DELTA6B/X/SMAM/RP/S/11
    SIRETTA
    Delta 6B 是一款单频段 WiFi 天线,调谐至 2.4-2.5GHz,峰值增益为 5dBi,提供卓越的天线性能,适用于更苛刻的 WiFi 应用。
DELTA6B/X/SMAM/RP/S/11 数据手册
Delta 6B WiFi / WLAN Hinged Antenna SMA Male Key Features • 5dBi gain • 2.4 - 2.5GHz frequency band • Adjustable Swivel design General Description Additional Considerations The Delta 6B is a single band WiFi antenna, tuned to 2.4 - 2.5GHz and with a peak gain of 5dBi, provides superior antenna performance suiting more demanding WiFi applications. • Adjustable design allow positioning for best signal • Suitable for WiFi, ISM Applications, Bluetooth and Zigbee • The antenna does not rely on mounting on a metallic surface • Meets EU compliance criteria for electronic goods The hinged joint provides a flexible position at 0, 45 & 90 degrees for optimum signal transmission. The Delta 6B is commonly used with WiFi, Bluetooth, and Zigbee based applications to help improve the signal strength and connectivity of short-range terminals. The Delta 6B is supplied, as standard, with either an SMA male or a reverse polarity SMA male connector (the latter being the common connector type for WiFi modems). Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.6 Delta 6B WiFi / WLAN Hinged Antenna SMA Male Electrical Specifications Mechanical Specifications Operating Temperature: -20 - +65°C Storage Temperature: -30 - +75°C Impedance: Gain: VSWR: Frequency Range: Antenna Type: Polarization: Return Loss Registered in England No. 08405712 VAT Registration No. GB163 04 0349 50 Ohm Dimensions: L196 x 13 mm Ø Connector: SMA/SMA-RP Male Cable: RG316 (Internal) Mounting Method: Direct Connect 5dBi
DELTA6B/X/SMAM/RP/S/11 价格&库存
很抱歉,暂时无法提供与“DELTA6B/X/SMAM/RP/S/11”相匹配的价格&库存,您可以联系我们找货
  • 1+92.52695
  • 5+89.74645
库存:72
  • 1+147.845961+19.12783
  • 10+117.2073110+15.16390
  • 25+109.5405025+14.17199
  • 100+101.11652100+13.08212
  • 250+97.10082250+12.56259
  • 500+94.68025500+12.24942
库存:92
