DELTA6C/X/SMAM/S/S/11 数据手册
Delta 6C
5G/4G/3G/Dual band WiFi/Bluetooth/Zigbee Antenna
Key Features
Supports 5G NR / 4G LTE / 3G UMTS
Supports LTE Cat M, LTE Cat NB & NR Cat NB
Supports Dual Band WiFi 4/5/6
Supports Bluetooth / Zigbee / ISM 2.4 GHz / WLAN2400 /
IEEE 802.15.4 Bands
• Supports ISM 5.8 GHz / WLAN5800 Bands
• Adjustable antenna position
• Omni-directional Compact Antenna
General Description
Additional Considerations
The Delta 6C antenna has excellent
performance in the 2.4 GHz and 5.8 GHz
WLAN bands.
• Fits to many popular terminals
Terminated with an SMA or SMA-RP
male connector, the knuckle adjusts
through 0°, 45° & 90° angles and swivels
360° to enable the best signal to be
obtained.
• Meets EU compliance criteria for electronic goods
• The antenna does not rely on mounting on a metallic
surface
The Delta 6C is a popular antenna
compatible with the 802.11a, 802.11b,
802.11g, 802.11n 802.11ac and
802.11ax WLAN standards. It also works
well on other wireless standards from
4G/5G cellular networks, Bluetooth,
Zigbee to ISM2450 applications.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Download Latest Edition
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 976 9000
sales@siretta.com
www.siretta.com
Rev 2.0
1
Delta 6C
Electrical Specifications
Impedance:
50 Ohm
Polarization:
Vertical
Max Input Power:
10 W
Ground plane independent:
Yes
Environmental Specifications
Operating Temperature range:
-20 to +65 °C
Storage Temperature range:
-30 to +75 °C
Mechanical Specifications
Dimensions:
Weight:
Connector:
L196 x 13 mm base diameter
25.6 g
SMA male / RP-SMA male
Mounting method:
Direct Connect
Housing materials:
TPEE
Z
X
Y
orientation
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
2
Delta 6C
Spectrum Coverage
Suitable band
Adequate band in good signal conditions
Likely to be unsuitable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
3
Delta 6C
Usable Cellular Frequency Support (410 MHz – 1900 MHz)
410
450
600
700
800
850
900
1500
1600
1700
1800
1900
GSM Bands:
UMTS Bands:
LTE Bands:
LTE Cat M Bands:
LTE Cat NB Bands:
5G NR Bands:
NR Cat NB Bands:
Usable Cellular Frequency Support (2000 MHz – 5900 MHz)
2000
2100
2300
2400
2500
2600
3300
3500
3700
4700
5200
5900
GSM Bands:
UMTS Bands:
LTE Bands:
LTE Cat M Bands:
LTE Cat NB Bands:
5G NR Bands:
NR Cat NB Bands:
Usable ISM Frequency Support (433 MHz - 5800 MHz)
433
868
915
2450
5800
Bluetooth
IEEE 802.15.4
LoRa
Sigfox
WiFi 2.4G
WiFi 5G
Zigbee
Z-Wave
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
4
Delta 6C
Peak Gain vs. Frequency
Peak Gain From Highest Direction (dBi)
10.00
5.00
dBi
0.00
-5.00
-10.00
-15.00
-20.00
2000
3000
4000
5000
6000
4000
5000
6000
MHz
Return Loss
Return Loss in -dB
0.00
-2.00
-4.00
-6.00
-dB
-8.00
-10.00
-12.00
-14.00
-16.00
-18.00
-20.00
2000
3000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
5
Delta 6C
VSWR
VSWR
10.00
9.00
8.00
VSWR
7.00
6.00
5.00
4.00
3.00
2.00
1.00
2000
3000
4000
5000
6000
4000
5000
6000
MHz
Radiation Efficiency
Antenna Radiation Efficiency (in %)
110.00
100.00
90.00
80.00
% Efficiency
70.00
60.00
50.00
40.00
30.00
20.00
10.00
0.00
2000
3000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
6
Delta 6C
