ALPHA7/3M/FMEF/SMAM/S/S/11
    SIRETTA
    Alpha 7 是一款紧凑型、贴片安装的 GSM/GPRS (2G) 和 GPS 组合天线,适用于移动应用,具有 30dB 预放大器,可提高信噪比。
ALPHA7/3M/FMEF/SMAM/S/S/11 数据手册
Alpha 7 Combined GSM/GPRS (2G) & GPS Puck Antenna Key Features • 30dB pre-amplifier • High grade mounting adhesive • Improves signal to noise ratio for mobile applications General Description Additional Considerations The Alpha 7 is an adhesive mount compact, puck-shaped GSM/GPRS & GPS combination antenna. • 3M™ adhesive pad ensures long lasting bond to windscreen • Works on all UK and European GSM / GPRS cellular networks • Meets all EU compliance criteria for electronic goods The GSM/GPRS antenna is a dual band 900/1800MHz dipole providing GSM and GPRS coverage throughout Europe, Africa and most of Asia. The GPS antenna is built with a 30dB Low Noise Amplifier (LNA) to help provide strong satellite fixing. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Alpha 7 Combined GSM/GPRS (2G) & GPS Puck Antenna Mechanical Specifications Electrical Specifications Dielectric Antenna Frequency range: Impedance: Peak Gain: Polarization: VSWR: Connector: Dimensions: 900/1800MHz 50 Ohm L50 x H15.5mm Ø Operating Temperature: -40 - +90°C Storage Temperature: -40 - +90°C 2dBi GSM Connector: SMA Male Vertical GPS Connector: SMA Male
ALPHA7/3M/FMEF/SMAM/S/S/11 价格&库存
很抱歉,暂时无法提供与“ALPHA7/3M/FMEF/SMAM/S/S/11”相匹配的价格&库存,您可以联系我们找货
