FHQ69273CD-518VC3
FHQ69273CD-518VC3
    LAIRD(莱尔德)
    ANT4G-LTE/GPS/UHF/WIFIROOFMNT
FHQ69273CD-518VC3 数据手册
Phantom Fin Multiband Roof Mount Antenna FHQ69273CD PHANTOM FIN 4G/LTE, GPS, UHF & WLAN ROOF MOUNT ANTENNA The Laird Phantom Fin multiband antenna provides an excellent solution for the public safety, transportation and after market fleet applications. The Phantom Fin requires only (1) one single hole mount/fixing which reduces vehicle damage, cost of installation and visual impact. The Phantom Fin design provides multiple antenna functions while remaining discrete. The Phantom Fin multiband antenna integrates 4G/LTE, GPS, UHF and WLAN frequency operation into one aerodynamic housing. FEATURES MARKETS • One (1) single hole mount/fixing which reduces vehicle damage and cost of installation. • Attractive, IP67 rated aerodynamic housing excellent for overt and/or discrete installations. • • • • Public Safety Transportation Aftermarket Fleet Land Mobile Radio • Multiband 4G/LTE,GPS,UHF, and WLAN frequency operation. SPECIFICATIONS PARAMETER PERFORMANCE Antenna Model / No. of Ports: FHQ69273CD 4 ports Port ID Frequency Bands, MHz Patent Pending Americas: +1.847 839.6925 IAS-AmericasEastSales@lairdtech.com Europe: +44.(0).1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com www.lairdtech.com 698-960 MHz 1710-2700 MHz 2400-2500 MHz 4900-5875 MHz 380-430 MHz Peak Gain, Typical dBi 3.4 dBi 5.5 dBi 6.6 dBi 6.2 dBi 2.0 dBi Peak Gain, Maximum dBi 4.0 dBi 6.4 dBi 7.1 dBi 7.8 dBi 2.6 dBi Max Gain ± 30° Above Horizon, dBi N/A N/A N/A 4.1 dBi N/A VSWR*, Typical < 1.9:1 < 1.5:1 < 1.3:1 < 1.3:1 < 1.6:1 VSWR*, Max < 2.0:1 < 2.0:1 < 2.0:1 < 2.0:1 < 2.0:1 Port-to-Port Isolation, Maximum (Typical) UHF-LTE > 15 dB (18 dB) UHF-WiFi > 20 dB (31 dB) LTE-WiFi > 20 dB (23 dB) Nominal Impedance 50 Ohms Polarization Vertical Linear Azimuth Beam Width Omnidirectional Input Power, Max 10 watt (ambient temp. of 25°C / 77°F Operating Temparture - 30°C to + 70°C ( - 22°F to + 158°F ) Storage Temparture - 40°C to + 85°C ( - 40°F to + 185°F ) Dimensions mm (inches) 98 x 70 x 160 ( 3.9"x 2.7" x 6.30") Weight Kg (lbs.) Approximately 0.52 Kg (1.15 lbs.) Cable LMR-100 ( 5.18 m / 17 ft.) Radome Material PC/ASA (Black) Baseplate Material Aluminum Material Compliance RoHS Compliant IP Dust & Water Ingress Rating IP67 Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Phantom Fin Multiband Roof Mount Antenna FHQ69273CD SPECIFICATIONS - GPS PARAMETER PERFORMANCE Frequency Band 1575.42 MHz (GPS L1) Band Width 6 MHz (Typical) Amplifier Gain 27 dB ± 3 dBc Nominal Impedance 50 Ohm Output VSWR < 1.5:1 DC Voltage 2.7 -12 Vdc DC Current 20 mA (Nominal); 40 dB rejection @ ± 50 MHz from center frequency Intermodulation @ CW Mode (-40°C to +85°C) Int1 - 10 (1842.8 MHz) - 10 (829.58 MHz) - 10 (755.42 MHz) Input 1 dB Compression @ 750 MHz, 2000 MHz & 3500 MHz > 10dBm (-40°C to +85°C) Cable - Exposed Length RG174-518.2 cm (17 ft.) Int2 - 10 (2110 MHz) - 10 (2405 MHz) - 10 (820 MHz) IM3
FHQ69273CD-518VC3
- 物料型号:FHQ69273CD - 器件简介:该天线设计优雅,具有IP67等级的防水防尘特性,适用于明显或隐蔽安装。 - 引脚分配:4个端口,分别为4G/LTE、WiFi、UHF和GPS。 - 参数特性: - 频率波段包括698-960 MHz、1710-2700 MHz、2400-2500 MHz(4G/LTE、WiFi)、4900-5875 MHz(UHF)、380-430 MHz(UHF GPS)。 - 增益范围从2.0 dBi(UHF)到7.8 dBi(WiFi)。 - 电压驻波比(VSWR)典型值小于1.5:1,最大值小于2.0:1。 - 端口间隔离度大于15 dB(UHF-LTE)和20 dB(UHF-WiFi)。 - 功能详解:天线集成了多频段操作,具有全向辐射模式和垂直线性极化。 - 应用信息:适用于陆地移动无线电、公共安全、交通和售后市场车队。 - 封装信息:尺寸为98x70x160毫米(3.9x2.7x6.30英寸),重量约为0.52千克(1.15磅)。电缆为LMR-100(5.18米/17英尺),天线罩材料为PC/ASA(黑色),基板材料为铝。
FHQ69273CD-518VC3 价格&库存
很抱歉,暂时无法提供与“FHQ69273CD-518VC3”相匹配的价格&库存,您可以联系我们找货
