TLS.30.1F11
TLS.30.1F11
    TAOGLASLIMITED
    TLS.30.1F11
TLS.30.1F11 数据手册
Shockwave ISM 433MHz Permanent Mount Part No: TLS.30.1F11 Description: Shockwave 433MHz Permanent Mount External Antenna N Type(F) connector Features: ISM 433MHz with 55% efficiency Mechanically robust for indoor/outdoor applications Height: 79.45mm(3.13") ; Diameter : 42mm(1.65") IP67 Waterproof N type(F) connector RoHS & REACH Compliant SPE-15-8-069-C 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 9 6. Installation Guidelines 10 7. Packaging 11 Changelog 12 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-15-8-068-C www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. Introduction The Shockwave TLS.30.1F11 is a mechanically robust, waterproof, external antenna operating at the 433MHz band with an N type female connector. It has been designed to be used on a ground plane. Typical Applications Include: 1. Introduction 1. Introduction 1. - Mesh networks Indoor/outdoor asset monitoring Security systems Remote control systems Heavy-duty equipment/vehicle communication in harsh environments The antenna has 51% efficiency and -1.1 dBi peak gain at ISM 433MHz on a 30x30 cm ground plane. Stable radiation patterns over low angles provides consistent gain in the horizontal plane, meaning that it is especially suitable for mesh networks or hot spots. Introduction A unique indent tab on the base of the antenna allows a wrench to be used to solidly lock the antenna on top of its mounting location while tightening up the nut beneath the metal panel. Waterproof O-rings around the bottom base prevent water from leaking under the antenna. The TLS.30 antenna is IP67 waterproof resistant against high pressure water jets in commercial cleaning environments, which makes the antenna ideal for ISM 433MHz applications in harsh outdoor environments. Cable lengths and connector types are customizable. Contact your regional Taoglas customer support team for further information. SPE-15-8-068-C www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Application Band ELECTRICAL Specifications ISM433 Operation Frequency 433 MHz On 30 x 30 cm ground plane 3. 4. Efficiency (%) 51.67% Antenna Characteristics Peak Gain (dBi) -1.19 Average Gain (dBi) -2.87 Return Loss (dB) < -15 Impedance 50 Ω Antenna Radiation Polarization Patterns3.Antenna Radiation Property Vertical Omni-Directional Power Characteristics2.Max InputSpecifications 100 W MECHANICAL 3. 3. Dimension (mm) Height: 79.45mm (3.13") ; Diameter : 42mm(1.65") Connector N type (F) Antenna Characteristics2. Specifications Housing: UV Resistant ABS, Material Base: Nickel Plated Zinc Alloy Weight (g) 169 Rec. Torque for Mounting 4.018 N.m Torque for Mounting AntennaMax. Characteristics 9.8 N.m ENVIRONMENTAL 4. Waterproof Rating IP67 Operation Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-15-8-068-C Specifications www.taoglas.com 4 3. Antenna Characteristics 3.1 Return Loss 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-15-8-068-C www.taoglas.com 5 3.3 Average Gain 3.4 Peak Gain SPE-15-8-068-C www.taoglas.com 6 4. 6. Radiation Patterns 4.1 Test Setup Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-068-C Mechanical Drawing www.taoglas.com 7 4.2 3D and 2D radiation Patterns 433MHz XY Plane SPE-15-8-068-C XZ Plane YZ Plane www.taoglas.com 8 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-068-C Mechanical Drawing www.taoglas.com 9 8. 6. Packaging Guidelines Installation 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-068-C Mechanical Drawing www.taoglas.com 10 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-068-C Mechanical Drawing www.taoglas.com 11 Changelog for the datasheet SPE-15-8-068 – TLS.30.1F11 Revision: B (Current Version) Date: Changes: Changes Made by: 2022-09-08 Updated specifications Cesar Sousa Previous Revisions Revision: A (Original First Release) Date: Notes: 2021-09-28 Author: Jack Conroy SPE-15-8-068-C www.taoglas.com 12 www.taoglas.com SPE-15-8-068-C © Taoglas 13 www.taoglas.com
TLS.30.1F11 价格&库存
很抱歉,暂时无法提供与“TLS.30.1F11”相匹配的价格&库存,您可以联系我们找货
TLS.30.1F11
  • 1+380.856671+49.47135
  • 10+311.3231210+40.43930
库存:26
