TANGO11A/2.5M/SMAM/S/S/19 数据手册
Tango 11A
2G/3G/4G/5G & Dual Band WiFi Puck Antenna
Key Features
Quad Band GSM / GPRS 2G and UMTS 3G
4G and 5G LTE
Dual Band WiFi 2.4 GHz and 4.9 GHz to 5.9 GHz
Low profile
General Description
Additional Considerations
The Tango 11A puck antennas operate
on 850/900/1800/1900/2100MHz
bands supporting quad band GSM/
GPRS networks throughout Europe,
Asia and Africa with the addition of
3G UMTS, 4G/5G LTE and Dual Band
WiFi.
• Internal or external use
• Strong puck design
• Meets all EU compliance criteria for electronic goods
The tough case and through hole
mount design makes it suitable for use
in external environments like high sided
vehicles.
The RF cable is fed via the through
hole mount base to ensure no cable is
visible when fixed and the rubber ‘skirt’
around the base protects against water
ingress.
The antenna is finished with an SMA
Male connector and comes in different
cable lengths. Alternative connector
types and cable lengths can be
specified for volume orders.
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
Electrical Specification
Humidity:
Mechanical Specification
40 to 95% RH
Impedance:
50 Ohms
Polarization:
Linear vertical
Dimensions:
80 mm Ø x H23 mm
Cable:
RG174
Connector:
SMA Male
Mounting Method:
Environmental Specification
Temperature range:
-40 to 85 °C
M 17 Screw Mount
Mounting screw length:
22 mm
Max Panel Thickness:
13 mm
Radome Material:
Nylon PA6
Z
X
Y
orientation
Return Loss tested with 1 m cable
Return Loss in -dB
0.00
-2.00
-4.00
-6.00
-dB
-8.00
-10.00
-12.00
-14.00
-16.00
-18.00
-20.00
2000
3000
4000
5000
6000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
VSWR tested with 1 m cable
VSWR
10.00
9.00
8.00
VSWR
7.00
6.00
5.00
4.00
3.00
2.00
1.00
2000
3000
4000
5000
6000
4000
5000
6000
MHz
Radiation Efficiency tested with 1 m cable
Antenna Radiation Efficiency (in %)
110.00
100.00
90.00
80.00
% Efficiency
70.00
60.00
50.00
40.00
30.00
20.00
10.00
0.00
2000
3000
MHz
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
LTE/5G Band Coverage
M/5G Bands
NB-IoT
Band
1/n1
B1
2/n2
3/n3
LTE, CAT-
Avg Efficieny %
over band
Max VSWR
over Band
Uplink
Downlink
Europe / Asia
1920-1980 MHz
2110-2170 MHz
63.31 / 57.12
2.02 / 2.05
B2
North America/Latin America/Caribbean
1850-1910 MHz
1930-1990 MHz
60.31 / 62.75
1.99 / 2.01
B3
Europe/Africa/Asia/Oceania
1710-1785 MHz
1805-1880 MHz
54.42 / 58.77
2.04 / 1.99
4
B4
1710-1755 MHz
2110-2155 MHz
53.73 / 56.10
2.04 / 2.05
5/n5
B5
Country Specific
824-849 MHz
869-894 MHz
49.23 / 38.62
1.99 / 2.48
7/n7
Regional Coverage
2500-2570 MHz
2620-2690 MHz
44.14 / 42.86
2.49 / 2.58
8/n8
B8
Latin America/Europe/Asia +
Europe / Asia +
880-915 MHz
925-960 MHz
29.86 14.20
2.91 / 4.54
11
B11
Country Specific
1427.9-1447.9 MHz
1475.9-1495.9 MHz
36.23 / 39.86
2.84 / 2.07
12/n12
B12
North America/Caribbean +
699-716 MHz
729-746 MHz
48.38 / 50.45
2.47 / 1.38
13/n13
B13
777-787 MHz
746-756 MHz
52.69 / 51.52
1.11 / 1.25
14/n14
B14
Country Specific
788-798 MHz
758-768 MHz
