用于需要空间节省的嵌入式无线IoT应用。
封装信息: - 尺寸:L37 x W6xH0.7mm(不含电缆) - 电缆尺寸:100x1.13mm - 连接器类型:UFL
订购详情: - 部件编号:ECHO18/0.1M/UFL/S/S/15 - 描述:100mm uFL WiFi / WLAN PCB天线
ECHO18/0.1M/UFL/S/S/15 价格&库存
很抱歉,暂时无法提供与“ECHO18/0.1M/UFL/S/S/15”相匹配的价格&库存,您可以联系我们找货
  • 1+78.27040
  • 5+73.31342
库存:2
