TLS.20.105111
TLS.20.105111
    TAOGLASLIMITED
    TLS.20.105111
TLS.20.105111 数据手册
Shockwave 450-470MHz Permanent Mount Part No: TLS.20.105111 Description: Shockwave 450-470MHz Permanent Mount External Antenna 1m TGC-200 SMA(M) connector Features: CDMA 450-470MHz with 45% efficiency Mechanically robust for indoor/outdoor applications Height: 79.45mm(3.13") ; Diameter : 42mm(1.65") IP67 Waterproof 1 meter of low loss TGC-200 cable SMA(M) connector RoHS & REACH Compliant SPE-15-8-067-C 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 12 6. Installation Guide 13 7. Packaging 14 Changelog 15 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-15-8-067-C www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The Shockwave TLS.20.105111 is a mechanically robust, waterproof, external antenna operating at the 433MHz ISM band with 1 meter low loss TGC-200 cable and SMA(M) connector. It has been designed to be used on a ground plane. 1. Typical Applications Include: 1. 1. Introduction Introduction - Public safety Smart meters Mesh networks Transportation Introduction The antenna has greater than 45% efficiency and -0.71 dBi peak gain at CDMA 450-470MHz on a 30x30 cm ground plane. Stable radiation patterns over low angles provide consistent gain in the horizontal plane, meaning that it is especially suitable for mesh networks or hot spots. Introduction A unique indent tab on the base of the antenna allows a wrench to be used to solidly lock the antenna on top of its mounting location while tightening up the nut beneath the metal panel. Waterproof O-rings around the bottom base prevent water from leaking under the antenna. The TLS.20 antenna is IP67 waterproof resistant against high pressure water jets in commercial cleaning environments, which makes the antenna ideal for 450-470MHz applications in harsh outdoor environments. Cable lengths and connector types are customizable. Contact your regional Taoglas customer support team for further information. SPE-15-8-067-C www.taoglas.com 3 2. Specifications 3. ELECTRICAL Antenna Characteristics2. Specifications Operation Band CDMA450 Operation Frequency(MHz) 450 460 470 Efficiency (%) 45.50 54.28 53.34 -1.33 -0.71 -0.79 -3.23 -2.65 -2.72 On 30 x 30 cm ground plane 3. Antenna PeakCharacteristics Gain (dBi) Average Gain (dBi) 4. Return Loss (dB) < -5 Impedance 50 Ω AntennaPolarization Radiation Patterns3.Antenna Vertical Radiation Property Omni-Directional Max Input Power Characteristics2. Specifications 100 W MECHANICAL 3. 3. Dimension (mm) Height: 79.45mm(3.13") ; Diameter : 42mm(1.65") Cable 1 meter TGC-200 AntennaConnector Characteristics2. Specifications SMA(M) Material Housing : UV Resistant ABS , Base : Nickel Plated Zinc Alloy Weight (g) 205 Rec. Torque for Mounting Antenna Characteristics 4.018 N.m Max. Torque for Mounting 9.8 N.m ENVIRONMENTAL Waterproof Rating 4. IP67 Antenna Radiation Patterns3.Antenna Operation Temperature -40°C to 85°C Humidity Non-condensing 65°C 95% RH Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-15-8-067-C Specifications www.taoglas.com 4 3. Antenna Characteristics 3.1 Return Loss 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-15-8-067-C www.taoglas.com 5 3.3 Average Gain 3.4 Peak Gain SPE-15-8-067-C www.taoglas.com 6 4. 6. Radiation Patterns 4.1 Test Setup Packaging5. Mechanical Drawing The TLS.20 antenna is tested in a CTIA certified ETS-Lindgren Anechoic Chamber. The test setup ishown below. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-067-C Mechanical Drawing www.taoglas.com 7 4.2 2D radiation Patterns XY Plane XZ Plane SPE-15-8-067-C www.taoglas.com 8 YZ Plane SPE-15-8-067-C www.taoglas.com 9 4.3 3D radiation Patterns 450MHz 460MHz SPE-15-8-067-C www.taoglas.com 10 470MHz SPE-15-8-067-C www.taoglas.com 11 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-067-C Mechanical Drawing www.taoglas.com 12 8. 6. Packaging Guidelines Installation 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-067-C Mechanical Drawing www.taoglas.com 13 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-067-C Mechanical Drawing www.taoglas.com 14 Changelog for the datasheet SPE-15-8-067 – TLS.20.10511 Revision: C (Current Version) Date: Changes: Changes Made by: 2022-09-19 Updated specifications Cesar Sousa Previous Revisions Revision: B Date: Changes: Changes Made by: 2019-01-14 Updated drawing Jack Conroy Revision: A (Original First Release) Date: Notes: 2021-09-28 Author: Jack Conroy SPE-15-8-067-C www.taoglas.com 15 www.taoglas.com SPE-15-8-067-C © Taoglas 16 www.taoglas.com
TLS.20.105111 价格&库存
很抱歉,暂时无法提供与“TLS.20.105111”相匹配的价格&库存,您可以联系我们找货
TLS.20.105111
  • 100+510.78528100+66.07788
