Sharpi Wi-Fi Antenna
Part No. SRC5G027
1.
ceriiANT ®
Product Specification
Features
2.
Antenna for 4.9 – 5.9 GHz applications: Wi-Fi 802.11a/h//j/n/p/ac®
including vehicle to vehicle (V2X) applications
Maintains high performance on device: DFI (Designed For Integration)
Ultra-compact ceramic solution
SMD mounting
Supplied on Tape and Reel
Description
Sharpi is intended for use with 5G Wi-Fi applications. Only requires a small ground
plane. Ideal for single and MIMO antenna systems. This product specification shows
the performance of the antenna over the frequency range 4.9-5.9GHz.
3.
Applications
Access Points
Portable Devices
PC-cards
Set-Top-Box
Network Devices
Wearable devices
V2X networks
MIMO Systems
IP Cameras
Antennas for Wireless M2M Applications
Product Specification Sharpi SRC5G027-PS-1.1
Page 1
Sharpi
Part No. SRC5G027
4.
Part Number
Sharpi: SRC5G027
5.
General Data
Product name
Sharpi
Part Number
SRC5G027
Frequency
4.9-6.0GHz
Polarization
Linear
Operating temperature
-40°C to125°C
Impedance with matching
50 Ω
Weight
< 0.015 g
Antenna type
SMD
Dimensions
1.0 x 0.5 x 0.5 (mm)
Footprint area
5.0 x 3.0 (mm)
6.
RF Characteristics
Peak gain
Average gain
Typical performance
3.50dBi
Conditions
-2.50dBi
4.9 – 5.9 GHz frequency range
All data measured on
Antenova’s evaluation PCB
Part No. SRC5G027-U1
Average efficiency
>60%
Maximum return loss
-6.0dB
Maximum VSWR
3.0:1
Page 2
Sharpi
Part No. SRC5G027
7.
RF Performance
7.1 Return Loss
5
[dB]
Atyune
1
2
-10
-15
-20
-25
-30
-35
4000
[MHz]
4200
4400
4600
4800
5000
5200
5400
5600
5800
6000
6200
6400
6600
6800
7000
7.2 VSWR
12
Atyune
11
10
9
8
7
6
5
4
1
3
2
2
1
4000
[MHz]
4200
4400
4600
4800
5000
5200
5400
5600
5800
6000
6200
6400
6600
6800
7000
Page 3
Sharpi
Part No. SRC5G027
7.3 Antenna patterns
7.3.1
4900 MHz – 5900 MHz
3D pattern at 5.46GHz
Drag to rotate pattern and PCB by using Adobe Reader
(Click to Activate)
Page 4
Sharpi
Part No. SRC5G027
8.
Antenna Dimensions
H
L
W
L
W
H
Length
Width
Height
1.0 ±0.1
0.5 ±0.1
0.5 ±0.1
All dimensions in mm
9.0 Antenna footprint
The recommended host PCB footprint is below.
L
W
P
Length
Width
Height
0.6
0.5
1.0
Page 5
Sharpi
Part No. SRC5G027
10.0 Schematic
The circuit for the antenna and the matching components is below. The RF feed
connection and GND connections are critical to the function of the antenna, and must be
followed as shown. This circuit can be used for the circuit capture of the host PCB.
A1
R1
Pi Network
To RF front end
A1
Antenna (SRC5G027)
R1
Tuning Component
Page 6
Sharpi
Part No. SRC5G027
11. Electrical Interface
11.1 Transmission Line
All transmission lines should be designed to have a characteristic impedance of 50Ω.
• The length of the transmission lines should be kept to a minimum
• Any other parts of the RF system like transceivers, power amplifiers, etc, should also
be designed to have an impedance of 50 Ω
Once the material for the PCB has been chosen (PCB thickness and dielectric constant),
a coplanar transmission line can easily be designed using any of the commercial
software packages for transmission line design. For the chosen PCB thickness, copper
thickness and substrate dielectric constant, the program will calculate the appropriate
transmission line width and gaps on either side of the feed.
11.2 Matching Circuit
The antenna requires a matching circuit that must be optimized for each product. The
matching circuit will require up to three components and the following pad layout should
be designed into the device so the correct circuit can be installed.
The Pi matching network must be placed close to the antenna feed to ensure it is
more effective in tuning the antenna.
An additional tuning component is designed in to aid the tuning of the antenna. This
is default not fitted.
A1
R1
A1
R1
Page 7
Sharpi
Part No. SRC5G027
11.3 Host PCB Layout
The host PCB must ensure the footprint and clearance meets the antenna
specification. The layout shown forms an integral part of the antenna, and any
deviation from this will result in sub optimal performance. It is best that the copper
trace layout is imported from the CAD files which are available from the Antenova
website.
SRC5G027 PCB layout
Below shows the PCB layout without solder mask for illustration purposes only.
Page 8
Sharpi
Part No. SRC5G027
12.0 Antenna Placement
The antenna should be placed close along the PCB edge. This is best near to the
corner of the host for optimal performance.
