TANGO44/5M/LL/SMAM/S/S/19
    SIRETTA
    Tango 44 是一款宽频天线,具有均匀的性能分布,适用于上部ISM频段、GPRS、UMTS、LTE、WiFi、蓝牙和Zigbee频段。
TANGO44/5M/LL/SMAM/S/S/19 数据手册
Tango 44 2G/3G/4G/5G & WiFi through hole mount puck antenna Key Features • 2G, 3G, 4G including NBIoT/Cat M Bands and 5G • Low loss cable • ISM bands, WiFi, Bluetooth and full Zigbee band allocation General Description Additional Considerations The Tango 44 is a wide band antenna with an even spread performance across the usable spectrum which allows it to be used in the upper ISM bands, GPRS, UMTS, LTE, WiFi, Bluetooth and the Zigbee band allocation. • Wide operating temp range • Weather resistant Supplied as standard with an SMA male connector in three cable lengths, 1, 2.5 and 5 m. Alternative cable lengths and connectors can be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Electrical Specifications Operating Temperature: Mechanical Specifications -40 - +85 °C Humidity: 40% - 95% RH Polarization: Linear Vertical Ø 80 x 23 mm Cable: RG174 Connector: SMA Male 50 W Mounting Method: M17 mm Ø Pitch1.25 50 Ohms Maximum Material Thickness: 10 mm Maximum Power: Impededance: Dimensions: Z X Y orientation Return Loss tested with 1m cable Return Loss in -dB 0.00 -2.00 -4.00 -6.00 -dB -8.00 -10.00 -12.00 -14.00 -16.00 -18.00 -20.00 0 1000 2000 3000 4000 5000 6000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna VSWR tested with 1m cable VSWR 10.00 9.00 8.00 VSWR 7.00 6.00 5.00 4.00 3.00 2.00 1.00 0 1000 2000 3000 4000 5000 6000 4000 5000 6000 MHz Radiation Efficiency tested with 1m cable Antenna Radiation Efficiency (in %) 110.00 100.00 90.00 80.00 % Efficiency 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 0 1000 2000 3000 MHz Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna LTE/5G Band Coverage M/5G Bands NB-IoT Band 1/n1 B1 2/n2 3/n3 LTE, CAT- Avg Efficieny % over band Max VSWR over Band Uplink Downlink Europe / Asia 1920-1980 MHz 2110-2170 MHz 70.81 / 67.15 1.78 / 1.60 B2 North America/Latin America/Caribbean 1850-1910 MHz 1930-1990 MHz 67.85 / 71.04 1.91 / 1.78 B3 Europe/Africa/Asia/Oceania 1710-1785 MHz 1805-1880 MHz 58.79 / 64.36 2.07 / 1.91 4 B4 North America/Latin America/Caribbean 1710-1755 MHz 2110-2155 MHz 57.94 / 67.04 2.07 / 1.59 5/n5 B5 Country Specific 824-849 MHz 869-894 MHz 52.51 / 47.71 2.13 / 2.47 7/n7 Regional Coverage 2500-2570 MHz 2620-2690 MHz 45.47 / 45.39 2.71 / 2.66 8/n8 B8 Latin America/Europe/Asia + Europe / Asia + 880-915 MHz 925-960 MHz 41.57 / 22.62 2.93 / 4.63 11 B11 Country Specific 1427.9-1447.9 MHz 1475.9-1495.9 MHz 40.82 / 47.51 2.80 / 2.49 12/n12 B12 North America/Caribbean + 699-716 MHz 729-746 MHz 53.97 / 53.10 2.95 / 2.04 13/n13 B13 North America/Caribbean + 777-787 MHz 746-756 MHz 53.83 / 52.37 1.55 / 1.98 14/n14 B14 Country Specific 788-798 MHz 758-768 MHz 54.14 / 52.73 1.49 / 1.77 17 B17 North America/Caribbean + 704-716 MHz 734.746 MHz 54.83 / 53.10 2.76 / 2.04 18/n18 B18 Country Specific 815-830 MHz 860-875 MHz 54.08 / 49.44 1.70 / 2.45 19 