Shockwave
Part No:
TLS.01.1F11
Description:
Shockwave Wideband 5G/4G Direct Mount External Antenna
With N Type(M) connector
Features:
Applicable for 5G/4G cellular bands
600-6000MHz Wideband Operational
Over 45% efficiency and 2.3 dBi gain
Mechanically robust for indoor/outdoor applications
Height: 79.45mm (3.13")
Diameter: 42mm(1.65")
IP67 Waterproof
N type(M) connector
RoHS & Reach Compliant
SPE-15-8-051-D
1.
Introduction
3
2.
Specifications
4
3.
Antenna Characteristics
6
4.
Radiation Patterns
8
5.
Mechanical Drawing
18
6.
Installation Guide
19
7.
Packaging
Changelog
21
Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to
make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and
the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited.
SPE-15-8-051-D
www.taoglas.com
2
1.
Introduction
1.
Introduction
1.
Introduction
1.
Introduction
1.
1.
1.
1.
Introduction
The Shockwave TLS.01.1F11 is a permanent mount, waterproof, external 5G/4G cellular operating at the
wideband 600- 6000MHz frequency with an N type male direct mount connector. It has been designed to be
used on a Ground Plane. It can be used in mobile and fixed applications for 5G/4G wireless such as:
Public safety
HD Video Streaming
Utilities and Smart Cities
Fleet Management
Agricultural
Industrial
Introduction
Introduction
This antenna has superior performance over wide-bands compared to traditional whip antennas. Up to 90%
efficiency and with a minimum 2.3dBi peak gain over all cellular bands result when mounted on a 30x30 cm
ground plane. Stable radiation patterns over low angles provides consistent gain in the horizontal plane,
meaning that it is especially suitable for cellular applications.
Introduction
A unique indent tab on the base of the antenna allows a wrench to be used to solidly lock the antenna on
top of its mounting location, where an N type female connector juts out from a metal panel. Waterproof Orings around the bottom base prevent water from leaking under the antenna.
The TLS.01 antenna is IP67 waterproof against short periods of immersion in water jets in commercial
cleaning environments, which makes the antenna ideal for 5G/4G/3G/Cat M/NB-IoT applications either in
indoor or in harsh outdoor environments. For more information contact your regional Taoglas customer
support team.
SPE-15-8-051-D
www.taoglas.com
3
2.
Specifications
3.
Antenna Characteristics2.
3.
Electrical
Specifications
Band
Frequency
(MHz)
Efficiency
Average Gain
(dB)
Peak Gain
(dBi)
5GNR/4G
Band 71
617~698
46.5
-3.2
-1
Antenna698~806
Characteristics
95.2
-0.2
3.1
4G/3G
Band 12,13,14,17,28,29
4G/3G/NB-IoT/Cat M
Band 5,8,18,19,20,26,27
824~960
84.5
-0.7
Impedance
Max Input Power
Polarization
Radiation Pattern
100W
Vertical
Omni-Directional
3.2
71.9 Patterns3.
-1.4
2.9
4.Band 5GNR/4G
Antenna1427~1518
Radiation
Antenna
21,32,74,75,76
50 Ω
4G/3G
Characteristics2.
Specifications
1710~2200
65.5
-1.8
Band
2.7
1,2,3,4,9,23,25,35,39,66
4G/3G
Band 7,38,41
2490~2690
62.7
-2
3.4
41.1
-4.1
3.Band 5GNR/4G
Antenna3300~3800
Characteristics2.
22,42,48,77,78
LTE5200/
Wi-Fi 5800
5150~5925
45.9
Specifications
2.5
-3.4
5.3
*Measured on 30*30cm ground plane
3.
4.
Mechanical
Dimension (mm)
Height: 79.45mm(3.13") ; Diameter : 42mm(1.65")
Connector
Direct Mount N type (M)
Housing Material
UV Resistant ABS
Antenna Radiation Patterns3.Antenna
Characteristics
4.
4.
Base Material
Nickel Plated Zinc Alloy
Weight (g)
130
Rec. Torque for Mounting
4.018 N∙m
Max. Torque for Mounting
9.8 N∙m
Environmental
Antenna
Waterproof Rating
IP67
Operation Temperature
-40°C to 85°C
Humidity
Non-condensing 65°C 95% RH
Characteristics
4.
Housing Rating Radiation Patterns3.Antenna IK10
Antenna
Characteristics2.
