WLA.10
WLA.10
    TAOGLASLIMITED
    WLA.10
WLA.10 数据手册
Part No: WLA.10 Description: Dual-Band 2.4GHz/5.8GHz Wi-Fi Ceramic Substrate Loop Antenna Features: Dimensions: 3.2mm *1.6mm * 0.5mm High Efficiency Dual-band Wi-Fi 2.4/5.8GHz Low profile Compact Size Surface-Mount RoHS and REACH compliant SPE-16-8-052-D 1. Introduction 3 2. Specifications 5 3. Antenna Characteristics 6 4. Radiation Patterns 8 5. Mechanical Drawing 11 6. Antenna Integration Guide 12 7. Solder Reflow Diagram 21 8. Packaging 22 Changelog 23 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-8-052-D www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. Introduction The WLA.10 2.4 / 5.8 GHz Loop antenna is a high efficiency, miniature SMD, edge mounted ceramic antenna for Dual-band 2.4 / 5.8 GHz Wi-Fi and 802.11 applications where PCB space is limited, such as hand-held devices. The WLA.10 uses the main PCB as its ground plane, thereby maintaining good efficiency despite its small size. The efficiency is very stable on the complete bandwidth of both lower and upper bands allowing for maximum data throughput rates on all channels available. Introduction The WLA.10 can be tuned for different PCB sizes/environments by simply changing the values of the matching circuit. Multiple WLA.10 antennas can be integrated easily on a board to achieve excellent MIMO throughput. 1. 1. Introduction At 3.2mm*1.6mm*0.5mm, the WLA.10 is one of the smallest antennas available worldwide. This antenna is delivered on tape and reel. Typical application Dual-band Wi-Fi Communications Handheld Devices IEEE 802.11 b/g/n/ac Tablet PCs Specialized Control Systems Wireless Remote Controls Introduction The results below are based on a 80mm x 40mm ground-plane. If your ground-plane is smaller the efficiency will decrease. SPE-16-8-052-D www.taoglas.com 3 Many module manufacturers specify peak gain limits for any antennas that are to be connected to that module. Those peak gain limits are based on free-space conditions. In practice, the peak gain of an antenna tested in free-space can degrade by at least 1 or 2 dBi when put inside a device. So ideally you should go for a slightly higher peak gain antenna than mentioned on the module specification to compensate for this effect, giving you better performance. Upon testing of any of our antennas with your device and a selection of appropriate layout, integration technique, or cable, Taoglas can make sure any of our antennas' peak gain will be below the peak gain limits. Taoglas can then issue a specification and/or report for the selected antenna in your device that will clearly show it complying with the peak gain limits, so you can be assured you are meeting regulatory requirements for that module. For example, a module manufacturer may state that the antenna must have less than 2 dBi peak gain, but you don't need to select an embedded antenna that has a peak gain of less than 2 dBi in free-space. This will give you a less optimized solution. It is better to go for a slightly higher free-space peak gain of 3 dBi or more if available. Once that antenna gets integrated into your device, performance will degrade below this 2 dBi peak gain due to the effects of GND plane, surrounding components, and device housing. If you want to be absolutely sure, contact Taoglas and we will test. Choosing a Taoglas antenna with a higher peak gain than what is specified by the module manufacturer and enlisting our help will ensure you are getting the best performance possible without exceeding the peak gain limits. This antenna can be mounted with no performance degradation in either orientation as long as the antenna is soldered correctly via Surface mounting. Please see the integration instructions section for further detail regarding the optimum way to integrate this antenna into your device. For further information please contact your regional Taoglas customer support team. SPE-16-8-052-D www.taoglas.com 4 2. Specifications 3. Antenna Characteristics2. 3. 4. Electrical Specifications Frequency (MHz) 2400-2500 5150-5850 Bandwidth (MHz) 100 (RL
WLA.10 价格&库存
很抱歉,暂时无法提供与“WLA.10”相匹配的价格&库存,您可以联系我们找货
WLA.10
    • 5000+4.26813
    库存:138
