1002685
1002685
    ETHERTRONICS
    ANT STAMP WLAN 802.11A 5GHZ SMT
1002685 数据手册
PRODUCT BRIEF: High Performance SMT Antenna Part No. 1002685 1002686 PresttaTM Embedded 802.11a 5GHz KEY BENEFITS DESIGN ADVANTAGES Ethertronics’ Prestta series of Isolated Magnetic Dipole™ (IMD) embedded antennas address the challenges facing today’s product designers. IMD’s high performance and isolation characteristics offer better connectivity and minimal interference. Prestta antennas can be used in a variety of applications including:  Handsets  Video Bridges  Gateway, Access Points  Tablets  M2M  Automatic Meter Reading  Healthcare  Point of Sale TECHNOLOGY ADVANTAGES Stays in Tune IMD antenna technology provides superior RF field containment, resulting in less interaction with surrounding components. Ethertronics IMD antennas resist de-tuning; providing a robust radio link regardless of the usage position. Prestta antennas use patented IMD technology in a stamped metal configuration to provide high performance. IMD antennas requires a smaller design keep-out area, carry lower program development risk which yields a quicker time-to-market, without sacrificing RF performance. Reduced Costs and Time-to-Market  Standard antenna eliminates design fees and cycle time associated with a custom solution; getting products to market faster. Greater Flexibility with Unique Form Factors  Ethertronics’ IMD technology helps you deliver more advanced ergonomic designs without adverse impact on product performance.  SMD mountable design enables faster and lower cost manufacturing. RoHS Compliant  Ethertronics’ antennas are fully compliant with the European RoHS Directive 2011/65/EU. END USER ADVANTAGES Unique Form Factors Support Advanced Industrial Designs  Smaller, more efficient IMD embedded antennas break through restrictive design rules and provide new freedom in component placement. Superior Range  Better antenna function means longer range and greater sensitivity to critically precise signals— delivering greater customer satisfaction while building brand loy-alty. SERVICE AND SUPPORT Extensive RF Experience  Our Prestta antennas are supported by documentation, and when needed, by the expertise of RF engineers who have integrated hundreds of antenna designs into wireless devices. Global Operations & Design Support  Ethertronics’ global operations supports an integrated network of design centers that can take projects from concept to production. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: High Performance Embedded 5GHz Antenna - P/N 1002685 - 1002686 Ethertronics’ 802.11a Internal (Embedded) Antenna Specifications. Below are the typical specs. Electrical Specifications Typical Characteristics Measurements taken on a Custom Ground Plane. Peak Gain Average Efficiency Return Loss in dB Feed Point Impedance Power Handling Polarization Mechanical Specifications Maximum Dimensions Mechanical Mounting RF Mounting P/N 1002686 #1 5150-5850 MHz P/N 1002686 #2 5150-5850 MHz P/N 1002685 #3 5150-5850 MHz < 6 dBi < 6 dBi < 6 dBi 68 % 75 % 76 % < -10 dB < -12 dB < -10 dB 50 ohms unbalanced 50 ohms unbalanced 50 ohms unbalanced 2 Watt CW 2 Watt CW 2 Watt CW Linear Linear Linear P/N 1002685: 18.00±0.1 mm x 6.00±0.1 mm x 6.00±0.1 mm P/N 1002686: 13.0±0.1 mm x 6.0±0.1 mm x 10.0±0.08 mm Antenna Assembly is Surface Mounted onto main PCB. RF and Ground feed pads are Surface Mounted onto main PCB. Typical Matching Circuit and Return Loss in dB ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: High Performance Embedded 5GHz Antenna - P/N 1002685 - 1002686 Configuration Setup Configuration Setup / Axis for Radiation Patterns 1002685_5G #3 1002686_5G #2 1002686_5G #1 ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: High Performance Embedded 5GHz Antenna - P/N 1002685 - 1002686 Antenna Efficiency in % Antenna Isolation in dB Isolation between each of the three antennas is below -20dB. ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: High Performance Embedded 5GHz Antenna - P/N 1002685 - 1002686 Antenna Radiation Patterns @ 5310MHz ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: High Performance Embedded 5GHz Antenna - P/N 1002685 - 1002686 Antenna Dimensions of the P/N 1002686 ETHERTRONICS 5501 Oberlin Drive, Suite 100, San Diego, CA. 92121, USA www.ethertronics.com Tel +(1) 858.550.3820 | fax +(1) 858.550.3821 | contact: info@ethertronics.com PRODUCT: High Performance Embedded 5GHz Antenna - P/N 1002685 - 1002686 Antenna Dimensions of the P/N 1002685 © 2015 Ethertronics. All rights reserved. Ethertronics, the Ethertronics logo, shaping antenna technology, Prestta, Savvi, Tavvel, Isolated Magnetic Dipole and the iMD logo are trademarks of Ethertronics. All other trademarks are the property of their respective owners. Specifications subject to change and are dependent upon actual implementation. 1002685 1002686 14Dec2015
1002685 价格&库存
很抱歉,暂时无法提供与“1002685”相匹配的价格&库存,您可以联系我们找货