52.12 / 51.96
1.24 / 1.16
17
B17
704-716 MHz
734.746 MHz
48.70 / 50.45
2.32 / 1.32
18/n18
B18
Country Specific
815-830 MHz
860-875 MHz
51.09 / 42.72
1.83 / 2.30
19
B19
Country Specific
830-845 MHz
875-890 MHz
49.23 / 38.62
1.94 / 2.45
20/n20
B20
Europe/Africa +
832-862 MHz
791-821 MHz
46.83 / 51.53
2.17 / 1.72
Country Specific
1447.9-1462.9 MHz
1495.9-1510.9 MHz
38.31 / 42.48
2.81 / 2.06
25/n25
21
B25
Country Specific
1850-1915 MHz
1525-1559 MHz
60.31 / 44.88
1.99 / 2.07
26/n26
B26
Country Specific
814-849 MHz
859-894 MHz
49.77 / 41.84
1.99 / 2.48
28/n28
B28
703-748 MHz
758-803 MHz
50.45 / 51.53
2.32 / 1.34
717-728 MHz
48.87
29/n29
Country Specific
30/n30
31
B31
32
1.78
Country Specific
2305-2315 MHz
2350-2360 MHz
59.23 / 55.87
1.77 / 1.95
Country Specific
452.5-457.5 MHz
462.5-467.5 MHz
16.98 / 14.38
6.13 / 5.08
Country Specific
1452-1496 MHz
39.18
2.71
38/n38
Europe +
2570-2620 MHz
42.72
2.54
39/n39
Country Specific
1880-1920 MHz
61.14
1.98
40/n40
Asia +
2300-2400 MHz
56.09
1.99
41/n41
Country Specific
2496-2690 MHz
43.86
2.58
42
Country Specific
3400-3600 MHz
40.05
2.64
43
Country Specific
3600-3800 MHz
44.13
2.42
46/n46
Country Specific
5150-5925 MHz
43.03
1.72
48/n48
Country Specific
3550-3700 MHz
43.23
2.59
65/n65
Country Specific
1920-2010 MHz
2110-2200 MHz
62.59 / 57.62
2.02 / 2.05
66/n66
B66
Country Specific
1710-1780 MHz
2110-2200 MHz
53.80 / 57.62
2.04 / 2.05
71/n71
B71
Country Specific
663-698 MHz
617-652 MHz
45.74 / 30.94
2.77 / 2.93
Table data for bands as detailed in 3GPP TS 36.101 & 38.101
Usable Band
Adequate in good signal area
x Not Usable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
5G Extended Table for Band Coverage
LTE/5G
Band
NB-IoT
Band
n24
Uplink
Downlink
1626.5 – 1660.5 MHz
1525 – 1559 MHz
Avg Efficieny %
over band
47.25 / 44.88
Max VSWR
over Band
1.88 / 2.07
n34
2010 – 2025 MHz
62.40
2.01
n47
5855 – 5925 MHz
44.18
1.27
n50
1432 – 1517 MHz
39.35
2.84
n51
1427 – 1432 MHz
35.68
2.84
n53
2483.5 – 2495 MHz
47.44
1.91
n67
738 – 758 MHz
50.45
1.26
n70
B70
n74
1695 – 1710 MHz
1995 – 2020 MHz
49.65 / 62.25
2.17 / 2.01
1427 – 1470 MHz
1475 – 1518 MHz
37.28 / 41.19
2.84 / 2.10
n75
1432 – 1517 MHz
39.35
2.84
n76
1427 – 1432 MHz
35.68
2.84
n77
3300 – 4200 MHz
40.12
2.64
n78
3300 – 3800 MHz
41.33
2.64
n79
4400 – 5000 MHz
44.46
2.31
n80
1710 – 1785 MHz
54.42
2.04
n81
880 – 915 MHz
29.86
2.91
n82
832 – 862 MHz
46.83
2.17
n83
703 – 748 MHz
50.11
2.32
1920 – 1980 MHz
63.31
2.02
n84
n85
B85
n86
698 – 716 MHz
728 – 746 MHz
48.38 / 50.45
2.47 / 1.38
1710 – 1780 MHz
53.80
2.04
n89
824 – 849 MHz
49.23
1.99
n90
2496 – 2690 MHz
43.86
2.58
n91
832 – 862 MHz
1427 – 1432 MHz
46.83 / 35.68
2.17 / 2.84
n92
832 – 862 MHz
1432 – 1517 MHz
46.83 / 39.35
2.17 / 2.84
n93
880 – 915 MHz
1427 – 1432 MHz
29.86 / 35.68
2.91 / 2.84
n94
880 – 915 MHz
1432 – 1517 MHz
29.86 / 39.35
2.91 / 2.84
n95
2010 – 2025 MHz
n96
5925 – 7125 MHz
62.40
n97
2300 – 2400 MHz
56.09
1.99
n98
1880 – 1920 MHz
61.14
1.98
n99
1626.5 – 1660.5 MHz
47.25
1.88
2.01
unmeasured