Page 9
Sharpi
Part No. SRC5G027
13.0 Reference Board
The reference board has been designed for evaluation purposes of SRC5G027 includes a
SMA female connector.
SRC5G027 Evaluation Board
25mm
30mm
To order a reference board contact sales@antenova-m2m.com
Please state if single or two antenna EVB is required.
Page 10
Sharpi
Part No. SRC5G027
14. Soldering
This antenna is suitable for lead free soldering.
The reflow profile should be adjusted to suit the device, oven and solder paste, while
observing the following conditions:
The maximum temperature should not exceed 240 ºC
However for lead free soldering, a maximum temperature of 255 ºC for no more
than 20 seconds is permitted.
The antenna should not be exposed to temperatures exceeding 120 ºC more
than 3 times during the soldering process.
15. Hazardous Material Regulation Conformance
The antenna has been tested to conform to RoHS requirements. A certificate of
conformance is available from Antenova M2M’s website.
16. Packaging
16.1 Optimal Storage Conditions
Temperature
-10ºC to 40ºC
Humidity
Less than 75% RH
Shelf life
24 Months
Storage place
Away from corrosive gas and direct sunlight
Reels should be stored in unopened sealed
manufacturer’s plastic packaging.
Packaging
Note: Storage of open reels of antennas is not recommended due to possible oxidization
of pads on antennas. If short term storage is necessary, then it is highly recommended
that the bag containing the antenna reel is re-sealed and stored in like storage conditions
as in above table.
Page 11
Sharpi
Part No. SRC5G027
16.2 Tape Characteristics
Do
Ao
Bo
1.50 +0.1
See note
See note
E1
1.75 ± 0.1
E2
6.25 ± 0.1
W
8.00 ± 0.3
P0
P1
4.00 ± 0.1
K0
4.00 ± 0.1
F
1.40 ± 0.1
3.50 ± 0.05
P2
2.00 ± 0.05
G
0.75 min
Notes:
The cavity defined by Ao, Bo and T shall be configured to provide sufficient clearance
surrounding the antenna so that:
a) The component does not protrude beyond either surface of the carrier
b) The component can be removed from the cavity in a vertical direction without mechanical
restriction after the top cover tape has been removed
c) Rotation of the component is limited to 20 degrees maximum.
d) Lateral movement of the component is restricted to 0.5mm maximum.
Page 12
Sharpi
Part No. SRC5G027
16.3 Reel Dimensions
A
330.0 ± 2.0
C
13.0 ± 0.5
N
W1
60.0
8.4.0
Quantity
10,000 pcs / reel
Leading Space
16 blank holders
Trailing Space
24 blank holders
Page 13
Sharpi
Part No. SRC5G027
16.4 Box Dimensions
s
Width
(W)
340mm
Breadth Thickness
(B)
(H)
350mm
47mm
16.5 Bag Properties
Reels are supplied in protective plastic packaging.
16.6 Reel Label Information
Antenova Limited
Antenova Asia Ltd
4F, No 324, Sec 1, Nei-Hu Road
Nei-Hu District, Taipei 11493, Taiwan, ROC
60.00mm
info@antenova-m2m.com / www.antenova-m2m.com
Description: Sharpi
Part number: SRC5G027
Quantity: 10,000
Date Code: YYWW
Manufacturer’s code number:
ceriiANT
90.00m
m
Page 14
Sharpi
Part No. SRC5G027
Corporate Headquarters
North America Headquarters
Asia Headquarters
Antenova Limited
nd
2 Floor Titan Court
3 Bishop Square
Hatfield
AL10 9NA
UK
Antenova Limited
100 Brush Creek Road, Suite 103
Santa Rosa
California 95404
USA
Antenova Asia Limited
4F, No. 324, Sec. 1, Nei-Hu Road
Nei-Hu District
Taipei 11493
Taiwan, ROC
Tel: +1 707 890 5202
Email: sales@antenova-m2m.com
Tel: +886 (0) 2 8797 8630
Fax: +886 (0) 2 8797 6890
Tel: +44 1223 810600
Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ®, the Antenova
product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks
of Antenova Ltd. Any other names and/or trademarks belong to their respective companies.
The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not
warrant the accuracy or completeness of the information, text, graphics or other items contained within this
information. Antenova further assumes no responsibility for the use of this information, and all such information
shall be entirely at the user’s risk.
Product Specification Sharpi SRC5G027-PS-1.1 Release date June 2016
Page 15
很抱歉,暂时无法提供与“SRC5G027”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+3.3670610000+0.43558
- 20000+3.3063120000+0.42772
- 国内价格 香港价格
- 1+7.589361+0.98180
- 10+5.4107610+0.69997
- 25+4.8725625+0.63034
- 100+4.27598100+0.55317
- 250+3.99169250+0.51639
- 500+3.82045500+0.49424
- 1000+3.679491000+0.47600
- 2500+3.646562500+0.47174
