TANGO3/1M/FMEF/S/S/31
    SIRETTA
    插件
    Tango 3 是一款适用于工业和汽车应用的2G/GPRS和3G/UMTS频率的穿孔安装天线。它具有紧凑的尺寸,适合面板安装,并配有O形密封圈防止水分进入。
TANGO3/1M/FMEF/S/S/31 数据手册
Tango 3 2G/GPRS & 3G Through Hole Antenna Key Features • Compact size • Tri-band 2G + 3G • Wide frequency range General Description Additional Considerations The Tango 3 is tuned to tri band 2G/ GPRS & 3G/UMTS frequencies. It is suited to industrial and automotive applications for panel mounting to (up to 4mm thick) and is manufactured with an O ring seal to prevent moisture ingress once installed. • Panel mounted • Meets all EU compliance criteria for electronic goods The brass foot has a ridged topside allowing secure fitting to the enclosure and a 6mm diameter screw thread for mounting the antenna. Supplied as standard with a 3m cable and either SMA Male or FME Female connectors. Alternative cable lengths or connector types may be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.4 Tango 3 2G/GPRS & 3G Through Hole Antenna Electrical Specifications Temperature range: Operating Frequencies: Mechanical Specifcations -40 to 85°C 869-960/1710-1990MHz Impedance: 50 Ohm Gain: 2.5dBi VSWR: Dimensions: L76 x W29 x 10mm Ø Cable: RG58 Connector: SMA Male Mounting method: Through hole
TANGO3/1M/FMEF/S/S/31 价格&库存
很抱歉,暂时无法提供与“TANGO3/1M/FMEF/S/S/31”相匹配的价格&库存,您可以联系我们找货