B19 Country Specific 830-845 MHz 875-890 MHz 52.51 / 47.71 1.99 / 2.44 20/n20 B20 Europe/Africa + 832-862 MHz 791-821 MHz 51.57 / 53.92 2.37 / 1.63 Country Specific 1447.9-1462.9 MHz 1495.9-1510.9 MHz 43.89 / 51.88 2.80 / 2.15 25/n25 21 B25 Country Specific 1850-1915 MHz 1525-1559 MHz 67.85 / 54.59 1.91 / 2.39 26/n26 B26 Country Specific 814-849 MHz 859-894 MHz 53.09 / 49.21 2.13 / 2.47 28/n28 B28 Latin America/Europe/Asia + 703-748 MHz 758-803 MHz 53.60 / 53.80 2.76 / 1.77 - 717-728 MHz 53.73 29/n29 Country Specific 30/n30 31 B31 32 2.15 Country Specific 2305-2315 MHz 2350-2360 MHz 62.24 / 58.59 Country Specific 452.5-457.5 MHz 462.5-467.5 MHz 14.60 / 14.62 Country Specific - 1452-1496 MHz 1.95 / 1.97 x 5.87 / 5.17 45.98 2.80 38/n38 Europe + 2570-2620 MHz 44.23 2.59 39/n39 Country Specific 1880-1920 MHz 69.51 1.87 40/n40 Asia + 2300-2400 MHz 58.7 2.15 41/n41 Country Specific 2496-2690 MHz 45.68 2.71 42 Country Specific 3400-3600 MHz 41.93 2.60 43 Country Specific 3600-3800 MHz 46.91 2.56 46/n46 Country Specific 5150-5925 MHz 50.95 1.71 48/n48 Country Specific 3550-3700 MHz 44.93 2.60 65/n65 Country Specific 1920-2010 MHz 2110-2200 MHz 71.41 / 66.57 1.78 / 1.90 66/n66 B66 Country Specific 1710-1780 MHz 2110-2200 MHz 58.24 / 66.57 2.07 / 1.90 71/n71 B71 Country Specific 663-698 MHz 617-652 MHz 51.99 / 37.68 3.72 / 3.75 Table data for bands as detailed in 3GPP TS 36.101 & 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna 5G Extended Table for Band Coverage LTE/5G Band NB-IoT Band n24 Uplink Downlink 1626.5 – 1660.5 MHz 1525 – 1559 MHz Avg Efficieny % over band 38.36 / 54.59 Max VSWR over Band 1.94 / 2.39 n34 2010 – 2025 MHz 73.52 1.60 n47 5855 – 5925 MHz 50.65 1.50 n50 1432 – 1517 MHz 46.35 2.80 n51 1427 – 1432 MHz 40.24 2.74 n53 2483.5 – 2495 MHz 48.36 2.29 n67 738 – 758 MHz 53.10 2.04 n70 B70 n74 1695 – 1710 MHz 1995 – 2020 MHz 52.53 / 72.78 2.08 / 1.54 1427 – 1470 MHz 1475 – 1518 MHz 42.69 / 49.40 2.80 / 2.49 n75 1432 – 1517 MHz 46.35 2.80 n76 1427 – 1432 MHz 40.24 2.74 n77 3300 – 4200 MHz 43.24 2.60 n78 3300 – 3800 MHz 43.55 2.60 n79 4400 – 5000 MHz 50.31 2.28 n80 1710 – 1785 MHz 58.79 2.07 n81 880 – 915 MHz 41.57 2.93 n82 832 – 862 MHz 51.57 2.37 n83 703 – 748 MHz 53.60 2.76 1920 – 1980 MHz 70.81 1.78 n84 n85 B85 n86 698 – 716 MHz 728 – 746 MHz 53.97 / 53.10 2.95 / 2.04 1710 – 1780 MHz 58.24 2.07 n89 824 – 849 MHz 52.51 2.13 n90 2496 – 2690 MHz 45.68 2.71 n91 832 – 862 MHz 1427 – 1432 MHz 51.57 / 40.24 2.37 / 2.74 n92 832 – 862 MHz 1432 – 1517 MHz 51.57 / 46.35 2.37 / 2.80 n93 880 – 915 MHz 1427 – 1432 MHz 41.57 / 40.24 2.93 / 2.74 n94 880 – 915 MHz 1432 – 1517 MHz 41.57 / 46.35 2.93 / 2.80 n95 2010 – 2025 MHz n96 5925 – 7125 MHz 73.52 n97 2300 – 2400 MHz 58.70 2.15 n98 1880 – 1920 MHz 69.51 1.87 n99 1626.5 – 1660.5 MHz 38.36 1.94 1.60 unmeasured Table data for bands as detailed in 3GPP TS 38.101 Usable Band Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Adequate in good signal area x Not Usable Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 