Cat M E-UTRA Band
Cat NB E-UTRA Band
NR (5G) Band
Cat NB NR (5G) Band
Uplink
Downlink
Average Upload Efficiency (%)
Average Download Efficiency (%)
Maximum Upload VSWR
Maximum Download VSWR
1
1
1
n1
n1
1920 - 1980 MHz
2110 - 2170 MHz
56.04
65.98
4.88
1.68
PCS-1900
2
2
2
2
n2
n2
1850 - 1910 MHz
1930 - 1990 MHz
43.75
56.86
6.05
4.77
DCS-1800
3
3
3
3
n3
n3
1710 - 1785 MHz
1805 - 1880 MHz
29.16
39.03
9.10
7.75
4
4
4
4
1710 - 1755 MHz
2110 - 2155 MHz
28.74
64.98
9.10
1.68
5
5
5
5
824 - 849 MHz
869 - 894 MHz
27.44
28.63
4.38
4.19
830 - 840 MHz
875 - 885 MHz
27.26
29.32
4.11
4.03
GSM-850
n5
n5
6
E-GSM-900
7
7
7
7
n7
n7
2500 - 2570 MHz
2620 - 2690 MHz
89.58
88.76
1.36
2.01
8
8
8
8
n8
n8
880 - 915 MHz
925 - 960 MHz
25.24
17.33
4.38
4.41
9
9
1749.9 - 1784.9 MHz
1844.9 - 1879.9 MHz
29.43
41.49
9.05
6.22
10
10
1710 - 1770 MHz
2110 - 2170 MHz
28.44
65.98
9.10
1.68
11
11
11
11
1427.9 - 1447.9 MHz
1475.9 - 1495.9 MHz
28.44
19.07
6.39
4.06
12
12
12
12
n12
n12
699 - 716 MHz
729 - 746 MHz
26.78
28.20
18.18
13.63
13
13
13
13
n13
n13
777 - 787 MHz
746 - 756 MHz
21.90
25.99
6.65
11.29
14
14
14
14
n14
788 - 798 MHz
758 - 768 MHz
23.40
23.54
5.89
8.91
704 - 716 MHz
734 - 746 MHz
26.99
28.17
17.35
13.12
815 - 830 MHz
860 - 875 MHz
26.80
29.65
4.68
4.03
830 - 845 MHz
875 - 890 MHz
27.41
28.79
4.11
4.15
832 - 862 MHz
791 - 821 MHz
28.28
25.10
4.05
5.77
1447.9 - 1462.9 MHz
1495.9 - 1510.9 MHz
23.55
18.87
5.41
4.36
3410 - 3490 MHz
3510 - 3590 MHz
57.45
63.38
3.65
3.69
1626.5 - 1660.5 MHz
1525 - 1559 MHz
30.38
18.68
7.03
6.65
1850 - 1915 MHz
1930 - 1995 MHz
44.25
57.10
6.05
4.77
814 - 849 MHz
859 - 894 MHz
27.20
28.92
4.74
4.19
807 - 824 MHz
852 - 869 MHz
26.22
29.44
5.02
3.97
703 - 748 MHz
758 - 803 MHz
27.70
23.00
17.54
8.91
17
17
18
18
18
19
19
19
19
21
21
21
22
22
n18
n20
24
24
24
n24
25
25
25
25
n25
26
26
26
26
n26
27
27
28
28
28
Suitable band
n28
n18
n20
n25
n28
Use Indicator
E-UTRA (4G) Band
1
GSM (2G) Band
UMTS (3G) Band
Cellular Standards Band Support
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
7
Delta 6C
Maximum Upload VSWR
758 - 788 MHz
27.54
22.61
17.54
8.91
n29
N/A
717 - 728 MHz
N/A
27.93
N/A
15.29
30
n30
2305 - 2315 MHz
2350 - 2360 MHz
70.70
70.72
2.18
2.11
452.5 - 457.5 MHz
462.5 - 467.5 MHz
4.56
5.41
18.90
21.44
32
N/A
1452 - 1496 MHz
N/A
20.56
N/A
5.18
33
1900 - 1920 MHz
1900 - 1920 MHz
49.27
49.27
5.15
5.15
2010 - 2025 MHz
2010 - 2025 MHz
62.74
62.74
3.07
3.07
35
1850 - 1910 MHz
1850 - 1910 MHz
43.75
43.75
6.05
6.05
36
1930 - 1990 MHz
1930 - 1990 MHz
56.86
56.86
4.77
4.77
37
1910 - 1930 MHz
1910 - 1930 MHz
52.28
52.28
5.00
5.00
n38
2570 - 2620 MHz
2570 - 2620 MHz
77.84
77.84
1.64
1.64
n39
1880 - 1920 MHz
1880 - 1920 MHz
47.03
47.03
5.47
5.47
2300 - 2400 MHz
2300 - 2400 MHz
70.59
70.59
2.19
2.19
2496 - 2690 MHz
2496 - 2690 MHz
86.19
86.19
2.01
2.01
31
31
34
n34
38
39
39
40
40
41
41
41
42
42
42
3400 - 3600 MHz
3400 - 3600 MHz
60.30
60.30
3.69
3.69
43
43
43
3600 - 3800 MHz
3600 - 3800 MHz
69.32
69.32
3.72
3.72
44
703 - 803 MHz
703 - 803 MHz
25.37
25.37
17.54
17.54
45
1447 - 1467 MHz
1447 - 1467 MHz
23.23
23.23
5.45
5.45
n40
n41
n41
46
n46
5150 - 5925 MHz
5150 - 5925 MHz
81.15
81.15
1.73
1.73
47
n47
5855 - 5925 MHz
5855 - 5925 MHz
73.60
73.60
1.61