SPE-15-8-051-D
Specifications
www.taoglas.com
4
5G/4G Bands
Band Number
5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA / Cat M / NB-IoT
Uplink
Downlink
1
UL: 1920 to 1980
DL: 2110 to 2170
2
UL: 1850 to 1910
DL: 1930 to 1990
3
UL: 1710 to 1785
DL: 1805 to 1880
4
UL: 1710 to 1755
DL: 2110 to 2155
5
UL: 824 to 849
DL: 869 to 894
7
UL: 2500 to 2570
DL:2620 to 2690
8
UL: 880 to 915
DL: 925 to 960
9
UL: 1749.9 to 1784.9
DL: 1844.9 to 1879.9
11
UL: 1427.9 to 1447.9
DL: 1475.9 to 1495.9
12
UL: 699 to 716
DL: 729 to 746
13
UL: 777 to 787
DL: 746 to 756
14
UL: 788 to 798
DL: 758 to 768
17
UL: 704 to 716
DL: 734 to 746
18
UL: 815 to 830
DL: 860 to 875
19
UL: 830 to 845
DL: 875 to 890
UL: 832 to 862
DL: 791 to 821
21
UL: 1447.9 to 1462.9
DL: 1495.9 to 1510.9
22
UL: 3410 to 3490
DL: 3510 to 3590
23
UL:2000 to 2020
DL: 2180 to 2200
24
UL:1625.5 to 1660.5
DL: 1525 to 1559
25
UL: 1850 to 1915
DL: 1930 to 1995
26
UL: 814 to 849
DL: 859 to 894
27
UL: 807 to 824
DL: 852 to 869
28
UL: 703 to 748
DL: 758 to 803
29
UL: -
DL: 717 to 728
30
UL: 2305 to 2315
DL: 2350 to 2360
31
UL: 452.5 to 457.5
DL: 462.5 to 467.5
32
UL: -
DL: 1452 – 1496
35
1850 to 1910
38
2570 to 2620
39
1880 to 1920
40
2300 to 2400
41
2496 to 2690
42
3400 to 3600
43
3600 to 3800
3550 to 3700
48
66
UL: 1710-1780
DL: 2110-2200
71
617 to 698
74/75/76
1427 to 1518
77
3300 to 4200
78
3300 to 3800
79
4400 to 5000
SPE-15-8-051-D
Covered
www.taoglas.com
5
3.
4.
3.1
Return Loss
Characteristics
4.
4.
Characteristics
4.
Characteristics
3.2
Efficiency
4.
4.
4.
4.
Characteristics
4.
SPE-15-8-051-D
www.taoglas.com
6
3.3
Average Gain
3.4
Peak Gain
SPE-15-8-051-D
www.taoglas.com
7
4.
Radiation Patterns
4.
4.
4.1
Test Setup
4.
4.
4.
4.
4.
On 30*30cm Ground Plane
4.
SPE-15-8-051-D
www.taoglas.com
8
4.2
3D and 2D Radiation Patterns
652MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
9
751MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
10
890MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
11
1470MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
12
1805MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
13
1990MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
14
2595MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
15
3550MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
16
5530MHz
XY Plane
SPE-15-8-051-D
XZ Plane
YZ Plane
www.taoglas.com
17
5.
Mechanical Drawing (Units: mm)
6.
Packaging5.
6.
Packaging
7.
Application Note6. Packaging5.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-051-D
Mechanical Drawing
www.taoglas.com
18
6.
Installation
4.
Characteristics
4.
4.
Characteristics
4.
Characteristics
4.
4.
4.
4.
Characteristics
4.
SPE-15-8-051-D
www.taoglas.com
19
7.
Packaging
6.
Packaging5.
6.
Packaging
7.
Mechanical Drawing
Mechanical
Drawing
6.
Packaging5.
Mechanical Drawing
6.
Packaging
7.
7.
Application Note
7.
7.
Mechanical
Drawing
6.
Packaging5.
SPE-15-8-051-D
Mechanical Drawing
www.taoglas.com
Changelog for the datasheet
SPE-17-8-042 - OMB.868.B12F21
Revision: D (Current Version)
Date:
Changes:
Changes Made by:
2022-09-01
Updated specifications
Cesar Sousa
Previous Revisions
Revision: C
Date:
Changes:
Changes Made by:
2019-11-18
Included 5G data
Jack Conroy
Revision: B
Date:
Changes:
Changes Made by:
2017-03-30
Included LTE Table
Andy Mahoney
Revision: A (Original First Release)
Date:
Notes:
Author:
SPE-15-8-051-D
2015-10-11
Initial Release
Jack Conroy
www.taoglas.com
21
www.taoglas.com
SPE-15-8-051-D
© Taoglas 22
www.taoglas.com
很抱歉,暂时无法提供与“TLS.01.1F11”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+365.262321+47.24461
- 10+297.8348710+38.52325
- 30+278.1185030+35.97305
- 100+262.47124100+33.94917
- 250+253.64807250+32.80794
