FW.86.RNT.M
FW.86.RNT.M
    TAOGLASLIMITED
    FW.86.RNT.M
FW.86.RNT.M 数据手册
Meteor Part No: FW.86.RNT.M Description: Meteor-868MHz Flexible Whip Monopole Antenna RP-N Type(M) Straight Features: External 868MHz Monopole Antenna Omni-directional Designed for Outdoor Use Over 90% efficiency* Over 4dBi high peak gain* Robust Inner Steel Core Antenna height 246mm RP-N Type(M) Straight Connector IP65 dust and water-resistant *Tested on 30cm*30cm Ground Plane RoHS Compliant SPE-15-8-035/B/AW 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 8 5. Mechanical Drawing 11 6. Packaging 12 Changelog 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-15-8-035/B/AW www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The FW.86 is a flexible 868MHz whip antenna with an RP-N type (M) connector for outdoor use. It features excellent efficiency (>95%) and high peak gain (>4.5 dBi) at 868MHz on a 30x30 cm ground plane. The antenna was specifically developed for monitoring systems, such as weather monitoring, motion/vibration sensors, and pollutants monitoring. Introduction The FW.86 has an excellent omni-directional radiation pattern, ensuring wide coverage. The antennas high efficiency means that it allows your radio to consume less power than with a lower efficiency antenna when transferring data. It also means a better strength of signal, and better sensitivity in areas of low signal levels. The antenna performs at its best while attached to a ground plane with dimensions of at least 30x30 cm. For an environment where there is no ground-plane available we recommend to use the TI.18 or OMB.868. Introduction The FW.86 whip is made of a flexible inner steel core covered by PE so it is extremely resistant to abrasion and maintains its original shape and RF performance even after shock. This rugged design and IP65 rating on the housing ensure high reliability. Introduction This antenna also comes with SMA(M) connector as standard. Other custom variants can be provided subject to NRE and MOQ. Contact your regional Taoglas office for details. SPE-15-8-035/B/AW www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. 3. 4. 4. 868MHz In free space On 30x30cm ground 27.2 % 96.6 % -1.57 dBi 4.78 dBi Return loss < -3dB < -15dB VSWR ≤ 6:1 ≤ 2:1 Efficiency Antenna Characteristics Peak Gain Antenna Radiation Patterns3.Antenna Impedance Polarization 3. Specifications Center Frequency Characteristics2. Radiation Pattern 3. 868MHz 50Ω Linear Specifications Omni-Directional Input Power 2W Tested Power 10 W Antenna Characteristics2. Specifications Mechanical Dimensions Height 246 ± 6 mm Base Diameter 20 ± 0.5 mm Whip Diameter Antenna Characteristics 6.2 ± 0.6 mm Casing ABS Connector RP-N Type(M) Straight Weight 48.5 g Antenna Radiation Patterns3.AntennaIP65 (housing) Dust and Water Resistance Characteristics Environmental Temperature Range -40°C to 85°C Humidity Non-condensing 65°C 95% RH 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-15-8-035/B/AW Specifications www.taoglas.com 4 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna 3.1 Return Loss Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-15-8-035/B/AW www.taoglas.com 5 3.2 Efficiency SPE-15-8-035/B/AW www.taoglas.com 6 3.3 Peak Gain SPE-15-8-035/B/AW www.taoglas.com 7 4. 4. 4. 4. Radiation Patterns 4.1 Antenna Radiation Patterns 4. Test Setup Antenna Radiation Patterns Antenna Radiation Patterns Y X Z 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns Free Space 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns On 30x30 cm ground plane SPE-15-8-035/B/AW www.taoglas.com 8 4.2 3D and 2D Radiation Patterns (Free Space) XY Plane XZ Plane X Z Y X YZ Plane Z Y 3D Radiation Pattern @ 868MHz SPE-15-8-035/B/AW www.taoglas.com 9 4.2 3D and 2D Radiation Patterns (On 30cm*30cm Ground Plane) XY Plane XZ Plane X Z Y X YZ Plane Z Y 3D Radiation Pattern @ 868MHz SPE-15-8-035/B/AW www.taoglas.com 10 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 8. 6. Packaging Packaging5. SPE-15-8-035/B/AW Mechanical Drawing www.taoglas.com 11 6. Packaging 6. Packaging5. 6. 7. Mechanical Drawing 1pcs FW.86.RNT.M per PE Bag Bag Dimensions - 380*50mm Weight - 50g Packaging Application Note6. Packaging5. Mechanical Drawing 50 PE Bags per Large PE Bag Large PE Bag Dimensions - 470*340mm Weight – 2Kg 6. Packaging5. 6. Packaging 7. Mechanical Drawing 4 Large PE Bags per Carton Carton Dimensions - 400*300*250mm Weight - 10.5Kg Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Pallet Dimensions: 1100*1200*1500mm 60 Cartons Per Pallet 12 Cartons Per Layer 5 Layers Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-035/B/AW Mechanical Drawing www.taoglas.com 12 Changelog for the datasheet SPE-15-8-035 - FW.86.RNT.M Revision: B Date: Changes: Changes Made by: 2019-08-16 Updated to new format Dan Cantwell Previous Revisions Revision: A (Original First Release) Date: Notes: 2015-06-15 Author: Wayne Yang SPE-15-8-035/B/AW www.taoglas.com 13 www.taoglas.com SPE-15-8-035/B/AW © Taoglas www.taoglas.com 14
FW.86.RNT.M 价格&库存
很抱歉,暂时无法提供与“FW.86.RNT.M”相匹配的价格&库存,您可以联系我们找货
FW.86.RNT.M
  • 1+145.890941+18.87322
  • 24+107.9501624+13.96500
  • 47+105.9210247+13.70250
  • 93+103.8918893+13.44000
库存:94
FW.86.RNT.M
  • 5+94.37028
  • 24+92.62917
  • 47+90.88807
  • 93+89.14696
库存:94
FW.86.RNT.M
  • 1+194.291791+25.13461
  • 10+155.3074810+20.09140
  • 50+139.7165350+18.07447
  • 100+134.88902100+17.44996
  • 250+129.79298250+16.79071
  • 500+126.72107500+16.39331
库存:48
FW.86.RNT.M
  • 3+239.03297
  • 16+211.12423
  • 31+207.23138
  • 62+203.11095
库存:94
FW.86.RNT.M
    • 3+257.419183+33.30110
    • 16+227.3709316+29.41390
    • 31+223.1781531+28.87150
    • 62+218.7233262+28.29520
    库存:94
