TANGO43/2.5M/SMAM/SMAM/RP/S/S/17
    SIRETTA
    Tango 43系列将两个天线集成在一个封装中,适用于4G/WiFi路由器,支持本地和广域连接,具有小型防风雨设计。
TANGO43/2.5M/SMAM/SMAM/RP/S/S/17 数据手册
Combined LTE and Wifi antennas with 2.5M cables & SMA male connector for LTE and SMA male RP for Wifi TANGO43/2.5M/SMAM/SMAM/RP/S/S/17 Features two separate antennas in one package 46mm dia x 15mm deep bolt through antenna 1880 - 1900MHz GPRS + 2572 - 2635 MHz LTE 2400MHZ Wifi The Tango 43 family combines two antennas in one package similar to the Tango 24, Tango 19 and Tango 20 antennas. This formula has proved a very popular style of antenna combining small size with robust build and IP67 characteristics. The Tango 43 is ideal for 4G / Wifi router products now starting to be popular, typically the Siretta MICA and QUARTZ series of routers for example. The Tango 43 has a 12mm diameter stud to bolt the antenna to a surface. The maximum surface thicknes that the Tango43 can handle is around 10-11mm. The Tango 43 has 2.5M cables but other cable and connector variants are available. Specifications Electrical specifications: GSM frequencies: 1880-1900MHz + 2575-2635 MHz Wifi Frequencies: 2400MHz Wifi Gain 2dBi Polarisation: Vertical VSWR: ≤1.5 Max input power 60W Input impedance: 50 Ohm Mechanical specifications: size: 46mm dia x 15mm Cable type: RG174 LTE connector: SMA male Wifi connector: SMA male RP Mounting stud: 12mm dia x 15mm long ©Siretta Ltd 2016
TANGO43/2.5M/SMAM/SMAM/RP/S/S/17 价格&库存
很抱歉,暂时无法提供与“TANGO43/2.5M/SMAM/SMAM/RP/S/S/17”相匹配的价格&库存,您可以联系我们找货
  • 1+360.98525
  • 5+353.77888
库存:585
