OMB.433.B03F21
OMB.433.B03F21
    TAOGLASLIMITED
    OMB.433.B03F21
OMB.433.B03F21 数据手册
Barracuda Part No: OMB.433.B03F21 Description: Barracuda - 433MHz 3dBi Omni Directional Outdoor Antenna with N Type Female Connector, U-Bolt, 523mm Length Features: Omni-Directional Radiation Pattern Collinear 3dBi Peak gain, 433 MHz Fiberglass Housing Robust design for all weather operation IP65 Waterproof Length: 553mm, Weight: 350g N type Female connector Wall/Pole Mount bracket included RoHS & Reach Compliant SPE-16-8-019-F 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 11 6. Packaging 12 7. Antenna Installation Guide 13 Changelog 14 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-8-019-F www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The OMB.433.B03F21 is a fiberglass Omni-directional outdoor antenna, operating in the 433 MHz ISM band. The antenna is designed for applications such as metering, industrial / environmental monitoring, remote asset monitoring, and mesh network applications. 1. The OMB.433 operates at 433MHz, one of the most widely used license free ISM bands, with a 3dBi peak gain. The omni-directional antenna radiates uniformly in the azimuth. This collinear design characteristic provides the best performance, giving optimized coverage and therefore longer range in the horizontal plane over 360 degrees, thus minimizing the amount of nodes needed for a mesh network. 1. 1. Introduction Introduction Introduction The UV resistant fiberglass housing enables the OMB antenna to be utilized in all kinds of harsh environments, making it more robust and safer than traditional whip antennas. It can be connected directly to the access point or telemetry unit, or can be mounted on wall or device surface via the N-type connector. Introduction Another larger model, the OMB.433.B06F21 with 6dBi peak gain, also working in the 433MHz ISM band, is also available. Gain and connector customizable, subject to MOQ. SPE-16-8-019-F www.taoglas.com 3 2. Specifications Electrical 3. 3. 4. Frequency (MHz) Antenna Characteristics2. 433 Specifications Antenna Type Collinear Dipole Array Peak Gain 3 dB Polarization Vertical Impedance Characteristics Antenna 50 ohms Max Input Power 100 watts VSWR 1.5:1 Radiation Omni-Directional Antenna Radiation Patterns3.Antenna60 Deg Vertical Beamwidth Horizontal Beamwidth Characteristics2. Internal Material 360 Deg Specifications Copper Connector N Type Female Mechanical 3. 3. 4. Length Characteristics2. Antenna Radome Diameter 24mm Bracket Dimension 70 x 53mm (Max) Antenna Weight 350g Mounting Accessories Weight 70g Application Indoor/Outdoor Radome Material White Fiberglass Bracket Material Aluminium Antenna Characteristics Antenna Radiation Patterns3.Antenna Mount Style Pole Mount/Wall Mount U Bolt Characteristics 4. 4. 553 mm (Max) Specifications Stainless Steel Wind Resistance >150mph (>241km/h) Waterproof IP65 Environmental Antenna Radiation Patterns Storage Temperature -40°C to +85°C Operating Temperature -40°C to +85°C Operating Humidity 10%~90% non-condensing Storage Humidity 5%~90% non-condensing Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-16-8-019-F Specifications www.taoglas.com 4 3. Antenna Characteristics ISM 433Radiation Patterns3.Antenna 4.3.1 Antenna Return Loss Characteristics 0 OMB.433 4. -5 Antenna Radiation Patterns -10 -15 (dB) 4. Antenna Radiation Patterns3.Antenna Characteristics -20 -25 4. -30 Antenna Radiation Patterns3.Antenna 420 425 430 Characteristics 435 440 450 (MHz) 445 Efficiency 4. Antenna Radiation Patterns 100 90 (%) 4. 4. 80 Antenna Radiation Patterns 70 60 50 Antenna Radiation Patterns 40 30 4. 20 Antenna Radiation Patterns3.Antenna 10 0 Characteristics 425 426 427 4. OMB.433.B03F21 428 429 430 431 432 433 434 435 Antenna Radiation Patterns3.Antenna SPE-16-8-019-F 436 437 438 439 440 (MHz) www.taoglas.com 5 Average Gain 10 OMB.433.B03F21 (dB) 5 0 -5 -10 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 (MHz) Peak Gain 10 OMB.433.B03F21 (dBi) 5 0 -5 -10 425 426 SPE-16-8-019-F 427 428 429 430 431 432 433 434 435 436 437 438 439 440 (MHz) www.taoglas.com 6 4. Radiation Patterns 4. 4. 4.1 Test Setup Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-16-8-019-F www.taoglas.com 7 4.2 430MHz 3D and 2D Radiation Patterns XZ Plane SPE-16-8-019-F YZ Plane XY Plane www.taoglas.com 8 4.3 433 MHz 3D and 2D Radiation Patterns XZ Plane SPE-16-8-019-F YZ Plane XY Plane www.taoglas.com 9 4.4 436 MHz 3D and 2D Radiation Patterns XZ Plane SPE-16-8-019-F YZ Plane XY Plane www.taoglas.com 10 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-019-F Mechanical Drawing www.taoglas.com 11 6. Packaging 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-019-F www.taoglas.com 12 7. Antenna Installation Guide 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-019-F www.taoglas.com 13 Changelog for the datasheet SPE-16-8-019 – OMB.433.B03F21 Revision: F (Current Version) Date: Notes: Author: 2019-09-02 Updated template, added Return Loss, Efficiency, Average Gain Yu Kai Yeung Previous Revisions SPE-16-8-019-F www.taoglas.com 14 www.taoglas.com © Taoglas SPE-16-8-019-F www.taoglas.com 15
OMB.433.B03F21 价格&库存
很抱歉,暂时无法提供与“OMB.433.B03F21”相匹配的价格&库存,您可以联系我们找货
