TLS.01.305721
TLS.01.305721
    TAOGLASLIMITED
    TLS.01.305721
TLS.01.305721 数据手册
Shockwave Part No: TLS.01.305721 Description: Shockwave 600-6000MHz Permanent Mount External Antenna with 3m TGC-200 FAKRA Code D Features: Applicable for 5G/4G, Cat M1 & NB-IoT bands Over 45% efficiency and 2.2 dBi gain Mechanically robust for indoor/outdoor applications Height: 79.45mm (3.13"); Diameter: 42mm (1.65") IP67 Waterproof IK10 Rated Enclosure Cable: Low loss TGC-200 cable, 3 meters Connector: FAKRA Code D RoHS & Reach Compliant SPE-15-8-064-G 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing 18 6. Installation Guidelines 19 7. Packaging 20 8. Application Note 21 Changelog 23 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-15-8-064-G www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. Introduction The Shockwave TLS.01.305721 is a permanent mount, waterproof, external 5G/4G cellular wideband antenna operating at 600-6000MHz with an N type male connector. It has been designed to be used on a Ground Plane. It can be used in mobile and fixed applications for 4G wireless such as: • Public safety • HD Video Streaming • Utilities and Smart Cities • Fleet Management • Agricultural • Industrial Introduction Introduction This antenna has superior performance over wide-bands compared to traditional whip antennas. Up to 77% efficiency and with a minimum 2.2dBi peak gain over all cellular bands result when mounted on a 30x30 cm ground plane. Stable radiation patterns over low angles provides consistent gain in the horizontal plane, meaning that it is especially suitable for cellular applications. Introduction A unique indent tab on the base of the antenna allows a wrench to be used to solidly lock the antenna on top of its mounting location while tightening up the nut beneath the metal panel. Waterproof O-rings around the bottom base prevent water from leaking under the antenna. The TLS.01 antenna is IP67 waterproof resistant against short periods of immersion in water jets in commercial cleaning environments, which makes the antenna ideal for 5G/4G applications either in indoor or in harsh outdoor environments. For more information contact your regional Taoglas customer support team. SPE-15-8-064-G www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. 3. Electrical Specifications Band Frequency (MHz) Efficiency (%) Average Gain (dB) Peak Gain (dBi) 5GNR/4G Band 71 617~698 43 -3.2 -1 Antenna698~806 Characteristics 57.7 -0.2 3.1 4G/3G Band 12,13,14,17,28,29 4G/3G/NB-IoT/Cat M Band 5,8,18,19,20,26,27 824~960 71.4 -0.7 Impedance Max Input Power Polarization Radiation Pattern 100W Vertical Omni-Directional 3.2 56.8 Patterns3. -1.4 2.9 4.Band 5GNR/4G Antenna1427~1518 Radiation Antenna 21,32,74,75,76 50 Ω 4G/3G Characteristics2. Specifications 1710~2200 45.9 -1.8 Band 2.7 1,2,3,4,9,23,25,35,39,66 4G/3G Band 7,38,41 2490~2690 42.9 -2 3.4 5GNR/4G 26.8 -4.1 3. Antenna3300~5000 Characteristics2. Band 22,42,48,77,78,79 LTE5200/ Wi-Fi 5800 5150~5925 8.9 Specifications 2.5 -3.4 5.3 *Measured on 30*30cm ground plane 3. 4. Antenna Characteristics Mechanical Dimension (mm) Height: 79.45mm(3.13") ; Diameter : 42mm(1.65") Connector SMA(M)ST Antenna Radiation Patterns3.Antenna Cable 3m TGC-200 Housing Material Characteristics UV Resistant ABS Base Material Nickel Plated Zinc Alloy Weight (g) 270 for Mounting 4. Rec. Torque Antenna Radiation Patterns 4.018 N∙m Max. Torque for Mounting 9.8 N∙m Environmental 4. Antenna Radiation Patterns3.AntennaIP67 Waterproof Rating Operation Temperature Characteristics 4. -40°C to 85°C Humidity Non-condensing 65°C 95% RH Housing Rating IK10 Antenna Radiation Patterns3.Antenna SPE-15-8-064-G Characteristics2. Specifications www.taoglas.com 4 5G/4G Bands Band Number 5GNR / FR1 / LTE / LTE-Advanced / WCDMA / HSPA / HSPA+ / TD-SCDMA / Cat M / NB-IoT Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 18 UL: 815 to 830 DL: 860 to 875 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 28 UL: 703 to 748 DL: 758 to 803 29 UL: - DL: 717 to 728 30 UL: 2305 to 2315 DL: 2350 to 2360 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 32 UL: - DL: 1452 – 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 48 3550 to 3700 66 UL: 1710-1780 DL: 2110-2200 71 617 to 698 74/75/76 1427 to 1518 77 3300 to 4200 78 3300 to 3800 79 4400 to 5000 SPE-15-8-064-G Covered ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  www.taoglas.com 5 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna TLS.01.305721 Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 Efficiency 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna TLS.01.305721 Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-15-8-064-G www.taoglas.com 6 3.3 Average Gain TLS.01.305721 3.4 Peak Gain dBi TLS.01.305721 SPE-15-8-064-G www.taoglas.com 7 4. Radiation Patterns 4. 4. 4.1 Antenna Radiation Patterns Test Setup 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 30*30cm Ground Plane 4. Antenna Radiation Patterns SPE-15-8-064-G www.taoglas.com 8 4.2 652MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 9 4.3 751MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 10 4.4 890MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 11 4.5 1470MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 12 4.6 1805MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 13 4.7 1920MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 14 4.8 1990MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 15 4.9 2595MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 16 4.10 3550MHz 3D and 2D Radiation Patterns XY Plane SPE-15-8-064-G XZ Plane YZ Plane www.taoglas.com 17 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-064-G Mechanical Drawing www.taoglas.com 18 6. Installation Guidelines 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-15-8-064-G www.taoglas.com 19 8. 7. Packaging 6. Packaging5. 6. Packaging 7. Mechanical Drawing TLS.01.305721 Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-15-8-064-G Mechanical Drawing www.taoglas.com 20 8. Packaging Note Application Efficiency 6.8.1 Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. 8.2 Mechanical Drawing Peak Gain Mechanical Drawing 6. Packaging5. SPE-15-8-064-G Mechanical Drawing www.taoglas.com 21 8.3 Average Gain SPE-15-8-064-G www.taoglas.com 22 Changelog for the datasheet SPE-15-8-064 – TLS.01.305721 Revision: G (Current Version) Date: Changes: Changes Made by: 2022-09-15 Updated specifications Cesar Sousa Previous Revisions Revision: F Revision: A (Original First Release) Date: Changes: Changes Made by: 2018-12-03 Updated to show 5G Jack Conroy Date: Notes: 2015-11-27 Author: Jack Conroy Revision: E Date: Changes: Changes Made by: 2019-01-14 Mechanical Drawing Jack Conroy Revision: D Date: Changes: Changes Made by: 2018-03-27 Installation Guide Amended Jack Conroy Revision: C Date: Changes: 2017-03-30 Bands Updated Changes Made by: Andy Mahoney Revision: B Date: Changes: Changes Made by: SPE-15-8-064-G 2016-11-07 Packaging Details Updated Andy Mahoney www.taoglas.com 23 www.taoglas.com SPE-15-8-064-G © Taoglas 24 www.taoglas.com
TLS.01.305721 价格&库存
很抱歉,暂时无法提供与“TLS.01.305721”相匹配的价格&库存,您可以联系我们找货
