TANGO20/3M/SMAM/S/S/26
    SIRETTA
TANGO20/3M/SMAM/S/S/26 数据手册
Tango 20 GPS Puck Antenna Key Features • Vandal resistant • 28dB LAN gain • Puck design for secure mounting General Description Additional Considerations The Tango 20 is a compact, puck shaped antenna that is tuned to the 1575.42MHz GPS frequency. • Reduced time for satellite fix • High performing antenna The Tango 20 can be mounted securely inside or outside making this antenna suitable for a host of different GPS applications including: vehicle/ fleet/asset tracking, mobile applications or general positioning purposes. The built in Low Noise Amplifier (LNA) provides 28dB gain for strong signal reception from visible satellites, and influences a shorter time to fix to the satellites allowing applications to run quickly. The antenna comes as standard with an SMA Male connector. Alternative cable lengths and connectors types can be fitted for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.3 Tango 20 GPS Puck Antenna Electrical Specifications Dielectric Antenna Frequency range: VSWR: Polarization: Mechanical Specifications Dimensions: 1575.42 ±1 MHz
TANGO20/3M/SMAM/S/S/26 价格&库存
很抱歉,暂时无法提供与“TANGO20/3M/SMAM/S/S/26”相匹配的价格&库存,您可以联系我们找货
  • 1+219.19045
  • 5+197.27973
库存:424
