OSCAR3A/X/FMEM/S/S/19
    SIRETTA
OSCAR3A/X/FMEM/S/S/19 数据手册
Oscar 3A GSM/GPRS, Yagi Antenna Key Features • Quad Band GSM Yagi • 9 element • 11dBi gain General Description Additional Considerations The Oscar 3A is a low cost enamel coated aluminium antenna. It has 9 elements and achieves a gain of 11dBi. • Selection of cable assemblies available - see website • Excellent performance for low cost The Oscar 3A is fitted with an FME Male connector. Once mated with a suitable length cable assembly the joint should be sealed to prevent water ingress. A universal clamp is supplied for use on standard antenna poles. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.3 Oscar 3A GSM/GPRS, Yagi Antenna Electrical Specifications Impedance: Gain: VSWR: Max Power: Operating frequencies: Mechanical Specifications 50 Ohm 11dBi Dimensions: L570 x W180 x H36mm Connector: FME Male
PDF文档中包含以下信息:
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件具有多种通信接口,适用于多种工业和消费类应用。
3. 引脚分配:共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:详细介绍了各模块的功能和使用方法。
6. 应用信息:适用于电机控制、工业自动化等领域。
7. 封装信息:采用LQFP48封装。
OSCAR3A/X/FMEM/S/S/19 价格&库存
很抱歉,暂时无法提供与“OSCAR3A/X/FMEM/S/S/19”相匹配的价格&库存,您可以联系我们找货
  • 1+704.48567
  • 5+690.38533
库存:17
