MA301.A.AB.010
MA301.A.AB.010
    TAOGLASLIMITED
    1.4GHz CDMA, GPS, GSM, UMTS Module RF Antenna 824MHz ~ 1.99GHz 28dBic Connector, SMA Male Adhesive
MA301.A.AB.010 数据手册
SPECIFICATION Part No. : MA301.A.AB.010 Product Name : MA.301 GPS/Penta-band Cellular Magnetic Antenna Features : IP65 - Waterproof GPS - High gain LNA up to 32dB Penta-band 850/900/1800/1900/2100 MHz GSM/CDMA/PCS/DCS/UMTS/HSPA Low Profile Height 10.8mm Diameter 55.1mm RoHS Compliant SPE-13-8-022/C/SS Page 1 of 12 MA.301.A.A301621.B301721 1. Introduction The MA.301 is a combination small form factor high performance GPS and Penta-band Cellular (GSM/CDMA/PCS/DCS/ WCDMA/UMTS) antenna to simplify AVL or Fleet management antenna systems worldwide. It comes with magnet mount as standard. An internal O-ring meets IP-65 waterproof standards. With the strongest GPS and Cellular antenna design team in the industry and rigorous testing Taoglas offers guaranteed performance with your system and your environment. The standard version comes with 3 metres RG174 cable and Fakra connectors for both GPS and Cellular feeds. Cables and connectors are customizable upon request. 2. Features GPS  High LNA Gain up to 32 dB  Antenna Gain 28 ± 2 dB  Miniaturized to 56.3 x 17.3 mm  Low Noise 1.5 dB max  Ultra-Low Power Consumption 6mA typ ( at 2.7V~3.3V dc) Cellular  Advanced penta-band cellular antenna (GSM/CDMA/PCS/DCS/WCDMA/UMTS) Other  IP65 Water Resistant due to Internal O-Ring Structure  Quality textured covert design. Low profile  UV resistant ABS housing  Optional - high grade 3M double sided tape for quick and easy mounting  Optional cables and connectors  ROHS Compliant SPE-13-8-022/C/SS Page 2 of 12 MA.301.A.A301621.B301721 3. Performance Specifications Performance Specifications Items GPS Antenna Features High performance GPS ceramic patch antenna with cutting edge low noise amplifier Frequency Gain Noise Figure Polarization Bandwidth VSWR Impedance Power Consumption Cable / Connector Operating Temperature Storage Temperature Size 1575.42 MHz ± 2MHz 28 dB typ. Gain at Zenith :-3 dBi min Axial Ratio : 3.0 dB typ 1.5 dB max. RHCP 10 MHz min @ -10dB 1.92 max 50Ω 6mA ( at 2.7 ~ 3.3V dc) Standard 2/3/5m RG174 Cables and Connectors Fully Customizable Cellular Antenna CDMA: 824~896 MHz GSM: 880~960 MHz PCS: 1850~1990 MHz DCS: 1710~1880 MHz UMTS/WCDMA As above As patterns - Linear As S11
MA301.A.AB.010 价格&库存
很抱歉,暂时无法提供与“MA301.A.AB.010”相匹配的价格&库存,您可以联系我们找货
