TANGO6A/3M/SMAM/SMAF/RP/S/20
    SIRETTA
    Tango 6A 是一款坚固的鲨鱼鳍天线,结合了四频段2G和GPS天线,提供简单安装解决方案,节省时间和成本。
TANGO6A/3M/SMAM/SMAF/RP/S/20 数据手册
Tango 6A Combined 2G/GPRS & GPS Fin Antenna Key Features • Quad band 2G • GSM 2dBi Peak Gain • 28dB GPS LNA gain General Description Additional Considerations The Tango 6A is solid shark-fin antenna combining a quad band 2G and a GPS antenna into a single package. Providing a simple solution without the inconvenience of installing two separate antennas, saving installation time and cost. • Robust ABS design and rubber seal • Meets all EU compliance criteria for electronic goods Tango 6A is commonly used for applications such as asset tracking and fleet management. The antenna comes supplied as standard with 3 or 4m cables and SMA Male connectors. Alternative cable lengths and connector types may be specified for volume orders. Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.5 Tango 6A Combined 2G/GPRS & GPS Fin Antenna Electrical Specification Mechanical Specification GSM Antenna Dimensions: Center Frequency: 850/900/1800/1900 MHz VSWR: 2.0:1 Impedance: 50 Ohm 2dBi+/-1dBi@850MHz 2dBi+/-1dBi@900MHZ 1dBi+/-1dBi@1800MHz 1dBi+/-1dBi@1900MHz Typical Gain: GPS Dielectric Antenna Center Frequency: VSWR: Impedance: Peak Gain: Gain Coverage: Polarization: 1575.42 L84 x W54 x H65mm Connector: SMA Male Cable: RG174 Mounting Hole: 14mm Max Material Thickness: 3mm Environmental Specification Operating Temperature: -40 - +85˚C Storage Temperature: -45 - +100˚C Humidity: 95 - 100% RH 1.5:1 50 Ohm 3dBi (based on 7x7cm ground plane) 4dBi at -90˚ RHCP GPS LNA LNA Gain: 28dBi Typical Noise Figure: 1.5dB VSWR:
TANGO6A/3M/SMAM/SMAF/RP/S/20 价格&库存
很抱歉,暂时无法提供与“TANGO6A/3M/SMAM/SMAF/RP/S/20”相匹配的价格&库存,您可以联系我们找货