1.61
48
n48
3550 - 3700 MHz
3550 - 3700 MHz
68.90
68.90
3.72
3.72
3550 - 3700 MHz
3550 - 3700 MHz
68.90
68.90
3.72
3.72
49
50
n50
1432 - 1517 MHz
1432 - 1517 MHz
21.72
21.72
6.20
6.20
51
n51
1427 - 1432 MHz
1427 - 1432 MHz
31.10
31.10
6.43
6.43
3300 - 3400 MHz
3300 - 3400 MHz
57.96
57.96
3.55
3.55
52
Suitable band
Use Indicator
703 - 733 MHz
29
31
32
Downlink
28A
Uplink
Cat NB NR (5G) Band
NR (5G) Band
Cat NB E-UTRA Band
Cat M E-UTRA Band
E-UTRA (4G) Band
UMTS (3G) Band
GSM (2G) Band
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
8
Delta 6C
65
Maximum Upload VSWR
2483.5 - 2495 MHz
2483.5 - 2495 MHz
81.06
81.06
1.47
1.47
65
n65
n65
1920 - 2010 MHz
2110 - 2200 MHz
57.44
66.07
4.88
1.68
66
n66
n66
1710 - 1780 MHz
2110 - 2200 MHz
28.87
66.07
9.10
1.68
N/A
738 - 758 MHz
N/A
26.67
N/A
12.62
68
698 - 728 MHz
753 - 783 MHz
27.21
23.05
18.27
9.82
69
N/A
2570 - 2620 MHz
N/A
77.84
N/A
1.64
1695 - 1710 MHz
1995 - 2020 MHz
30.07
61.97
8.68
3.47
663 - 698 MHz
617 - 652 MHz
27.01
19.49
18.64
14.48
66
66
67
n67
70
70
n70
n71
n70
71
71
71
72
72
72
451 - 456 MHz
461 - 466 MHz
4.47
5.24
18.33
21.44
73
73
73
450 - 455 MHz
460 - 465 MHz
4.41
5.13
17.94
21.44
74
74
74
n74
1427 - 1470 MHz
1475 - 1518 MHz
25.62
19.01
6.43
4.66
75
n75
N/A
1432 - 1517 MHz
N/A
21.72
N/A
6.20
76
n76
N/A
1427 - 1432 MHz
N/A
31.10
N/A
6.43
n77
3300 - 4200 MHz
3300 - 4200 MHz
63.58
63.58
3.72
3.72
n78
3300 - 3800 MHz
3300 - 3800 MHz
63.44
63.44
3.72
3.72
n79
4400 - 5000 MHz
4400 - 5000 MHz
76.29
76.29
2.79
2.79
n80
1710 - 1785 MHz
N/A
29.16
N/A
9.10
N/A
n81
880 - 915 MHz
N/A
25.24
N/A
4.38
N/A
n82
832 - 862 MHz
N/A
28.28
N/A
4.05
N/A
n83
703 - 748 MHz
N/A
27.70
N/A
17.54
N/A
n84
1920 - 1980 MHz
N/A
56.04
N/A
4.88
N/A
n85
698 - 716 MHz
728 - 746 MHz
26.75
28.20
18.27
13.76
n86
1710 - 1780 MHz
N/A
28.87
N/A
9.10
N/A
85
85
85
87
87
87
410 - 415 MHz
420 - 425 MHz
4.80
4.22
21.81
18.06
88
88
88
412 - 417 MHz
422 - 427 MHz
4.67
4.15
21.13
17.69
Suitable band
Use Indicator
Downlink
Cat NB NR (5G) Band
n53
Uplink
53
NR (5G) Band
Cat NB E-UTRA Band
Cat M E-UTRA Band
E-UTRA (4G) Band
UMTS (3G) Band
GSM (2G) Band
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
9
Delta 6C
Downlink
Maximum Upload VSWR
27.44
N/A
4.38
N/A
2496 - 2690 MHz
2496 - 2690 MHz
86.19
86.19
2.01
2.01
n91
832 - 862 MHz
1427 - 1432 MHz
28.28
31.10
4.05
6.43
n92
832 - 862 MHz
1432 - 1517 MHz
28.28
21.72
4.05
6.20
n93
880 - 915 MHz
1427 - 1432 MHz
25.24
31.10
4.38
6.43
n94
880 - 915 MHz
1432 - 1517 MHz
25.24
21.72
4.38
6.20
n95
2010 - 2025 MHz
N/A
62.74
N/A
3.07
N/A
n97
2300 - 2400 MHz
N/A
70.59
N/A
2.19
N/A
n98
1880 - 1920 MHz
N/A
47.03
N/A
5.47
N/A
n99
1626.5 - 1660.5 MHz
N/A
30.38
N/A
7.03
N/A
n101
1900 - 1910 MHz
1900 - 1910 MHz
47.54
47.54
5.15
5.15
787 - 788 MHz
757 - 758 MHz
22.59
24.47
5.95
9.08
n89
n90
103
Suitable band
n90
Use Indicator
Uplink
N/A
Cat NB NR (5G) Band
824 - 849 MHz
NR (5G) Band
Cat NB E-UTRA Band
Cat M E-UTRA Band
E-UTRA (4G) Band
UMTS (3G) Band
GSM (2G) Band
NOTE: For each frequency band, Siretta provides a traffic light indication to show the suitability of the antenna for use at that
frequency band. Determination of exactly what makes an antenna good or bad at any frequency is subjective.
