MA750.B.ABICG.003
MA750.B.ABICG.003
    TAOGLASLIMITED
    Pantheon MA750 5-in-1 Permanent Mount Antenna 是一种全向重型、完全防水的外部 M2M 天线,适用于远程信息处理、运输和远程监控应用。该天线提供了强大的 5...
MA750.B.ABICG.003 数据手册
SPECIFICATION Part No. : MA750.A.ABICG.003 Product Name : Pantheon Antenna 5in1 MA.750 Screw-Mount (Permanent Mount) 2G/3G/4G MIMO/ GPS/GLONASS/ 2.4/5GHz MIMO Feature : ● 2 x cellular (2G/3G/4G) Antennas (MIMO) (698~960MHz, 1710~2170MHz,2300~2700MHz, 2900-3500MHz) • 1*MIMO main antenna • 1*MIMO diversity antenna ● 1 x GPS/GLONASS 1575.42/1602MHz Active Antenna ● 2 x 2.4GHZ/ 5GHz Antennas (MIMO) • 1*MIMO main antenna • 1*MIMO diversity antenna IP67 Waterproof Front End SAW Filter High Efficiency / Peak Gain Outdoor Antenna RoHS Compliant SPE-12-8-146/I/PK Page 1 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 1. Introduction The MA.750 Pantheon antenna is an omni-directional heavy-duty, fully IP67 waterproof external M2M antenna for use in telematics, transportation and remote monitoring applications. This unique antenna delivers powerful MIMO antenna technology for cellular/LTE and Wi-Fi 802.11n and emerging 802.11ac, plus GPS/GLONASS for next generation multiple wireless technology systems, such as telematics. The GPS/GLONASS antenna has a Front End SAW Filter. Examples are new fleet management and real time video applications that demand high speed video uplink and downlink. High efficiency and high gain MIMO antennas are necessary to achieve the required signal to noise ratio and throughput required to solve these challenges. Five (5) high performance antennas are integrated into an extremely robust IP67 direct/permanent mount antenna package with excellent isolation (20dB+). The antenna has its own ground-plane and can radiate on any mounting environment like metal or plastic without affecting performance. The cables are low loss allowing for lengths of up to 10 meters (32' and 9.70 "), critical for buses, trains and other commercial transport applications. Customized cables and connector version available. SPE-12-8-146/I/PK Page 2 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 2. Specification Table 2G/3G/4G MIMO Frequency 698~960 1710~2170 2300~2700 VSWR 3 Max Polarization Vertical Impedance 50 2900-3500 MHz Ω 2.4GHz/ 5GHz MIMO Frequency 2.4~2.5 4.5~5.85 VSWR 2 Max Polarization Linear Impedance 50 GHz Ohm GPS-GLONASS Centre Frequency 1575.42MHz / 1602MHz Bandwidth 10MHz Radiation Efficiency 50(without cable) Passive Gain @ 4.0 typ(with ψ=140mm ground) Zenith VSWR 2 Impedance 50Ω DC Power Input 3 ~ 5V Range DC input MHz 3.3V 4.0V 5.5V 1575.42 1602 1575.42 1602 1575.42 1602 2 2 2 2 2 2 29.2 29 31 31 32.3 32 Noise Figure 3.1 3.1 3.2 3.2 3.4 3.4 Power Consumption 7.5 7.5 9.4 9.4 15 15 VSWR LNA Gain Band Attenuation Cable Connector 1520MHz: -20dB 1520MHz: -20dB 1520MHz: -20dB 1642MHz: -20dB 1642MHz: -20dB 1642MHz: -20dB 3m RG-174 standard, fully customizable SMA(M) standard, fully customizable SPE-12-8-146/I/PK Page 3 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 MECHANICAL Antenna Dimensions Height 85.7mm x Diameter 145.6mm Casing Wonderloy PC-540 PC/ABS Alloy Waterproof IP67 2G/3G/4G MIMO 1 3M CFD-200 SMA(M) 2G/3G/4G MIMO 2 3M CFD-200 SMA(M) 2.4/5GHz MIMO 1 3M CFD-200 RP-SMA(M) 2.4/5GHz MIMO 2 3M CFD-200 RP-SMA(M) GPS/GLONASS 3M RG-174 SMA(M) Base and thread CAN10 Zinc Alloy Thread diameter M30 x 2 (30mm) Nut Nickel Plated Steel Foam 3M 9448HK Waterproof IP67 1.29(antenna) 1.53(with box) Weight(kg) Recommended Torque for Mounting Max Torque for Mounting 49 N∙m 58.8N∙m ENVIRONMENTAL Operation Temperature -40°C to 85°C Storage Temperature -40°C to 90°C Humidity Non-condensing 65°C 95% RH * all measurements were conducted with 3m low loss CFD200 cable SPE-12-8-146/I/PK Page 4 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 LTE BANDS Band Number LTE/LTE- Advanced /WCDMA/HSPA.HSPA+ Uplink Downlink 1 UL: 1920 to 1980 DL: 2110 to 2170 2 UL: 1850 to 1910 DL: 1930 to 1990 3 UL: 1710 to 1785 DL: 1805 to 1880 4 UL: 1710 to 1755 DL: 2110 to 2155 5 UL: 824 to 849 DL: 869 to 894 7 UL: 2500 to 2570 DL:2620 to 2690 8 UL: 880 to 915 DL: 925 to 960 9 UL: 1749.9 to 1784.9 DL: 1844.9 to 1879.9 11 UL: 1427.9 to 1447.9 DL: 1475.9 to 1495.9 12 UL: 699 to 716 DL: 729 to 746 13 UL: 777 to 787 DL: 746 to 756 14 UL: 788 to 798 DL: 758 to 768 17 UL: 704 to 716 DL: 734 to 746 (LTE only) 18 UL: 815 to 830 DL: 860 to 875 (LET only) 19 UL: 830 to 845 DL: 875 to 890 20 UL: 832 to 862 DL: 791 to 821 21 UL: 1447.9 to 1462.9 DL: 1495.9 to 1510.9 22 UL: 