ANT-WS-A-NF-09
ANT-WS-A-NF-09
    ATOPTECHNOLOGIES(上尚)
ANT-WS-A-NF-09 数据手册
IEEE 802.11 Antennas Model Name ANT-WD-A-RF-0305 ANT-WS-AB-RM-05-180 ANT-WS-AB-RM-05-200 Frequency Range ANT-WS-A-NF-09 ANT-WS-A-NF-09-150 2.4/5 GHz 2.4 GHz 2.4 GHz 2.4~2.5 GHz 2.4~2.5 GHz Omni-directional Omni-directional Omni-directional Omni-directional Omni-directional Typical Antenna Gain 3/5 dBi 5 dBi 5 dBi 9 dBi 9 dBi Impedance 50 Ohm 50 Ohm 50 Ohm 50±5 Ohm 50±5 Ohm Polarization Linear Vertical Vertical Vertical Linear Linear - RG-316 RG-174 - RG-58/U 360° 360° 360° 360° 360° - - - 10° 10° ≦2 ≦2 ≦2 1:1.3 Max 1:1.3 Max - - - 15W max 15W max RP-SMA(Male) RP-SMA(Male) RP-SMA(Male) N-type(Female) N-type(Female) - RP-SMA(Female) to RP-SMA(Female) to - N-type(Male) to RP-SMA(Male) RP-SMA(Male) -20~65°C -20~65°C -30~85°C -20~60°C -20~60°C 160mm length 236.4mm length 196.6mm length 420mm length 420mm length with 180cm cable with 200cm cable 166g 125g Radiation Cable Type HPBW / Horizontal HPBW / Vertical V.S.W.R Power Handling Antenna Connector Cable Connector Operating Temperature Antenna Profile Weight 26g RP-SMA(Male) with 150cm cable 430g 520g Ordering Information ANT-WD-A-RF-0305 IEEE 802.11 a/b/g 2.4/5 GHz, Dual Band, omni-directional antenna, 3/5dBi, RP-SMA(F) ANT-WS-AB-RM-05-180 IEEE 802.11 b/g 2.4 GHz, Single Band, omni-directional antenna, 5dBi, RP-SMA(M), with 180cm Cable, with Base ANT-WS-AB-RM-05-200 IEEE 802.11 b/g 2.4 GHz, Single Band, omni-directional antenna, 5dBi, RP-SMA(M), with 200cm Cable, with Base ANT-WS-A-NF-09 IEEE 802.11 b/g 2.4~2.5 GHz, Single Band, omni-directional antenna, 9dBi, N-type(F) ANT-WS-A-NF-09-150 IEEE 802.11 b/g 2.4~2.5 GHz, Single Band, omni-directional antenna, 9dBi, N-type(F), with150 cm cable Connector Types N Type (Male) N Type (Female) RP-SMA Type (Male) RP-SMA Type (Female) SMA Type (Male) SMA Type (Female) Atop Technologies, Inc. Technologies TEL:+886-3-5508137 FAX:+886-3-5508131 sales@atop.com.tw http://www.atop.com.tw Design and specification are subjected to change without notice. All product names referenced herein are registered trademarks of their respective companies. CA_Antenna_E:v1-110830
ANT-WS-A-NF-09 价格&库存
很抱歉,暂时无法提供与“ANT-WS-A-NF-09”相匹配的价格&库存,您可以联系我们找货
