TANGO21/3M/SMAM/S/S/26
    SIRETTA
TANGO21/3M/SMAM/S/S/26 数据手册
Tango 21 Robust Through Hole GPS Antenna Key Features • GPS antenna • 28dB LNA gain • High gain dielectric antenna General Description Additional Considerations The Tango 21 is our most compact GPS antenna with a screw threaded base. • Vandal resistant • Compact design for covert or space limited applications • Low current consumption 5mA at 2.2V The built in Low Noise Amplifier (LNA) provides a 28dB gain on the antenna signal. The benefit of having a strong signal means that satellite fix times are quicker which drives application readiness. The antenna can be mounted securely and can be used for a host of different GPS applications including: vehicle/ fleet/asset tracking, mobile applications or general positioning purposes. Supplied as standard with an IPEX or MCXM connector. Custom cable lengths and alternative connector types can be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9014 sales@siretta.com www.siretta.com Rev 1.7 Tango 21 Robust Through Hole GPS Antenna Antenna Specifications Frequency Range: Mechanical Specifications 1575.42 ±1 MHz VSWR:
TANGO21/3M/SMAM/S/S/26 价格&库存
很抱歉,暂时无法提供与“TANGO21/3M/SMAM/S/S/26”相匹配的价格&库存,您可以联系我们找货
  • 1+247.159531+32.01581
  • 10+199.1496110+25.79684
  • 25+187.1544325+24.24305
  • 100+173.96829100+22.53498
  • 250+167.68294250+21.72081
  • 500+163.89534500+21.23018
库存:17
  • 1+188.91742
  • 5+185.14761
库存:40
