TANGO25A/0.1M/SMAM/S/RP/29
    SIRETTA
TANGO25A/0.1M/SMAM/S/RP/29 数据手册
Tango 25A Miniature Dual Band WiFi Through Hole Mount Antenna Key Features • Miniature Design • Through Hole / Screw Mounting • Dual Band WiFi 2400 / 5800MHz General Description Additional Considerations The Tango 25A is a miniature, through-hole mount, dual band WiFi / WLAN antenna. Measuring at an impressive 22 x 22mm, this is one of the most compact screw mount WiFi antennas on the market. • Made out of durable ABS • 2dBi gain at 2400MHz / 4dBi gain at 5800MHz The Tango 25A is tuned to operate within the 2.4 to 2.5GHz and 5.1 to 5.9GHz frequencies, making this antenna perfect for WiFi, Bluetooth and Zigbee applications. The antenna is supplied as standard, with 100mm of RG174 coaxial cable, terminated with a reverse polarity SMA male connector. Custom cable lengths and alternative connector types can be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 1.5 Tango 25A Miniature Dual Band WiFi Through Hole Mount Antenna Electrical Specifications Operating temperature: Impedance: Gain: VSWR: Frequency range: Mechanical Specifications -30 to +60°C 50 Ohm 2/4dBi ≤ 2.0 2.4 - 2.5 / 5.1 - 5.9GHz Max power: 1 Watt Beamwidth: H-PLANE - 360° E-PLANE - 30/22° Polarization: Vertical Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Dimensions: Ø22 x 22mm Weight: 11g Connector: RP SMA Male Cable: RG174 RoHS compliant: Yes Mounting Method: Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW M11 1.0P-6g screw sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 1.5 Tango 25A Miniature Dual Band WiFi Through Hole Mount Antenna Test Reports VSWR Return Loss Radiation Patterns 2.4GHz H Plane 2.4GHz E Plane 2.4G 2.45G 2.5G Registered in England No. 08405712 VAT Registration No. GB163 04 0349 2.4G 2.45G 2.5G Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 1.5 Tango 25A Miniature Dual Band WiFi Through Hole Mount Antenna 5GHz H Plane 5GHz E Plane Ordering Details Part Number Description TANGO25A/0.1M/SMAM/S/RP/29 DUAL WIFI 2.4/5GHZ MINI THROUGH HOLE MOUNT ANTENNA 100MM CABLE AND RP SMA MALE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 1.5
TANGO25A/0.1M/SMAM/S/RP/29 价格&库存
很抱歉,暂时无法提供与“TANGO25A/0.1M/SMAM/S/RP/29”相匹配的价格&库存,您可以联系我们找货
  • 1+145.98117
  • 5+140.14942
库存:115
