SR4W035
SR4W035
    ANTENOVA(安诺亚)
SR4W035 数据手册
Serica 2.4GHz Antenna Part No. SR4W035 1. lamiiANT ® Product Specification Features        2. Antenna for 2.4GHz applications Bluetooth, Wi-Fi, ZigBee, ISM. Maintains high performance on device: DFI (Designed for Integration) Ultra-low profile innovative design. SMD mounting Supplied on Tape and Reel Automotive temperature rating. Description Serica is intended for use with 2.4GHz applications. The antenna only requires a small ground plane. It is ideal for single and MIMO antenna systems. This product specification shows the performance of the antenna over the frequency range 2.4 – 2.5GHz. 3. Applications        Wearable devices Medical equipment Tablets Network Devices MIMO Systems IP Cameras Access Points Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 1 Serica Part No. SR4W035 4. Part Number Serica: SR4W035 5. General Data Product name Serica Part Number SR4W035 Frequency 2.4 – 2.5 (GHz) Polarization Linear Operating temperature -40°C to140°C Environmental Condition Test ISO16750-4 5.1.1.1/5.1.2.1/5.3.2 Impedance with matching 50 Ω Weight 65% -10.0dB 1.85:1 Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 2 Serica Part No. SR4W035 7. RF Performance 7.1 Return Loss 7.2 VSWR Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 3 Serica Part No. SR4W035 7.3 Antenna pattern 2400 MHz – 2500 MHz 3D pattern at 2.45 GHz Drag to rotate pattern and PCB by using Adobe Reader (Click to Activate) Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 4 Serica Part No. SR4W035 8. Antenna Dimensions L W H Length Width Height 6.0 ±0.1 4.0 ±0.1 0.4 +0.1 -0.0 All Dimensions in (mm) Bottom Side Dimensions Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 5 Serica Part No. SR4W035 10.0 Schematic symbol and Pin definition The circuit symbol for the antenna is shown below. The antenna has 6 pins with only two as functional. All other pins are for mechanical strength. Pin Description 2 Feed 3,4,6 Return/GND 1,5 Not used (Mechanical only) Serica Schematic Symbol 9.0 Antenna footprint The recommended host PCB footprint is below. 6 5 4 1 2 3 6 copper pads all 1.0 x 1.0 (mm) Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 6 Serica Part No. SR4W035 11. Electrical Interface 11.1 Transmission Line All transmission lines should be designed to have a characteristic impedance of 50Ω. • The length of the transmission lines should be kept to a minimum. • Any other parts of the RF system like transceivers, power amplifiers, etc, should also be designed to have an impedance of 50 Ω. Once the material for the PCB has been chosen (PCB thickness and dielectric constant), a coplanar transmission line can easily be designed using any of the commercial software packages for transmission line design. For the chosen PCB thickness, copper thickness and substrate dielectric constant, the program will calculate the appropriate transmission line width and gaps on either side of the track, so the characteristic impedance of the co-planar transmission is 50 Ω. 11.2 Matching Circuit The antenna requires a matching circuit that must be optimized for each product. The matching circuit will require up to five components and the following circuit should be designed into the host PCB. Not all components may be required but should be included as a precaution. The matching network must be placed close to the antenna feed to ensure it is more effective in tuning the antenna. Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 7 Serica Part No. SR4W035 12.0 Antenna Integration Guide 12.1 Antenna Placement Whichever size host PCB is used, the antenna should ideally be placed on the host PCB’s longest edge at the centre. Where the centre is not a viable option, the antenna can be placed offset on the PCB to within the limits shown below. A minimum of 6mm from either PCB edge should be observed. Where possible this distance should be greater than 6mm. Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 8 Serica Part No. SR4W035 12.2 Host PCB Layout The footprint and clearance of the host PCB must meet the antenna specification. An example of the PCB layout, below, shows the antenna footprint with clearance. Pins 3, 4 and 6 (GND) are shown directly connecting to the GND with the shortest route. The feed (Pin 2) connects to the matching circuit close to the antenna. Example host layout Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 9 Serica Part No. SR4W035 12.3 Host PCB Clearance The diagram below shows the antenna footprint and clearance through all layers on the PCB. Only the antenna pads and connections to feed and GND are present within this clearance area. The clearance area required is 6.0 x 4.0 (mm). The clear-out area is simply defined as the same size as the antenna. No additional clearance is required. Clearance area Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 10 Serica Part No. SR4W035 14.0 Reference Board The reference board has been designed for the purpose of evaluating SR4W035 and includes an SMA female connector. SR4W035-EVB-1 Evaluation Board To order a reference board contact sales@antenova-m2m.com. Please state if a single antenna or two antenna EVB is required. Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 11 Serica Part No. SR4W035 14.1 Reference Board Matching Circuit The reference board has been designed for the purposes of evaluating SR4W035 and includes an SMA female connector. Designator Type L1 Not Fitted Value Not Fitted Description Not Fitted L2 Inductor 2.2nH C1 Capacitor 1.5pF Murata LQG15HN series or equivalent Murata GRM15HS series or equivalent Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 12 Serica Part No. SR4W035 15. Soldering This antenna is suitable for lead free soldering. The reflow profile should be adjusted to suit the device, oven and solder paste, while observing the following conditions:    The maximum temperature should not exceed 240 ºC. However for lead free soldering, a maximum temperature of 255 ºC for no more than 20 seconds is permitted. The antenna should not be exposed to temperatures exceeding 120 ºC more than 3 times during the soldering process. 16. Hazardous Material Regulation Conformance The antenna has been tested to conform to RoHS requirements. A certificate of conformance is available from Antenova M2M’s website. 17. Packaging 17.1 Optimal Storage Conditions Temperature -10ºC to 40ºC Humidity Less than 75% RH Shelf life 24 Months Storage place Away from corrosive gas and direct sunlight Reels should be stored in unopened sealed manufacturer’s plastic packaging. Packaging Note: Storage of open reels of antennas is not recommended due to possible oxidization of pads on antennas. If short term storage is necessary, then it is highly recommended that the bag containing the antenna reel is re-sealed and stored in like storage conditions as in above table. Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 13 Serica Part No. SR4W035 17.2 Tape Characteristics Ko 0.95 ± 0.1 Ao Bo 4.20 ± 0.1 P0 6.20 ± 0.1 P1 4.00 ± 0.1 8.00 ± 0.1 E F W 1.75 ± 0.1 7.50 ± 0.15 12.00 ± 0.3 P2 2.00 ± 0.1 Dimensions in mm Notes: 1) 10 sprocket hole pitch cumulative tolerance ±0.2 2) Camber not to exceed 1mm in 100mm 3) Ao and Bo measured on a plane 0.1mm above the bottom of the pocket 4) Ko measured from a plane on the inside bottom of the pocket to the top surface of the carrier Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 14 Serica Part No. SR4W035 17.3 Reel Dimensions A 178.0 ± 2.0 C 13.50 ± 0.5 N W1 60.0 ± 0.2 13.0 ± 0.3 All dimensions in mm Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 15 Serica Part No. SR4W035 17.4 Box Dimensions Width (W) 203mm Breadth Thickness (B) (H) 188mm 40mm 17.5 Bag Properties Reels are supplied in protective plastic packaging. 17.6 Reel Label Information Antenova Limited 4F, No 324, Sec 1, Nei-Hu Road Nei-Hu District, Taipei 11493, Taiwan, ROC 60mm info@antenova-m2m.com / www.antenova-m2m.com Description: Serica Part number: SR4W035 Quantity: 1,000 Date Code: YYWW Manufacturer’s code number: lamiiANT ® 90mm Antennas for Wireless M2M Applications Product Specification Serica-SR4W035-PS-1.0 Page 16 Serica Part No. SR4W035 www.antenova-m2m.com Corporate Headquarters North America Headquarters Asia Headquarters Antenova Limited nd 2 Floor Titan Court 3 Bishop Square Hatfield AL10 9NA UK Antenova Limited 100 Brush Creek Road Suite 103, Santa Rosa California 95404, USA Antenova Asia Limited 4F, No. 324, Sec. 1, Nei-Hu Road Nei-Hu District Taipei 11493 Taiwan, ROC Tel: +1 707 890 5202 Email: sales@antenova-m2m.com Tel: +886 (0) 2 8797 8630 Fax: +886 (0) 2 8797 6890 Email: sales@antenova-m2m.com Tel: +44 1223 810600 Email: sales@antenova-m2m.com Copyright® Antenova Ltd. All Rights Reserved. Antenova ®, Antenova M2M ®, gigaNOVA ®, the Antenova product family names, and the Antenova and Antenova M2M logos are trademarks and/or registered trademarks of Antenova Ltd. Any other names and/or trademarks belong to their respective companies. The materials provided herein are believed to be reliable and correct at the time of printing. Antenova does not warrant the accuracy or completeness of the information, text, graphics or other items contained within this information. Antenova further assumes no responsibility for the use of this information, and all such information shall be entirely at the user’s risk. Antennas for Wireless M2M Applications Product Specification Serica-PS-SR4W035-1.0 Release date March 2017 Page 17
SR4W035 价格&库存
很抱歉,暂时无法提供与“SR4W035”相匹配的价格&库存,您可以联系我们找货
SR4W035
  • 1000+3.416431000+0.44197
  • 2000+3.307292000+0.42785
  • 3000+3.252623000+0.42078
  • 5000+3.192065000+0.41295
  • 7000+3.156667000+0.40837
  • 10000+3.1226110000+0.40396
库存:20634
SR4W035
  • 1+6.04290
  • 10+4.27495
  • 25+3.90962
  • 100+3.69042
库存:611
SR4W035
  • 1+6.507551+0.84185
  • 10+4.6033310+0.59551
  • 25+4.2102525+0.54466
  • 100+3.97441100+0.51415
库存:611
SR4W035
  • 1+7.066321+0.91414
  • 10+5.0489010+0.65316
  • 25+4.5373925+0.58698
  • 100+3.97753100+0.51456
  • 250+3.70993250+0.47994
  • 500+3.54892500+0.45911
库存:20634