The view presented is that of Siretta’s engineering team having taken into account the efficiency and VSWR measurements. The end
user is advised to use their own criteria and/or testing to confirm suitability.
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
10
Delta 6C
ISM Standards Frequency Support
Application
Frequency Range
Efficiency (%)
Maximum VSWR
Peak Gain from highest direction (dBi)
ISM 433 MHz
433.05 - 434.79 MHz
3.86
16.96
-8.604
IMT 868 MHz
863 - 870 MHz
29.65
3.98
0.68
ISM 915 MHz
902 - 928 MHz
21.18
4.40
-0.11
ISM 2.4 GHz
2400 - 2500 MHz
74.55
1.91
8.23
WiFi 2.4G
2401 - 2483 MHz
73.00
1.90
8.23
WiFi 2.4G (USA)
2401 - 2473 MHz
72.55
1.90
8.23
WiFi 2.4G (Japan)
2401 - 2495 MHz
74.01
1.90
8.23
WiFi 5G (all channels)
5150 - 5990 MHz
79.91
1.73
5.14
WiFi 5G (Ch 32-48)
5150 - 5250 MHz
89.62
1.35
5.14
WiFi 5G (Ch 32-64)
5150 - 5330 MHz
86.60
1.39
5.14
WiFi 5G (Ch 32-161)
5150 - 5815 MHz
81.93
1.73
5.14
WiFi 5G (Ch 32-173)
5150 - 5875 MHz
81.72
1.73
5.14
ISM 5.8 GHz
5725 - 5875 MHz
82.20
1.73
4.45
Suitable band
Use Indicator
Likley to be unsuitable
end user is advised to use their own criteria and/or testing to confirm suitability.
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
11
Delta 6C
2D Radiation Plots
1700 MHz XY
XZ
YZ
2000 MHz XY
XZ
YZ
2100 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
12
Delta 6C
2D Radiation Plots
2300 MHz XY
XZ
YZ
2400 MHz XY
XZ
YZ
2500 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
13
Delta 6C
2D Radiation Plots
2600 MHz XY
XZ
YZ
3300 MHz XY
XZ
YZ
3500 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
14
Delta 6C
2D Radiation Plots
3700 MHz XY
XZ
YZ
4700 MHz XY
XZ
YZ
5200 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
15
Delta 6C
2D Radiation Plots
5500 MHz XY
XZ
YZ
5800 MHz XY
XZ
YZ
5900 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
16
Delta 6C
3D Radiation Plots
1700 MHz
2000 MHz
2100 MHz
2300 MHz
2400 MHz
2500 MHz
2600 MHz
3300 MHz
3500 MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
17
Delta 6C
3D Radiation Plots
3700 MHz
4700 MHz
5200 MHz
5500 MHz
5800 MHz
5900 MHz
NOTE: All 3D radiation plots are shown with Theta = 45 and Phi = 45.
Part Number
Description
DELTA6C/x/SMAM/S/RP/11
5G/4G/3G/Dual band WiFi/Bluetooth/Zigbee Antenna SMA Male Reverse Polarity
Connector
DELTA6C/x/SMAM/S/S/11
5G/4G/3G/Dual band WiFi/Bluetooth/Zigbee Antenna SMA Male Connector
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44 118 796 9000
sales@siretta.com
www.siretta.com
Rev 2.0
18
DELTA6C/X/SMAM/S/S/11 价格&库存
很抱歉,暂时无法提供与“DELTA6C/X/SMAM/S/S/11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+86.64313
- 10+84.91443
- 50+83.20656
- 国内价格 香港价格
- 1+147.845961+19.12783
- 10+117.2073110+15.16390
- 25+109.5405025+14.17199
- 100+101.11652100+13.08212
- 250+97.10082250+12.56259
- 500+94.68025500+12.24942
