YE572113-30RSMM
YE572113-30RSMM
    LAIRD(莱尔德)
    ANTENNAYAGI15DB25WSMA
YE572113-30RSMM 数据手册
Vertical or Horizontal Polarized Broadband Directional Antenna YE572113 5725-6000 MHz VERTICAL OR HORIZONTAL POLARIZED DIRECTIONAL ANTENNA The Laird YE572113 12.5 dBi gain directional antenna operates in the 5725-6000 MHz band and is designed to complement interior or exterior mounted wireless communication systems.The YE572113 directional antenna provides high gain performance and is configured with a 30 cm Plenum Rated cable terminated with an SMA connector. The YE572113 standard articulating arm mount enables either wall or mast mounting providing maximum installation flexibility. The Laird YE572113 high gain directional antenna is an excellent solution for both indoor and outdoor applications . FEATURES Patent Pending YE572113 MARKETS - APPLICATIONS • 12.5 dBi antenna gain. • SMA male connector with 30 cm (1’) RG58 Low Temperature Plenum Rated cable. • IP67 Rated, lightweight design for indoor & outdoor use. • UV Stable polycarbonate radome. •Standard articulating arm mount for mast or wall installations. •Performance engineered for optimum performance. PARAMETER • Wireless broadband systems • DSRC (Dedicated Short Range Communications) • ITS (Intelligent Transportation Systems) • Point-to-multi-point systems • WLAN access points SPECIFICATIONS Model Frequency Bands, MHz YE572113 5725 - 5850 5850 - 5925 5925 - 6000 Peak Gain, dBi (Avg) 12.5 13.0 12.7 Peak Gain, (Max) 13.2 13.2 12.9 VSWR, Avg 1.4:1 1.2:1 1.4:1 VSWR, Max 1.8:1 1.5:1 2.0:1 Nominal Impedance 50Ω Polarization Vertical or Horizontal Azimuth 3 dB Beamwidth 35° Elevation 3 dB Beamwidth 35° Front-to-Back Ratio 15 dB Side Lobe 14 dB Max Power (Ambient 25°C) 25 Watts Antenna Dimension (L x W) 149.1 x 58.6 mm (5.87” x 2.31”) Weight w/ Bracket 0.16 kg (0.35 lbs) Antenna Color White Radome ASA, UV Stable Wind Operational 160 km/h (100 mph) Wind Survival 220 km/h (136 mph) Operating Temperature -30°C to +70°C Storage Temperature -40°C to +80°C Ingression Protection IP67 Material Substance Compliance RoHS SPECIFICATIONS Americas: +1.847 839.6925 IAS-AmericasSales@lairdtech.com Europe: +44.1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com Middle East & Affrica: +44.1628.858941 IAS-MEASales@lairdtech.com www.lairdtech.com PART NUMBER CABLE LENGTH CONNECTOR YE572113-30SMAM 30 cm (12”) SMA Male YE572113-30RSMM 30 cm (12”) RP SMA Male Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Vertical or Horizontal Polarized Broadband Directional Antenna YE572113 RADIATION PATTERNS 5725 MHz 5850 MHz 5925 MHz 6000 MHz ANT-DS-YE572113 0117 Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in effect from time to time, a copy of which will be furnished upon request. © Copyright 2017 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trade marks or registered trade marks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
YE572113-30RSMM 价格&库存
很抱歉,暂时无法提供与“YE572113-30RSMM”相匹配的价格&库存,您可以联系我们找货
