Shockwave 450-470MHz Permanent Mount
Part No:
TLS.20.1F21
Description:
Permanent Mount External Antenna
N Type(F) connector
Features:
CDMA 450-470MHz with 46% efficiency
Mechanically robust for indoor/outdoor applications
Height: 79.45mm(3.13") ; Diameter : 42mm(1.65")
IP67 Waterproof
N type(F) connector
RoHS & REACH Compliant
SPE-15-8-066-B
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
5
4.
Radiation Patterns
7
5.
Mechanical Drawing
9
6.
Installation Guidelines
10
7.
Packaging
11
Changelog
12
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-15-8-066-B
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
The Shockwave TLS.20.1F21 is a mechanically robust, waterproof, external antenna operating at the 450470MHz with 1 meter low loss TGC-200 cable and SMA(M) connector. It has been designed to be used on a
ground plane.
1.
Typical Applications Include:
1.
1.
Introduction
Introduction
Public safety
Smart meters
Mesh networks
Transportation
Introduction
The antenna has greater than 46% efficiency and -2.6dBi peak gain with the application band on a 30x30 cm
ground plane. Stable radiation patterns over low angles provide consistent gain in the horizontal plane,
meaning that it is especially suitable for mesh networks or hot spots.
Introduction
A unique indent tab on the base of the antenna allows a wrench to be used to solidly lock the antenna on
top of its mounting location while tightening up the nut beneath the metal panel. Waterproof O-rings around
the bottom base prevent water from leaking under the antenna.
The TLS.20 antenna is IP67 waterproof resistant against high pressure water jets in commercial cleaning
environments, which makes the antenna ideal for 450-470MHz applications in harsh outdoor environments.
Cable lengths and connector types are customizable. Contact your regional Taoglas customer support team
for further information.
SPE-15-8-066-B
www.taoglas.com
3
2.
Specifications
3.
ELECTRICAL
Antenna
Characteristics2.
Specifications
Operation Band
CDMA450
Operation Frequency (MHz)
450
460
470
Efficiency (%)
45.50
54.28
53.34
-1.33
-0.71
-0.79
-3.23
-2.65
-2.72
On 30 x 30 cm ground plane
3.
Antenna
PeakCharacteristics
Gain (dBi)
Average Gain (dBi)
4.
Return Loss (dB)
< -5
Impedance
50 Ω
AntennaPolarization
Radiation Patterns3.Antenna Vertical
Radiation Property
Omni-Directional
Max Input Power
Characteristics2.
Specifications
100 W
MECHANICAL
3.
3.
Dimension (mm)
Cable
1 meter TGC-200
AntennaConnector
Characteristics2.
Specifications
SMA(M)
Material
Housing : UV Resistant ABS ,
Base : Nickel Plated Zinc Alloy
Weight (g)
205
Rec. Torque
for Mounting
Antenna
Characteristics
4.018 N.m
Max. Torque for Mounting
9.8 N.m
ENVIRONMENTAL
Waterproof Rating
4.
IP67
Antenna Radiation Patterns3.Antenna
Operation Temperature
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
Characteristics
4.
4.
Characteristics
4.
Characteristics2.
SPE-15-8-066-B
Specifications
www.taoglas.com
4
3.
3.1
Return Loss
4.
4.
4.
4.
4.
3.2
Efficiency
4.
4.
SPE-15-8-066-B
www.taoglas.com
5
3.3
Average Gain
3.4
Peak Gain
SPE-15-8-066-B
www.taoglas.com
6
4.
6.
Radiation Patterns
4.1
Test Setup
Packaging5.
Mechanical Drawing
The TLS.20 antenna is tested in a CTIA certified ETS-Lindgren Anechoic Chamber. The test setup ishown
below.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-066-B
Mechanical Drawing
www.taoglas.com
7
4.2
2D radiation Patterns
XY Plane
XZ Plane
SPE-15-8-066-B
www.taoglas.com
8
YZ Plane
SPE-15-8-066-B
www.taoglas.com
9
4.3
3D radiation Patterns
450MHz
460MHz
SPE-15-8-066-B
www.taoglas.com
10
470MHz
SPE-15-8-066-B
www.taoglas.com
11
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-066-B
Mechanical Drawing
www.taoglas.com
12
8.
6.
Packaging Guidelines
Installation
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-066-B
Mechanical Drawing
www.taoglas.com
13
8.
7.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-066-B
Mechanical Drawing
www.taoglas.com
14
Changelog for the datasheet
SPE-15-8-066 – TLS.20.1F21
Revision: B (Current Version)
Date:
Changes:
Changes Made by:
2022-09-12
Updated specifications
Cesar Sousa
Previous Revisions
Revision: A (Original First Release)
Date:
Notes:
2021-09-28
Author:
Jack Conroy
SPE-15-8-066-B
www.taoglas.com
15
www.taoglas.com
SPE-15-8-066-B
© Taoglas 16
www.taoglas.com
很抱歉,暂时无法提供与“TLS.20.1F21”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+335.7820150+43.61638