Table data for bands as detailed in 3GPP TS 38.101
Usable Band
x Not Usable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
Radiation Plots tested with 1 m cable
400 MHz XY
XZ
YZ
500 MHz XY
XZ
YZ
600 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
700 MHz XY
XZ
YZ
800 MHz XY
XZ
YZ
900 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
1400 MHz XY
XZ
YZ
1500 MHz XY
XZ
YZ
1600 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
1700 MHz XY
XZ
YZ
1800 MHz XY
XZ
YZ
1900 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
2000 MHz XY
XZ
YZ
2100 MHz XY
XZ
YZ
2300 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
2400 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
51.52
Eff %
51.52
2460 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
47.75
Eff %
47.75
2500 MHz XY
XZ
YZ
WiFi
Band
2.4
GHz
WiFi
Band
2.4
GHz
Eff %
46.34
Eff %
46.34
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
2600 MHz XY
XZ
YZ
2700 MHz XY
XZ
YZ
3300 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
3400 MHz XY
XZ
YZ
3500 MHz XY
XZ
YZ
3600 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
3700 MHz XY
XZ
YZ
3800 MHz XY
XZ
YZ
4400 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
4600 MHz XY
XZ
YZ
4800 MHz XY
XZ
YZ
5000 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
5200 MHz XY
XZ
YZ
5400 MHz XY
XZ
YZ
5600 MHz XY
XZ
YZ
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
5800 MHz XY
XZ
YZ
5900 MHz XY
XZ
YZ
3D Radiation Plots tested with 1 m cable
400 MHz
500 MHz
600 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
700 MHz
800 MHz
900 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
1400 MHz
1500 MHz
1600 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
1700 MHz
1800 MHz
1900 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
2000 MHz
Theta 65 Phi 45
2400 MHz
2100 MHz
Theta 65 Phi 45
2460 MHz
2300 MHz
Theta 65 Phi 45
2500 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
2600 MHz
2700 MHz
3300 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
3400 MHz
Theta 65 Phi 45
3700 MHz
3500 MHz
Theta 65 Phi 45
3800 MHz
3600 MHz
Theta 65 Phi 45
4400 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
4600 MHz
4800 MHz
5000 MHz
Theta 65 Phi 45
Theta 65 Phi 45
Theta 65 Phi 45
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
Tango 11A
5200 MHz
Theta 65 Phi 45
5800 MHz
Theta 65 Phi 45
5400 MHz
Theta 65 Phi 45
5600 MHz
Theta 65 Phi 45
5900 MHz
Theta 65 Phi 45
Ordering Details
Part Number
Description
TANGO11A/1.5M/SMAM/S/S/19
2G/3G/4G/5G & Dual Band WiFi Puck Antenna IP65 SMA Male Connector 1.5m Cable
2G/3G/4G/5G & Dual Band WiFi Puck Antenna IP65 SMA Male Connector 2.5m Cable
TANGO11A/5M/SMAM/S/S/19
2G/3G/4G/5G & Dual Band WiFi Puck Antenna IP65 SMA Male Connector 5m Cable
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9014
sales@siretta.com
www.siretta.com
Rev 2.0
TANGO11A/2.5M/SMAM/S/S/19 价格&库存
很抱歉,暂时无法提供与“TANGO11A/2.5M/SMAM/S/S/19”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+188.93825
- 5+185.15803
