FXP612.07.0095A
FXP612.07.0095A
    TAOGLASLIMITED
    FXP612.07.0095A
FXP612.07.0095A 数据手册
Part No: FXP612.07.0095A Description: FXP612 Flexible Polymer GPS L1 / GPS L2 / GPS L5 / GALILEO / GLONASS G1 / BEIDOU Antenna Features: GPS L1 / GALILEO :1563-1587 MHz GPS L2 :1215-1240 MHz GPS L5 :1164-1189 MHz GLONASS G1: 1593-1610 MHz BEIDOU:1559-1591 MHz Flexible Loop Antenna 3 dBi Peak Gain-90% Efficiency Peel and Stick Dims: 76mm*47mm*0.15mm Cable Length : 95mm IPEX MHFI Connector (U.FL compatible) Patent Pending RoHS compliant SPE-16-08-027-B 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 9 5. Mechanical Drawing 14 6. Packaging 15 7. Application Note 16 Changelog 17 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-08-027-B www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction The patent pending FXP612 embedded flexible antenna is a next generation GNSS antenna designed to cover working frequencies in the GPS L1/L2/L5/ GLONASS / GALILEO / BeiDou bands. This antenna features the highest efficiencies in the market, not just an incredible efficiency of 90% in GPS/GALILEO/GLONASS/BeiDou L1 bands, but also 70% efficiency in the GPS L2 and L5 bands. The FXP612 is a linear polarized antenna, but with an omnidirectional radiation pattern which makes it less sensitive to device orientation. The VSWR is also extremely low, below 1.6 at all bands, this of course contributes to it’s total radiation efficiency, but also means it is ideal for low power consumption applications. 1. Introduction 1. Introduction This antenna is made of durable, flexible, polymer with a cable and connector for easy installation. It is designed to be mounted directly to the inner shell of a plastic housing or glass enclosure/cover. No space is needed on the PCBs of your device, but at least 20mm of minimum clearance is required from the ground-plane to achieve optimal antenna efficiency. At 76mm*47mm*0.15mm, the antenna is ultrathin and can be applied by a simple peel and stick process, attaching securely to non-metal surfaces via 3M adhesive. It has been tuned to work directly on ABS/PC plastic housings. 1. Introduction 1. Introduction Typical Applications - Telematics - Fleet Management - Positioning It is an ideal choice for any device maker that needs a solution that can work on L1 and L2 today, but also for years to come with the new L2 and L5 GPS civilian signal bands coming on stream in 2020 and beyond, and which would like to keep manufacturing costs down over the lifetime of a product. Cable type, length and connectors are customizable. For cable lengths over 200mm, it is recommended to use an active GPS/GALILEO patch antenna. Please contact your regional Taoglas sales office for support. SPE-16-08-027-B www.taoglas.com 3 2. Specifications 3. GNSS Frequency Bands Covered Antenna Characteristics2. Specifications GPS L1 L2 L5 GLONASS 3. ▓ ▓ G1 G2 G3 ▓ ▓ Antenna Characteristics Galileo BeiDou 4. ▓ E1 E5a E5b E6 ▓ ▓ ▓ □ B1 B2a B2b B3 ▓ ▓ ▓ ▓ Antenna Radiation Patterns3. Antenna QZSS (Regional) L1 Characteristics2. ▓ IRNSS (Regional) 3. ▓ L2C L5 L6 ▓ ▓ □ Specifications L5 ▓ Antenna Characteristics2. SBAS L1/E1/B1 L5/B2a/E5a ▓ ▓ Specifications G1 G2 G3 ▓ ▓ ▓ *SBAS systems: WASS(L1/L5), EGNOSS(E1/E5a), SDCM(G1/G2/G3), SNAS(B1,B2a), GAGAN(L1/L5), QZSS(L1/L5), KAZZ(L1/L5). 3. Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-16-08-027-B Specifications www.taoglas.com 4 Electrical Band Frequency (MHz) Return Loss Efficiency (%) Peak Gain (dBi) VSWR GPS L1 /GALILEO 1563~1587 -16.2 91 3.7 1.2 GPS L2 1215~1240 -12.6 73 3.3 1.6 GPS L5 1164~1189 -16.0 70 3.1 1.3 GLONASS 1593~1610 -20.4 92 3.9 1.1 BEIDOU 1559~1591 -23.0 91.5 4.0 1.2 Impedance Max Power Input Polarization Radiation Pattern 50Ω 5W Linear Omnidirectional Mechanical Dimensions 76*47*40.15 mm Material FPCB Cable Mini-Coax 1.13 mm, Cable Length: 95mm Connector MHFI (U.FL compatible) Weight 3g Environmental Temperature Range -40°C to 85°C Storage Temperature -40°C to 105°C Humidity Non-condensing 65°C 95% RH * The FXP612 antenna performance was measured with 30X30 cm ABS Plastic (2mm thickness) SPE-16-08-027-B www.taoglas.com 5 3. Antenna Characteristics 3.1 4. Set Up Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Return Loss 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-08-027-B www.taoglas.com 6 3.3 VSWR 3.4 Efficiency SPE-16-08-027-B www.taoglas.com 7 3.5 Peak Gain SPE-16-08-027-B www.taoglas.com 8 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-16-08-027-B www.taoglas.com 9 4.2 2D Radiations Patterns 4.2.1 XY Plane 4.2.2 ZY Plane SPE-16-08-027-B www.taoglas.com 10 4.3 3D Radiation Pattern 4.3.1 GPS L1/GALILEO at 1575 MHz 4.3.2 GPS L2 at 1227 MHz SPE-16-08-027-B www.taoglas.com 11 4.3 3D Radiation Pattern 4.3.3 GPS L5 at 1176 MHz 4.3.4 GLONASS at 1602 MHz SPE-16-08-027-B www.taoglas.com 12 4.3 3D Radiation Pattern 4.3.5 BEIDOU at 1561 MHz SPE-16-08-027-B www.taoglas.com 13 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-08-027-B Mechanical Drawing www.taoglas.com 14 8. 6. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-08-027-B Mechanical Drawing www.taoglas.com 15 7. Application Note The FXP612 antenna performance with different cable lengths. 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. 7. Application Note6. Packaging5. Mechanical Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Drawing Copyright © Taoglas Ltd. 6. Packaging5. SPE-16-08-027-B Mechanical Drawing www.taoglas.com 16 Changelog for the datasheet SPE-16-08-027 – FXP612.07.0095A Revision: B (Current Version) Date: Changes: Changes Made by: 2022-06-07 Updated Image and Drawing Cesar Sousa Previous PreviousRevisions Revisions (Continued) Revision: A (Original First Release) Date: Notes: 2016-04-13 4/13/2016 Author: SPE-16-08-027-B www.taoglas.com 17 www.taoglas.com SPE-16-08-027-B © Taoglas 18 www.taoglas.com
FXP612.07.0095A 价格&库存
很抱歉,暂时无法提供与“FXP612.07.0095A”相匹配的价格&库存,您可以联系我们找货
FXP612.07.0095A
    • 1+159.55920
    • 200+63.66600
    • 500+61.53840
    • 1000+60.49080
    FXP612.07.0095A
    • 10+47.88037
    • 50+47.00982
    • 95+46.05463
    • 100+44.31353
    库存:154
