FHQ69273CE-518VC5
FHQ69273CE-518VC5
    LAIRD(莱尔德)
    ANT4G-LTE/GPS/UHF/WIFIROOFMNT
FHQ69273CE-518VC5 数据手册
Phantom Fin Multiband Roof Mount Antenna FHQ69273CE PHANTOM FIN 4G/LTE, GPS, UHF & WLAN ROOF MOUNT ANTENNA The Laird Phantom Fin multiband antenna provides an excellent solution for the public safety, transportation and after market fleet applications. The Phantom Fin requires only (1) one single hole mount/fixing which reduces vehicle damage, cost of installation and visual impact. The Phantom Fin design provides multiple antenna functions while remaining discrete. The Phantom Fin multiband antenna integrates 4G/LTE, GPS, UHF and WLAN frequency operation into one aerodynamic housing. FEATURES MARKETS • One (1) single hole mount/fixing which reduces vehicle damage and cost of installation. • Attractive IP67 aerodynamic housing excellent for overt and/or discrete installations. • • • • Public Safety Transportation Aftermarket Fleet Land Mobile Radio • Multiband 4G/LTE,GPS,UHF, and WLAN frequency operation. SPECIFICATIONS PARAMETER PERFORMANCE Antenna Model / No. of Ports: FHQ69273CE 4 ports Port ID Frequency Bands, MHz Patent Pending Americas: +1.847 839.6925 IAS-AmericasEastSales@lairdtech.com Europe: +44.(0).1628.858941 IAS-EUSales@lairdtech.com Asia: IAS-AsiaSales@lairdtech.com www.lairdtech.com 698-960 MHz 1710-2700 MHz 2400-2500 MHz 4900-5875 MHz 430-520 MHz Peak Gain, Typical dBi 3.5 dBi 5.4 dBi 6.5 dBi 6.5 dBi 2.1 dBi Peak Gain, Maximum dBi 4.1 dBi 7.1 dBi 7.3 dBi 8.2 dBi 2.5 dBi Max Gain ± 30° Above Horizon, dBi N/A N/A N/A 3.6 dBi N/A VSWR*, Typical < 1.8:1 < 1.4:1 < 1.3:1 < 1.3:1 < 1.7:1 VSWR*, Max < 2.0:1 < 2.0:1 < 2.0:1 < 2.0:1 < 2.0:1 Port-to-Port Isolation, Maximum (Typical) UHF-LTE UHF-WiFi LTE-WiFi Nominal Impedance 50 Ohms Polarization Vertical Linear Azimuth Beam Width Omnidirectional Input Power, Max 10 watt (ambient temp. of 25°C / 77°F > 15 dB (15 dB) > 20 dB (35 dB) > 20 dB (22 dB) Operating Temparture - 30°C to + 70°C ( - 22°F to + 158°F ) Storage Temparture - 40°C to + 85°C ( - 40°F to + 185°F ) Dimensions mm (inches) 98 x 70 x 160 ( 3.9"x 2.7" x 6.30") Weight Kg (lbs.) Approximately 0.52 Kg (1.15 lbs.) Cable LMR-100 ( 5.18 m / 17 ft.) Radome Material PC/ASA (Black) Baseplate Material Aluminum Material Compliance RoHS Compliant IP Dust & Water Ingress Rating IP67 Laird warrants to the original end user customer of its products that its products are free from defects in material and workmanship. Subject to conditions and limitations Laird will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty is in force for the useful lifetime of the original end product into which the Laird product is installed. Useful lifetime of the original end product may vary but is not to exceed five (5) years from the original date of the end product purchase. Phantom Fin Multiband Roof Mount Antenna FHQ69273CE SPECIFICATIONS - GPS PARAMETER PERFORMANCE Frequency Band 1575.42 MHz (GPS L1) Band Width 6 MHz (Typical) Amplifier Gain 27 dB ± 3 dBc Nominal Impedance 50 Ohm Output VSWR < 1.5:1 DC Voltage 2.7 -12 Vdc DC Current 20 mA (Nominal); 40 dB rejection @ ± 50 MHz from center frequency Intermodulation @ CW Mode (-40°C to +85°C) Int1 - 10 (1842.8 MHz) - 10 (829.58 MHz) - 10 (755.42 MHz) Input 1 dB Compression @ 750 MHz, 2000 MHz & 3500 MHz > 10dBm (-40°C to +85°C) Cable - Exposed Length RG174-518.2 cm (17 ft.) IM3
FHQ69273CE-518VC5 价格&库存
很抱歉,暂时无法提供与“FHQ69273CE-518VC5”相匹配的价格&库存,您可以联系我们找货