600 MHz XY XZ YZ 700 MHz XY XZ YZ 800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 860 MHz XY XZ YZ 900 MHz XY XZ YZ 1440 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 1500 MHz XY XZ YZ 1600 MHz XY XZ YZ 1700 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 1800 MHz XY XZ YZ 1900 MHz XY XZ YZ 2000 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 2100 MHz XY XZ YZ 2300 MHz XY XZ YZ 2400 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 54.70 Eff % 54.70 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 2440 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 51.64 Eff % 51.64 2500 MHz XY XZ YZ WiFi Band 2.4 GHz WiFi Band 2.4 GHz Eff % 48.31 Eff % 48.31 2600 MHz XY Registered in England No. 08405712 VAT Registration No. GB163 04 0349 XZ YZ Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 2700 MHz XY XZ YZ 3400 MHz XY XZ YZ 3500 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 3600 MHz XY XZ YZ 3700 MHz XY XZ YZ 3800 MHz XY XZ YZ Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna Radiation Plots tested with 1 m cable 4700 MHz XY XZ YZ 5900 MHz XY XZ YZ 3D Radiation Plots tested with 1 m cable 600 MHz 700 MHz 800 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna 3D Radiation Plots tested with 1 m cable 860 MHz 900 MHz Theta 65 Phi 45 Theta 65 Phi 45 1500 MHz 1600 MHz 1440 MHz Theta 65 Phi 45 1700 MHz Theta 65 Phi 45 Theta 65 Phi 45 Theta 65 Phi 45 1800 MHz 1900 MHz 2000 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Theta 65 Phi 45 Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna 3D Radiation Plots tested with 1 m cable 2100 MHz Theta 65 Phi 45 2440 MHz Theta 65 Phi 45 2700 MHz Theta 65 Phi 45 Registered in England No. 08405712 VAT Registration No. GB163 04 0349 2300 MHz Theta 65 Phi 45 2500 MHz Theta 65 Phi 45 3400 MHz Theta 65 Phi 45 2400 MHz Theta 65 Phi 45 2600 MHz Theta 65 Phi 45 3500 MHz Theta 65 Phi 45 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0 Tango 44 2G/3G/4G/5G & WiFi through hole mount puck Antenna 3D Radiation Plots tested with 1 m cable 3600 MHz Theta 65 Phi 45 4700 MHz Theta 65 Phi 45 3700 MHz Theta 65 Phi 45 3800 MHz Theta 65 Phi 45 5900 MHz Theta 65 Phi 45 Ordering Details Part Number Description TANGO44/1M/LL/SMAM/S/S/19 2G/3G/4G/5G & WIFI THROUGH HOLE MOUNT PUCK ANTENNA SMA MALE CONNECTOR 1M LOW LOSS CABLE TANGO44/2.5M/LL/SMAM/S/S/19 2G/3G/4G/5G & WIFI THROUGH HOLE MOUNT PUCK ANTENNA SMA MALE CONNECTOR 2.5M LOW LOSS CABLE TANGO44/5M/LL/SMAM/S/S/19 2G/3G/4G/5G & WIFI THROUGH HOLE MOUNT PUCK ANTENNA SMA MALE CONNECTOR 5M LOW LOSS CABLE Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales email web +44(0)118 976 9000 sales@siretta.com www.siretta.com Rev 2.0
TANGO44/5M/LL/SMAM/S/S/19 价格&库存
很抱歉,暂时无法提供与“TANGO44/5M/LL/SMAM/S/S/19”相匹配的价格&库存,您可以联系我们找货
  • 1+379.639411+49.35190
  • 10+332.2113910+43.18641
  • 30+312.6832730+40.64782
  • 100+293.30296100+38.12844
  • 250+279.85592250+36.38037
库存:14
  • 1+273.95682
  • 5+268.47914
库存:94
