OMB.450.B06F21
OMB.450.B06F21
    TAOGLASLIMITED
    450MHZ5DBIOMNIANTENNA,WITHN
OMB.450.B06F21 数据手册
SPECIFICATION Part No. : OMB.450.B06F21 Description : Barracuda - 450MHz-470MHz LTE BAND 31/ CDMA / ISM 6dBi Omni Directional Outdoor Antenna with N Type Female Connector, U-Bolt, 1474mm Length Features : Omni-Directional Radiation Pattern Collinear 6dBi peak gain Robust design for all weather operation IP65 waterproof Length: 1474mm, Weight: 1010g N Type Female connector Wall mount bracket included RoHS compliant DSP-15-8-SPE-16-8-022/D/WY Page 1 of 13 1. Introduction The OMB.450.B06F21 is a 6dBi LTE BAND 31 / CDMA / ISM 450MHz to 470MHz fiberglass omni-directional outdoor antenna. The antenna is designed for applications such as metering, industrial/environmental monitoring, remote asset monitoring, and mesh network applications. The omni-directional antenna radiates uniformly in the azimuth. The high peak gain collinear dipole array design provides the best performance because the antenna gives maximum coverage range in the horizontal plane over 360 degrees, thus minimizing the amount of routers, base stations or nodes needed for a network. The UV resistant fiberglass housing enables the OMB antenna to be weathered in all kinds of harsh environments, making it more robust and safer than traditional whip antennas. It can be connected directly to the access point or telemetry unit, or can be mounted on wall/device surface via the N-type connector. Connector is customizable subject to MOQ. A smaller 3dBi model is also available, the OMB.450.B03F21. DSP-15-8-SPE-16-8-022/D/WY Page 2 of 13 2. Specification ELECTRICAL Standard ISM 450 Band 450 ~ 470 MHz Antenna Type Collinear Dipole Array Peak Gain 6 dBi Polarization Vertical Impedance 50 ohms Max Input Power 100 watts VSWR 1.5:1 Radiation Omni-Directional Vertical Beamwidth 38 Deg Horizontal Beamwidth 360 Deg Internal Material Copper Connector N Type Female MECHANICAL Length 1474 mm(Max) Radome Diameter 24mm Bracket Dimension 70 x 73mm(Max) Antenna Weight 1010 g Mounting Accessories Weight 70g Application Indoor/Outdoor Radome Material White Fiberglass Bracket Material Aluminum Mount Style Pole Mount/Wall Mount Mount Hardware Material Stainless Steel Wind Resistance >150mph (>241km/h) Waterproof IP65 DSP-15-8-SPE-16-8-022/D/WY Page 3 of 13 ENVIRONMENTAL Storage Temperature -40°C to +85°C Operating Temperature -40°C to +85°C Operating Humidity 10%~90% non-condensing Storage Humidity 5%~90% non-condensing DSP-15-8-SPE-16-8-022/D/WY Page 4 of 13 3. Antenna Characteristics 3.1 VSWR DSP-15-8-SPE-16-8-022/D/WY Page 5 of 13 3.2 Peak Gain E-plane H-plane DSP-15-8-SPE-16-8-022/D/WY Page 6 of 13 4. Antenna Radiation Pattern 4.1 Measurement Setup Vertical Pattern – E plane Y Z X Horizontal Pattern – H plane Y Z X DSP-15-8-SPE-16-8-022/D/WY Page 7 of 13 4.2 2D Radiation Pattern Vertical Pattern – E plane Horizontal Pattern – H plane DSP-15-8-SPE-16-8-022/D/WY Page 8 of 13 5. Mechanical Drawing (Unit: mm) DSP-15-8-SPE-16-8-022/D/WY Page 9 of 13 DSP-15-8-SPE-16-8-022/D/WY Page 10 of 13 6. Packaging DSP-15-8-SPE-16-8-022/D/WY Page 11 of 13 7. Antenna Installation Guide DSP-15-8-SPE-16-8-022/D/WY Page 12 of 13 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. Copyright © Taoglas Ltd. DSP-15-8-SPE-16-8-022/D/WY Page 13 of 13
OMB.450.B06F21 价格&库存
很抱歉,暂时无法提供与“OMB.450.B06F21”相匹配的价格&库存,您可以联系我们找货
OMB.450.B06F21
  • 100+804.24602100+100.59275
