ILA.08
ILA.08
    TAOGLASLIMITED
    ILA.08
ILA.08 数据手册
ILA.08 868MHz 5*3*0.5mm -0.5dBi Ceramic Loop Antenna Part No: ILA.08 Description: 868MHz Embedded Ceramic Loop Antenna for ISM/Lora/LPWAN/Sigfox Features: High Efficiency Omnidirectional Low profile Tiny Size Dims: 5.0*3.0*0.5mm Surface-Mount RoHS & REACH Compliant SPE-16-8-050-B 1. Introduction 3 2. Specifications 4 3. Antenna Characteristics 5 4. Radiation Patterns 7 5. Mechanical Drawing – Antenna 9 6. Mechanical Drawing – Evaluation Board 11 7. Soldering Conditions 12 8. Packaging 13 9. Changelog 15 Taoglas makes no warranties based on the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Taoglas reserves all rights to this document and the information contained herein. Reproduction, use or disclosure to third parties without express permission is strictly prohibited. SPE-16-8-050-B www.taoglas.com 2 1. Introduction 1. Introduction 1. Introduction 1. Introduction 1. 1. 1. 1. The ILA.08 is a new 868MHz ISM band embedded ceramic loop antenna from Taoglas featuring a strong efficiency of 45% at the center of the band. It is the perfect solution for the growing amount of devices using the 868MHz band, such as Sigfox or LoRa applications in Europe, or in metering applications. Introduction This antenna works the best when placed at the center of the board edge. The ILA.08 antenna, at 5*3*0.5 mm, is low profile and would be suitable for devices with space constraints. The ILA.08 is delivered on tape and reel and now allows M2M customers to use an omnidirectional SMT antenna. The omnidirectional radiation characteristics allow for excellent performance regardless of device orientation. This is especially useful for devices that are not fixed in one particular spot during use. When there is little PCB space available for antenna placement, but high performance is required, the ILA.08 is the ideal choice. Introduction Introduction The antenna is manufactured in a TS16949 first tier automotive approved facility and has passed the most stringent reliability testing. Since it is SMD, it is much easier to integrate and more reliable in high volume production compared to helical antennas which are cumbersome to install and subject to variability due to the need for manual assembly. Introduction This antenna can be mounted with no performance degradation in either orientation as long as the antenna is soldered correctly via Surface mounting. Please see the integration instructions section for further detail regarding the optimum way to integrate this antenna into your device. For further optimization to customer-specific device environments and for support to integrate and test this antennas performance in your device, contact your regional Taoglas Customer Services Team. Applications: Sigfox, Lora, LPWAN, Automated Meter Reading (AMR), Radio Frequency Identification (RFID), Remote Monitoring, Healthcare, Sensing, Alarm Systems, Handheld Devices SPE-16-8-050-B www.taoglas.com 3 2. Specifications 3. Antenna Characteristics2. Frequency (MHz) 3. 863 Antenna Characteristics 80 x 40 mm Ground Plane Specifications Antenna 868 870 46.47 44.57 Efficiency (%) 42.57 Peak Gain (dBi) 4. Antenna Radiation Patterns3. Antenna-0.51 dBi -0.91 dBi 80 x 40 mm Ground Plane Max Return Loss (dB) Characteristics2. 3. Specifications -10 dB Impedance (Ω) 50Ω Polarization Linear Input Power(W) Antenna Characteristics2. -0.72 dBi 10 Specifications Mechanical 3. Dimensions (mm) 5.0 x 3.0 x 0.5 Ground plane (mm) 80 x 40 Weight (g) 0.02 Antenna Characteristics Environmental 4. Temperature Range -40°C to 85°C Antenna Radiation Patterns3.Antenna Storage Temperature -40°C to 85°C Humidity Characteristics 20% to 70% Moisture Sensitivity Level 3 (168 Hours) 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna Characteristics2. SPE-16-8-050-B Specifications www.taoglas.com 4 3. Antenna Characteristics 3.1 4. Return Loss Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 3.2 4. Efficiency Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns3.Antenna Characteristics 4. Antenna Radiation Patterns3.Antenna SPE-16-8-050-B www.taoglas.com 5 3.3 Average Gain 3.4 Peak Gain SPE-16-8-050-B www.taoglas.com 6 4. 4.1 4. Radiation Patterns Test Setup – Antenna on Evaluation Board Antenna Radiation Patterns Y 4. Antenna Radiation Patterns X 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns 4. Antenna Radiation Patterns SPE-16-8-050-B Z www.taoglas.com 7 4.2 2D Radiation Pattern XY Plane 868 MHz 5925MHz XZ Plane YZ Plane X Z Z X Y 4.3 Y 3D Radiation Pattern 868 MHz 5925MHz SPE-16-8-050-B www.taoglas.com 8 5. Mechanical Drawing – Antenna 5.1 Antenna Dimension and Drawing 6. Packaging5. 6. Packaging Mechanical Drawing Unit: mm 7.5.2 Application Note6. Packaging5. Antenna Footprint Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing *Taoglas is able to provide CAD drawing file to customers for evaluation. 6. Packaging5. SPE-16-8-050-B Mechanical Drawing www.taoglas.com 9 5.2 Matching Circuit Like all antennas, surrounding components, enclosures, and changes to the GND plane dimensions can alter performance. A pi-matching network like the one shown below is required incase adjustments need to be made. The antenna EVB has the same matching network. The components on the EVB are a good starting point for a new design, but will need to be adjusted upon integration for best performance. The zero ohm resistor is needed to solder down a coax pigtail to make measurements with a vector network analyzer. SPE-16-8-050-B www.taoglas.com 10 6. Mechanical Drawing – Evaluation Board 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-050-B Mechanical Drawing www.taoglas.com 11 7. Soldering Conditions Typical Soldering profile for lead-free process: 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-050-B Mechanical Drawing www.taoglas.com 12 9. Packaging 6. Packaging5. 6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing Mechanical Drawing 6. Packaging5. Mechanical Drawing 6. Packaging 7. Application Note6. Packaging 7. Application Note 7. Application Note6. Packaging 7. Application Note6. Packaging5. Mechanical Drawing 6. Packaging5. SPE-16-8-050-B Mechanical Drawing www.taoglas.com 13 SPE-16-8-050-B www.taoglas.com 14 Changelog for the datasheet SPE-16-8-050 – ILA.08 Revision: B (Current Version) Date: Changes: Changes Made by: 2021-10-31 Format Change, MSL Erik Landi Previous Revisions Revision: A (Original First Release) Date: Notes: Author: SPE-16-8-050-B 2016-05-17 Initial Release STAFF www.taoglas.com 15 www.taoglas.com SPE-16-8-050-B © Taoglas 16 www.taoglas.com
ILA.08 价格&库存
很抱歉,暂时无法提供与“ILA.08”相匹配的价格&库存,您可以联系我们找货
ILA.08
  • 1+29.880461+3.88305
  • 10+25.8200010+3.35538
  • 25+24.3977225+3.17055
  • 100+22.44233100+2.91644
  • 250+21.27131250+2.76426
  • 500+20.44355500+2.65669
  • 1000+19.663561000+2.55533
  • 2500+18.701132500+2.43026
库存:5710
ILA.08
  • 6000+17.858776000+2.32080
库存:5710
ILA.08
