OMB.433.B06F21
OMB.433.B06F21
    TAOGLASLIMITED
    OMB.433.B06F21
OMB.433.B06F21 数据手册
Barracuda Part No: OMB.433.B06F21 Description: Barracuda - 433MHz 6dBi Omni Directional Outdoor Antenna with N Type Female Connector Features: Omni-Directional Radiation Pattern Collinear 6dBi Peak gain, 433 MHz Fiberglass Housing Robust design for all weather operation IP65 waterproof Length: 1473mm | Weight: 1300g N type Female connector Mounting bracket included RoHS & Reach Compliant SPE-16-8-020-E 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing 11 6. Packaging 12 7. Antenna Installation Guide 13 Changelog 14 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-8-020-E www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. The OMB.433.B06F21 is a 6dBi fiberglass omni-directional outdoor antenna, operating in 433 MHz ISM band. The antenna is designed for applications such as metering, industrial/environmental monitoring, remote asset monitoring and mesh network applications. 1. The OMB.433 operates at 433MHz, one of the most widely used license free ISM bands, with a 6dBi peak gain. The omni-directional antenna radiates uniformly in the azimuth providing coverage over long distances. Coupled with a very low VSWR, this characteristic provides the best performance because the antenna gives maximum coverage range in the horizontal plane over 360 degrees, thus minimizing the amount of nodes needed for a mesh network. 1. 1. Introduction Introduction Introduction The UV resistant fiberglass housing enables the OMB antenna to be utilized in all kinds of harsh environments, making it more robust and safer than traditional whip antennas. It can be connected directly to the access point or telemetry unit, or can be mounted on wall or device surface via the N-type connector. Introduction A smaller model, OMB.433.B03F21, with 3dBi peak gain, is also available. SPE-16-8-020-E www.taoglas.com 3 2. Specifications Electrical 3. 3. 4. Frequency (MHz) Antenna Characteristics2. 433 Specifications Antenna Type Collinear Dipole Array Peak Gain 6 dBi Polarization Vertical Impedance Characteristics Antenna 50 ohms Max Input Power 100 watts VSWR 1.5:1 Radiation Omni-Directional Antenna Radiation Patterns3.Antenna13 Deg Vertical Beamwidth Horizontal Beamwidth Characteristics2. Internal Material 360 Deg Specifications Copper Connector N Type Female Mechanical 3. 3. 4. Length Characteristics2. Antenna Radome Diameter 24mm Bracket Dimension 70 x 73mm(Max) Antenna Weight 1040g Mounting Accessories Weight 70g Application Indoor/Outdoor Radome Material White Fiberglass Bracket Material Aluminum Antenna Characteristics Antenna Radiation Patterns3.Antenna Mount Style Pole Mount/Wall Mount Mount Hardware Material Characteristics 4. 4. 1473 mm(Max) Specifications Stainless Steel Wind Resistance >150mph (>241km/h) Waterproof IP65 Environmental Antenna Radiation Patterns Storage Temperature -40°C to +85°C Operating Temperature -40°C to +85°C Operating Humidity 10%~90% non-condensing Storage Humidity 5%~90% non-condensing Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-16-8-020-E Specifications www.taoglas.com 4 3. Antenna Characteristics ISM 433Radiation Patterns3.Antenna 4.3.1 Antenna Return Loss Characteristics 0 OMB.433 4. -5 Antenna Radiation Patterns -10 -15 Antenna Radiation Patterns3.Antenna (dB) 4. Characteristics -20 -25 4. -30 Antenna Radiation Patterns3.Antenna 420 425 430 435 440 450 (MHz) 445 Characteristics Efficiency 4. Antenna Radiation Patterns 100 90 80 4. Antenna Radiation Patterns 70 4. (%) 60 50 Antenna Radiation Patterns 40 30 4. 20 Antenna Radiation Patterns3.Antenna 10 OMB.433.B06F21 Characteristics 0 425 4. 426 427 428 429 430 431 432 433 434 435 Antenna Radiation Patterns3.Antenna SPE-16-8-020-E 436 437 438 439 440 (MHz) www.taoglas.com 5 Average Gain 10 OMB.433.B06F21 (dB) 5 0 -5 (MHz) -10 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 Peak Gain 10 OMB.433.B06F21 (dBi) 5 0 -5 -10 (MHz) 425 426 SPE-16-8-020-E 427 428 429 430 431 432 433 434 435 436 437 438 439 440 www.taoglas.com 6 4. Radiation Patterns 4. 4. 4. 4.1 Test Setup Antenna Radiation Patterns Antenna Radiation Patterns Y X 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-16-8-020-E Z www.taoglas.com 7 4.2 430MHz 3D and 2D Radiation Patterns XZ Plane SPE-16-8-020-E YZ Plane XY Plane www.taoglas.com 8 4.3 433 MHz 3D and 2D Radiation Patterns XZ Plane SPE-16-8-020-E YZ Plane XY Plane www.taoglas.com 9 4.4 436 MHz 3D and 2D Radiation Patterns XZ Plane YZ Plane XY Plane 330 300 270 10 0 -10 -20 -30 -40 0 30 60 90 240 120 210 150 180 SPE-16-8-020-E 436MHz (dBi) www.taoglas.com 10 5. Mechanical Drawing (Units: mm) 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-020-E Mechanical Drawing www.taoglas.com 11 6. Packaging 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-020-E www.taoglas.com 12 7. Antenna Installation Guide 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-020-E www.taoglas.com 13 Changelog for the datasheet SPE-16-8-020 – OMB.433.B06F21 Revision: E (Current Version) Date: Notes: Author: 2019-08-29 Updated template, added Return Loss, Efficiency, Average Gain Yu Kai Yeung Previous Revisions SPE-16-8-020-E www.taoglas.com 14 www.taoglas.com © Taoglas SPE-16-8-020-E www.taoglas.com 15
OMB.433.B06F21 价格&库存
很抱歉,暂时无法提供与“OMB.433.B06F21”相匹配的价格&库存,您可以联系我们找货
OMB.433.B06F21
  • 1+1787.009541+231.17697
  • 10+1523.1716110+197.04550
  • 25+1457.3142225+188.52584
库存:21
OMB.433.B06F21
库存:4