3410 to 3490 DL: 3510 to 3590 23 UL:2000 to 2020 DL: 2180 to 2200 (LTE only) 24 UL:1625.5 to 1660.5 DL: 1525 to 1559 (LTE only) 25 UL: 1850 to 1915 DL: 1930 to 1995 26 UL: 814 to 849 DL: 859 to 894 27 UL: 807 to 824 DL: 852 to 869 (LTE only) 28 UL: 703 to 748 DL: 758 to 803 (LTE only) 29 UL: - DL: 717 to 728 (LTE only) 30 UL: 2305 to 2315 DL: 2350 to 2360 (LTE only) 31 UL: 452.5 to 457.5 DL: 462.5 to 467.5 (LTE only) 32 UL: - DL: 1452 - 1496 35 1850 to 1910 38 2570 to 2620 39 1880 to 1920 40 2300 to 2400 41 2496 to 2690 42 3400 to 3600 43 3600 to 3800 MIMO 1 MIMO 2 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓   ✓ ✓ ✓ ✓ ✓ ✓  ✓ ✓ ✓ ✓  ✓  ✓  ✓ ✓ ✓ ✓      ✓ ✓ ✓    ✓ ✓   ✓ ✓ ✓ ✓ ✓   SPE-12-8-146/I/PK Page 5 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 3. LTE MIMO 3.1. LTE MIMO 1 and LTE MIMO 2 Specification 3.1.1. Return Loss LTE MIMO 1 LTE MIMO 2 3.1.2. Maximum Gain LTE MIMO 1 LTE MIMO 2 SPE-12-8-146/I/PK Page 6 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 3.1.3. Average Gain LTE MIMO 1 LTE MIMO 2 3.1.4. Efficiency LTE MIMO 1 LTE MIMO 2 SPE-12-8-146/I/PK Page 7 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 3.2 Radiation Patterns SPE-12-8-146/I/PK Page 8 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 3.2.1 LTE MIMO 1 Radiation Pattern XY plane X Y X Y SPE-12-8-146/I/PK Page 9 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 X Y X Y SPE-12-8-146/I/PK Page 10 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 XZ plane Z X Z X SPE-12-8-146/I/PK Page 11 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 Z X Z X SPE-12-8-146/I/PK Page 12 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 3.2.2 LTE MIMO 2 Radiation Pattern XY plane X Y X Y SPE-12-8-146/I/PK Page 13 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 X Y X Y SPE-12-8-146/I/PK Page 14 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 XZ plane Z X Z X SPE-12-8-146/I/PK Page 15 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 Z X Z X SPE-12-8-146/I/PK Page 16 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 4. 2.4/ 5GHz MIMO 4.1. 2.4/5 GHz MIMO 1 and MIMO 2 Specification 4.1.1. Return Loss WiFi MIMO 1 WiFi MIMO 2 4.1.2. Maximum Gain WiFi MIMO 1 WiFi MIMO 2 SPE-12-8-146/I/PK Page 17 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 4.1.3. Average Gain WiFi MIMO 1 WiFi MIMO 2 4.1.4. Efficiency WiFi MIMO 1 WiFi MIMO 2 SPE-12-8-146/I/PK Page 18 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 4.2 Radiation Patterns SPE-12-8-146/I/PK Page 19 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 4.2.1 2.4/5GHz MIMO 1 XY plane X Y X Y SPE-12-8-146/I/PK Page 20 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 X Y XZ plane Z X SPE-12-8-146/I/PK Page 21 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 Z X Z X SPE-12-8-146/I/PK Page 22 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 4.2.2 2.4/5GHz MIMO 2 XY plane X Y X Y SPE-12-8-146/I/PK Page 23 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 X Y XZ plane Z X SPE-12-8-146/I/PK Page 24 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 Z X Z X SPE-12-8-146/I/PK Page 25 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 5. GPS/GLONASS Antenna Characteristics 5.1 Block diagram SPE-12-8-146/I/PK Page 26 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 5.2 Return Loss SPE-12-8-146/I/PK Page 27 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 5.3 GPS/GLONASS Antenna Radiation Pattern XYZ co-ordinate for reference. XZ-plane Free Space @1575.42MHz SPE-12-8-146/I/PK Page 28 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 YZ-plane Free Space @1575.42MHz SPE-12-8-146/I/PK Page 29 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 XZ-plane Free Space @1602MHz SPE-12-8-146/I/PK Page 30 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 YZ-plane Free Space @1602MHz SPE-12-8-146/I/PK Page 31 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 5.4 GPS/GLONASS LNA SPE-12-8-146/I/PK Page 32 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 6. Drawing (unit: mm) SPE-12-8-146/I/PK Page 33 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 7. Installation SPE-12-8-146/I/PK Page 34 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 8. Packaging • 1 Antenna Individual Box • Weight: 1.53Kg SPE-12-8-146/I/PK Page 35 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. SPE-12-8-146/I/PK Page 36 of 36 MA750.A.A301111.B305111.I305111.C305151.G305151
MA750.B.ABICG.003 价格&库存
很抱歉,暂时无法提供与“MA750.B.ABICG.003”相匹配的价格&库存,您可以联系我们找货
